XFX Radeon RX 560 burnt power
  • ostryo
    • Sep 2021
    • 17
    I have XFX RX 560 (RX-560D2S VC.4) which has burnt mosfets and power control unit. After disconnecting the power supply from the core after desoldering the chokes, the resistance on it is about 1.2 Ohm. Does anyone know if this is the correct resistance for this gpu? I wonder if it is worth fixing it.
    In addition, I wanted to ask if anyone has a boardview? The card has burned a few more smaller components that are hard to identify.
    Thank you very much for your help.
    https://imgur.com/a/NPPkHRu
  • didi79
    • May 2021
    • 80
    • BE
    Re: XFX Radeon RX 560 burnt power
    Low GPU resistance is quite normal. You could measure some more trace pairs on the PCI-E connector going to the GPU. If they all measure similare, chances are the GPU is fine.
    BUT: you have some severe burnmarks on the MOSFETs. High probablility that they have fused to the PCB and maybe damaged other PCB traces. Only way to know: desolder the MOSFETs. If you can without too much damage (and pads intact), you may be able to save the card.
    But remember, with this much MOSFETs failed, the PWM controller most certainly failed too.
    Dunno about boardview, but schematics of other RX cards have similarities.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
      03-31-2024, 02:12 PM
    • swimllamaswim
      Precision 5550 LA-J191P No Power, Burnt ISL9538
      by swimllamaswim
      I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
      Here are the voltages measured at that chip:
      To note, DCIN at Pin 17 is low,...
      09-21-2025, 12:26 PM
      09-06-2024, 05:59 AM
