PALIT GTX1070 diagnosing help
  • geonak
    • Jul 2022
    Please bear with me as this post might be a bit long, but this is the first GPU I tinker with, and I am using it as a learning excercise.
    I received this GPU (PALIT GTX1070 Jetstream) from a friend who hadn't used it in a long while, put it in a machine, and things worked. Updated the drivers, and tried stress testing, after a minute or so there was some brief artifacting and the computer crashed.
    I tried loads to get an image out of it again to no avail (back light stays on but no image or post). I obviously ruled out the basic stuff, different machines, other gpus on the same machine...etc.
    So far I had been connecting using DVI, then one time I decided to try hdmi instead, and to my surprise the card posted! got to the windows logo, then crash. And it went to the same place as DVI (back light stays on but no image or post).
    after some online research, which suggested memory issues, I went ahead and ran some mods/mats tests, nothing conclusive, my knowledge is limited here, so it might be I am not doing things right. But basically some versions worked better than others, and each version (out of the ones that I managed to get to work) giving totally different results (sometimes getting errors on all banks, sometimes errors on one bank). also worth mentioning, booting through vga I could see an error 43 in windows.
    At this stage I started testing things, no shorts, resistances seemed all good, voltages all present and good, pci lanes to gpu all good.
    Left the gpu overnight in the above state, and came back to it the next morning. All of a sudden now I turned the machine on and got one long beep and two short ones, the gpu didn't seem to be detected anymore (in windows, or mods/mats).
    At this stage, I rechecked all resistances, voltages and pci lanes, everything checks out, except maybe one thing, I am getting a resistance of 20ohms on the pex rail now, I could swear I was getting something around 50 before, but can't say for certain. All voltages are correct though including pex. Thinking the reistance might be low, I wanted to check if the GPU is prodding the bios, so did some checks, and the bios seems to be prodded the right ways, vdd present, and oscilloscope showing pin 1 pulled low and something happening on pin 2.
    Here is where I am at the moment, a bit stuck and out of ideas. So any tips, help, or telling me that I am being an idiot and it was obvious and staring me in the face all along are welcome.
    If you read this far I appreciate your patience, and thank you for it!
    Please do not hesitate to prod me for more infos if that helps.
    Cheers,
    G
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3582
    • slovakia
    Re: PALIT GTX1070 diagnosing help
    memory error. run LORD OF GPU test and replace failed memory ic. only basic MATS test is weak to show bad memory with few errors
    • geonak
      • Jul 2022
      Thank you for the reply.
      Any links or videos that show the lord of the gpu test as I can't seem to easily find something online?
      More importantly, as mentioned above the current status is that the gpu is not being detected, even thogh all the voltages are present, and the bios seems to be being prodded by the gpu. (not forgetting that suspicious low 20ohm resitance on pex).
      any tips or ideas of what tests I should run next to try and figure out what is going on and try to get back to a detected state? so that I can start testing the memory again?
      Cheers,
      G
      • konter
        ACER Nitro 5 AN515-55-774Z errors in mats
        by konter
        ACER Nitro 5 AN515-55-774Z ((FH52M LA-J891P REV.1))
        Intel Core i7-10750H
        RTX 2060 6GB GDDR6
        There was a short circuit on the video memory power supply. Replaced all memory with new memory. The short circuit is gone.
        Now the laptop turns on and works. But heats up a lot. Turned on with external cooling. In Windows the video card is detected but after installing the correct drivers it gives error 43.
        In MATS test on 5mb writes a lot of errors on all memory channels on the record. (Attached report)
        When testing on 2mb of memory built into gpu...
        10-19-2024, 11:24 AM
      • tarikabak
        PALIT RTX 3060 VRAM LOCATION
        by tarikabak
        Hello, one of the vrams of my palit rtx 3060 model graphics card is showing as faulty. I will replace the faulty vram with a new one, but I could not find out the locations of the vrams. Does anyone know the location map such as a0, a1, b0, b1?
        mats version 455.127. Testing GA104 with 20 MB of memory starting with 0 MB.
        Memory Errors on
        Read Error Count: 0
        Write Error Count: 410022
        Unknown Error Count: 0
        === MEMORY ERRORS BY SUBPARTITION ===
        SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
        01-13-2025, 09:21 AM
      • chappers
        Nvidia MATS help please - 33 errors on two cards?
        by chappers
        I'm new to MATS and can only use it after watching a Youtube video, downloading the one he linked to (version 400.184) and running it without changing anything. I have no great understanding of it.
        I have 3 graphics cards in the house.
        My son's - Palit GTX 1080 used for 3D games constantly.
        Mine - Nvidia GTX 1080 not used for 3D games, just basic stuff.
        Inno3D RTX 2080 I bought faulty hoping to repair for my son's PC.
        Running MATS on my son's GTX 1080 gives a pass with no errors.
        Running MATS on my GTX 1080 gives...
        08-09-2023, 01:28 PM
        ASUS ROG G20CB-DH71-GTX1070 ROG i7-6700 Specification for Upgrade or Repair
        This specification for the ASUS ROG G20CB-DH71-GTX1070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ROG G20CB-DH71-GTX1070 boardview and ROG G20CB-DH71-GTX1070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-12-2024, 03:30 PM
      • ktmmotocross
        Nvidia rtx 2060 - MATS shows no errors, but with OCCT Vram test GPU freeze with atefa
        by ktmmotocross
        Nvidia rtx 2060 - MATS shows no errors, but with OCCT Vram test GPU freeze with atefacts
        on this card i replace one VRAM chip and card work for 5 days, but now i know some other ram is bad. but how to find bad chip when MATS cannot locate it?
        10-31-2021, 03:18 AM
