RX 470 mining short
  • Noovas
    • Jan 2022
    • 14
    • Bulgaria
    RX 470 mining short
    Hello friends,
    I have RX 470 4G mining card which is not working. After removing the mosfets there is still short between drain and source pads of the PCB.
    I think that the problem could be a bad cap, but without schematic it is not easy, I just dont know where to start from. I am uploading a photo of the PCB with removed mosfets. Any idea will be helpfull!! Thanks for the support !!
  • didi79
    • May 2021
    • 80
    • BE
    Re: RX 470 mining short
    So we are talking about the low side MOSFETs. This means you have a short between your load (the GPU) and ground.
    You could try isolating the VRMs by removing the chokes. Not easy to desolder tho.
    Another option is voltage injection and check for heat. But since we are on the GPU side, make sure to keep voltage low enough. I find this technique quite hard because there is not that much heat generated with low voltage. And heat dissipation in the pcb makes it quite hard to detect the actual heatspot.
    • Noovas
      • Jan 2022
      • 14
      • Bulgaria
      Thank you for your reply didi79.
      I also was thinking to apply 0,5volts between drain and source and see if there is something heating.
      • Noovas
        • Jan 2022
        • 14
        • Bulgaria
        If I don't detect any heat is that mean that the GPU is dead?
        Also if I remove all 4 chokes and there is no shortage, this means that the GPU is dead?
        • didi79
          • May 2021
          • 80
          • BE
          Answer to both questions: not necessarily
          The chance of the chokes creating a short is extremely low. You remove them to separate the VRM phases. Would make finding a short in one of the VRMs easier.
          • Noovas
            • Jan 2022
            • 14
            • Bulgaria
            I applied 0,8V, 2A and after 10 minutes I still can find a warm component.
            Now I will remove chokes one by one
            • Noovas
              • Jan 2022
              • 14
              • Bulgaria
              I think I stucked.... After removing the first choke there was no short for the corresponding MOSFET. Then I removed the second and the short for corresponding MOSFET also was gone. This is the same and for the other two. Now I don't have chokes and no short. It looks they are parallel to the MOSFET? One side to source and the other to drain ��
              • didi79
                • May 2021
                • 80
                • BE
                Each MOSFET has its corresponding coil. But on the GPU side all coils come together: you can see they are all connected to the same big trace on the pcb.
                I'm not sure how and where you are measuring. Do you have a short from GPU (the big trace where all the coils connect to) to ground?
                You should also be able to measure the high side MOSFETs easily (since your low sides are gone): none of the contacts should be shorted to ground. If one is, you have found the faulty one.
                In my experience it's usually the high side MOSFETs that fail.
                But don't mistake a switched MOSFET as shorted (measured from source to drain). If you put your multimeter positive probe on the gate, you will briefly switch the MOSFET.
                • Noovas
                  • Jan 2022
                  • 14
                  • Bulgaria
                  Yes, on the GPU side all coils are together and grounded!
                  • didi79
                    • May 2021
                    • 80
                    • BE
                    Low resistance over the GPU is normal. Depending on the (lack of) precision of your multimeter, you may not even see the difference between short or low resistance.
                    • Noovas
                      • Jan 2022
                      • 14
                      • Bulgaria
                      Thank you Didi,
                      Here are some more tests I made but unfortunately they didn't show where the problem could be...
                      Till now with MOSFETs on high side (all low side removed) and coils motherboard want run. Then I removed all coils and motherboard runs. I put one coil and motherboard want run. After that I removed this coil and put another one to other place but again motherboard want run.
                      Then I decided to remove all low side MOSFETs and to put the coils. Motherboard runs. After installing just a single MOSFET on low side motherboard want run.
                      Is that means that with removing all MOSFETs I am disconnecting the short from one side and removing all coils I am disconnecting the short from the other side?
                      I am uploading two photos just for visualization (motherboard want run in both situation).
                      Thanks,
                      • Noovas
                        • Jan 2022
                        • 14
                        • Bulgaria
                        I just found that with coil and MOSFET on high side burns the MOSFET.
                        • Noovas
                          • Jan 2022
                          • 14
                          • Bulgaria
                          I just turn it on to measure voltages but smoke come out from the cap
                          • didi79
                            • May 2021
                            • 80
                            • BE
                            Thank you Didi,
                            Thanks,
                            In those photos, are these new MOSFETs? If you put back a shorted one, it would make sense the short is still there and card won't power on.
                            Yeah well, shorted MOSFET...
                            I already saw in the above photos that those caps got some heat damage. You should really protect them. Better replace them all: toxic fumes and risk of popping.
                            • Noovas
                              • Jan 2022
                              • 14
                              • Bulgaria
                              When I find a MOSFET dead I don't use it anymore
                              Caps were ok but the heat from the gun melted this plastic under.
                              Whe I have time I will remove the cap and measure it....
                              • didi79
                                • May 2021
                                • 80
                                • BE
                                You said smoke came out: DON'T reuse it!
                                • SiO2
                                  • Apr 2022
                                  • 24
                                  Does the cap show any sign of damage? If smoke came out, that should be a catastrophic failure and hence clearly visible. Also check the neighboring components: MLCCs, the MOSFET driver chip, resistors before applying power again.
                                  Things like his can easily cause a chain reaction of popping components if something is overlooked in a rush.
                                  • Noovas
                                    • Jan 2022
                                    • 14
                                    • Bulgaria
                                    Ok, to be honest I am not 100% sure that the smoke was from the cap, it could be around. I was in hurry to switch off the power .
                                    But I will post the result if there is any progress....
                                    • jkucukov
                                      Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
                                      by jkucukov
                                      I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
                                      During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
                                      02-05-2025, 09:27 PM
                                    • DynaxSC
                                      Extreme High Current & Low Voltage Short Killer ??
                                      by DynaxSC
                                      Hi Folks
                                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                      After taking off the socket, the shorts dissappear again.
                                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                      10-15-2024, 10:13 AM
                                    • aaronkatrini
                                      Help me find the short circuit on this WORKING Nvidia GTX1650
                                      by aaronkatrini
                                      Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                                      Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                                      04-18-2024, 03:15 PM
                                    • mkdj
                                      Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                                      by mkdj
                                      Dear all,
                                      I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                                      I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                                      Both N-Channel Mosfets: nothing odd
                                      P-Channel MOSFET number 1:
                                      source - drain : 117 kOhm
                                      source - gate: 96 Ohm
                                      gate - drain: 117 kOhm
                                      P-Channel MOSFET...
                                      08-20-2025, 06:08 AM
                                    • h0m3w0rk
                                      Repairing a Music Store Professional GO! SUB 18A
                                      by h0m3w0rk
                                      I'm working on repairing a Music Store Professional GO! SUB 18A bass subwoofer, and I need some help troubleshooting an issue with the power amplifier board. The board uses an IR2153 driver and originally had two SLW20N50C MOSFETs. Unfortunately, these MOSFETs burned out. I replaced them with two TK20J60W MOSFETs; however, these also failed almost immediately.
                                      Here are some details:
                                      • SLW20N50C (original):
                                        • Rated for 500 V
                                        • Typical RDS(ON): 0.21 Ω
                                        • Continuous Drain Current: 20 A at 25°C (13 A at 100°C)
                                        • Pulsed Drain Current: 80 A
                                        • Avalanche
                                      02-27-2025, 07:42 AM
