Re: Msi B550M PRO-VDH Identified Missing Components
Sure.
I ordered already 250mW they will be fine ?Leave a comment:
4 means probably case 0402, as far as I remember in this case max. wattage is 0,125W. As this is 10kohms it does not play a role, as max. wattage lost on this resistor will be P = U x U / R, so 12x12/10000 = 0,0144 W, so a range lower than the standard wattage of 0402 resistor case.Last edited by DynaxSC; 03-25-2022, 04:36 AM.Leave a comment:
& Lisa Su, thanks for the schematics, one never knows when it can be needed.Leave a comment:
The chip with the marking MK=7K is a Richtek RT9553B, its the U9 on page 60 of the schematics. Pin one of this chip is 12VN_CS_N_R signal, and it is connected in the schematics (only by the signal name) just below to R34 (93.1R 1%), so what you measure.
So the the resistor just below the cap (on picture with the S83P) could be R34 and your missing cap is most probably C46 (10u 6.3V) as there is no other cap connected directly to pin 1 of U9 and the signal 12VN_CS_N_R is to be found only twice and only on page 60. The other resistor to the left and down is probably R33 / 93,1R1%. Pls measure this resistor to confirm.
To confirm this 1000% it would be interesting, where the pad marked "2" of the cap is connected. I suspect it goes through the "north" going track to one of the pins of CHOKE1 which is most probably just aside to the 12V 8pin CPU power connector.
BTW, the Richtek marking, only the two first letters are meaningful, "=" is always there, and the two final characters are only manufacturing date codes.Attached FilesLast edited by DynaxSC; 03-24-2022, 04:54 PM.Leave a comment:
Resistor from first pin second chip show 93ohm on my multimeter on block diagram I find only one 11 pin chip that have resistor 0ohm + capacitor on first pin and no GND on pin 1-10 like this chip
page 55 RT8125ELast edited by Rabit; 03-24-2022, 02:15 PM.Leave a comment:
Checked on this chip what leg is connected to resistor pad and this lock like pin2 sense and in block diagram I see one with 10kohm 1% resistor this equal to my results from multimeter.
I make close up oh chip connected to capacitor pad
Hi, I woud give it a try with the schematics. The chip near the missing cap is 99% a NCT3933U. There are 4 of them on page 57 in the schematics, called "Over Voltage Control IC". The marking in the datasheet meets the one on the good board. The other chip on your board will be the same, but different make.
If there is a connection on the board between the cap and this chip, you might be able to deduct which cap this is on the schematics, also comparing the resistor values, which can be measured in circuit in most of the cases.
If you attach a picture showing a slighly bigger area, I could have a look on this too. Also one pad of the cap goes somewhere to the "north", it would be helpful to check where it is connected to, eg to identify a part with marking/type, which can be found on the schematics easily.Attached FilesLast edited by DynaxSC; 03-24-2022, 08:10 AM.Leave a comment:
MSI respond that they cannot provided any info , crappy company practices.
My last solution is to visit Rusian hackers forum and buy board-view and schematic of this board that they steal from MSI.Leave a comment:
I am pretty noob to the game so not sure if it's possible to identify these missing components from the schematic. I hope it helps.Attached FilesLeave a comment:
I cannot take it of board without risk that board will not be accepted after return.
Max V on board can be 12V I go with random 16V capacitance I try my luck
Previous owner manage to power this board without of this smd but he have reboots.
Edit:
First I try ask MSI support to provide me with values of this missing SMD, before I try my luck with random value
Edit 2:
Missing Capacitor looks like (X7R, X5R ceramics) light brown microfarads range.Last edited by Rabit; 03-23-2022, 11:18 AM.Leave a comment:
It's a MLCC cap, but to measure its capacitance, you need to take if off the board.
Also power the board, and look what voltage is standing on the cap, then use a cap with at least higher nominal voltage, but to go sure use the highest voltage you can find in this case and capacity available.Last edited by DynaxSC; 03-23-2022, 09:09 AM.Leave a comment:
I bought open box motherboard to clearly see what is missing and later return.
resistor show on multimeter 10kohm in circuit measurement
second smd I believe is capacitor can anyone identified it ?
Hi I get cheap boards to repair ,missing I assume 1 to 3 SMD and 2 pads
Anyone know what SMD missing ?
Right Down Corner next to screw hole
Zoom
Closer Zoom on PAD A I not see any additional connection I can assume dead end ?
Closer Zoom on PAD B
I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.2 Photos-
08-06-2025, 01:36 AM -
by ugamazingBoard had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),... -
by jprezaHi everyone,
I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
Looking at the card, it appears to be missing the following:
1x 1.0uH inductor - orange square
2x...1 Photo -
by gurj1979Hey guys.
Need help with this one.
Fan not spinning due to missing PWN Fan signal.
Also 5 seconds from powering up it freezes, unless in BIOS.
But as soon as Windows starts to load, it will freeze.
CPU is COLD / Room temp when it freezes.
I've replaced the CPU, same problem.
Replaced SIO/KBC IT8987e and reprogrammed - same problem.
Replaced fan - same problem.
Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
Checked the Thermal sensors around CPU and Board to the SIO/KBC and...08-19-2024, 05:22 PM -
by salopianHello. I would need some advice please.
My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
I have already replaced the logic board with another... - Loading...
