GTX970 Best MATS variable
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Hello.
    Anyone knows how to check for variables on "KING_OVERKILL" test disk?
    i have gtx970 which crash when work on drivers.
    i try "KING_OVERKILL" first start find failure ram chips, but if i try to run mats by command variables " mats -e 30 " i get no error. even on my automatic image of nvidia tster inds nothing.
    so how to extract those variables on test disk to know best variables for stress testing rams to the max?
  • Bozog
    • Jan 2022
    • 125
    Re: GTX970 Best MATS variable
    Try this
    Code:
    ./mods gputest.js -oqa -old_gold -test 178 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -fan_speed 100 -matsinfo
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3577
      • slovakia
      i try to run in gtx970a directory but it give me lot of errors like not detecting
      • Bozog
        • Jan 2022
        • 125
        Post the output, someone may know what the issue is.
        • welp
          PS5 Disk Tray issues.
          by welp
          I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
          Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
          Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
          So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
          With that knowledge I preceded to check all the fuses for the 12v rail on the main...
          12-19-2024, 02:04 PM
        • DynaxSC
          Each GPU reballing produces different MATS results, looking for root cause ?
          by DynaxSC
          I have an Nvidia card which makes me wondering, what is the root cause for Mats errors. The story is as follows:
          1. When I received the card Mats showed one memory with errors.
          2. Replaced the memory chip, but no change, still same error, so memory chip is ruled out.
          3. Made a carefull reballing of the GPU, MATS showed 3 memories with errors, the one before, and 2 other new chips.
          4. Made a second reballing of the GPU and Mats shows again only one memory chip with errors, the same on as in the beginning.
          5. Made...
          12-11-2024, 07:44 PM
        • DynaxSC
          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
          by DynaxSC
          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
          The behaviour is also really very strange, i.e.:
          • The disk shows always up in BIOS - so it is recognized, so far so good
          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
          02-23-2025, 01:33 PM
        • chappers
          Nvidia MATS help please - 33 errors on two cards?
          by chappers
          I'm new to MATS and can only use it after watching a Youtube video, downloading the one he linked to (version 400.184) and running it without changing anything. I have no great understanding of it.
          I have 3 graphics cards in the house.
          My son's - Palit GTX 1080 used for 3D games constantly.
          Mine - Nvidia GTX 1080 not used for 3D games, just basic stuff.
          Inno3D RTX 2080 I bought faulty hoping to repair for my son's PC.
          Running MATS on my son's GTX 1080 gives a pass with no errors.
          Running MATS on my GTX 1080 gives...
          08-09-2023, 01:28 PM
        • madura2010
          DAY11AM6E0 hard disk drive and optical disk drive not detected
          by madura2010
          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
          i checked the connectivity of ribbon=good communication with hard and motherboard
          changed hard disk and checked=3f0 error persist
          sata power=+5v available
          Then checked data capacitors=all good
          Then checked data lines path connectivity to pch=all good
          reflashed...
          03-12-2023, 09:09 AM
