Nvidia rtx 2060 - MATS shows no errors, but with OCCT Vram test GPU freeze with atefa
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Nvidia rtx 2060 - MATS shows no errors, but with OCCT Vram test GPU freeze with atefacts
    on this card i replace one VRAM chip and card work for 5 days, but now i know some other ram is bad. but how to find bad chip when MATS cannot locate it?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Re: Nvidia rtx 2060 - MATS shows no errors, but with OCCT Vram test GPU freeze with a
    i next see that card was reflowed by amateur, because of lifted capacitors, so i bet on cracked ball under GPU. custommer dont want to reball gpu so no fix
    • chappers
      Nvidia MATS help please - 33 errors on two cards?
      by chappers
      I'm new to MATS and can only use it after watching a Youtube video, downloading the one he linked to (version 400.184) and running it without changing anything. I have no great understanding of it.
      I have 3 graphics cards in the house.
      My son's - Palit GTX 1080 used for 3D games constantly.
      Mine - Nvidia GTX 1080 not used for 3D games, just basic stuff.
      Inno3D RTX 2080 I bought faulty hoping to repair for my son's PC.
      Running MATS on my son's GTX 1080 gives a pass with no errors.
      Running MATS on my GTX 1080 gives...
      08-09-2023, 01:28 PM
    • konter
      ACER Nitro 5 AN515-55-774Z errors in mats
      by konter
      ACER Nitro 5 AN515-55-774Z ((FH52M LA-J891P REV.1))
      Intel Core i7-10750H
      RTX 2060 6GB GDDR6
      There was a short circuit on the video memory power supply. Replaced all memory with new memory. The short circuit is gone.
      Now the laptop turns on and works. But heats up a lot. Turned on with external cooling. In Windows the video card is detected but after installing the correct drivers it gives error 43.
      In MATS test on 5mb writes a lot of errors on all memory channels on the record. (Attached report)
      When testing on 2mb of memory built into gpu...
      10-19-2024, 11:24 AM
    • tarikabak
      PALIT RTX 3060 VRAM LOCATION
      by tarikabak
      Hello, one of the vrams of my palit rtx 3060 model graphics card is showing as faulty. I will replace the faulty vram with a new one, but I could not find out the locations of the vrams. Does anyone know the location map such as a0, a1, b0, b1?
      mats version 455.127. Testing GA104 with 20 MB of memory starting with 0 MB.
      Memory Errors on
      Read Error Count: 0
      Write Error Count: 410022
      Unknown Error Count: 0
      === MEMORY ERRORS BY SUBPARTITION ===
      SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
      01-13-2025, 09:21 AM
    • dicky96
      Asus GTX 750 ti OC 2GD5 Vram Fault but MATS didn't detect it
      by dicky96
      Hi guys
      I have this Asus 750ti OC 2G DDR5 graphics card that appears to have a problem with the RAM. Also the resistance from Vram VRM to ground is about 320R which seems unusually high to me though I am not familiar with these cards.
      The graphics card gives a picture in the BIOS with lines on it. I can also get it to boot into windows 10 desktop sometimes (with no lines on the screen) but it crashes before I can do anything useful.
      I tried MATS from a bootable USB but it does not seem to detect it, I can see MATS giving an error like 'invalid register' then...
      12-06-2021, 01:05 PM
    • dreico33
      Asus Strix 1060 GTX NO VMEM Voltage & MATS Shows READ Error on Every VRAM.
      by dreico33
      Hellow guys,
      I have 5 Asus strix 1060 with the same problem. No Singal, MATS Shows in every VRAM Read Errors. and i dont have present VMEM Voltage.
      12V Present
      5V Present
      1.8V Present
      PEX Rail 1V
      GPU CORE Present 0,7v
      VMEM NO Volts
      PWM Controller
      VCC 5V
      EN 3.1 V
      VREF 2.1 V
      As far as i can understand or is a problem with the memory Controller ( in this case there is no solucion?) or for some reason the vram do not have Voltage. By the way i...
      09-02-2024, 10:31 AM
