Frequency drop 1024Mhz to 350 mhz at 70 degrees - Rx 470 4 go
  • fab13
    • Dec 2021
    • 109
    • France
    Hello to all,
    I repaired a RX 470 4Gb from sapphire it was a mosfet HS on the VCORE only 1 and the card works again in games.
    Except that at the time of the test FURMARK I have falls of frequencies of approximately to 300mhz then goes up in the 1030 mhz every 5 seconds or more when it turns to 73 degrees approximately.
    The image jerks then becomes fluid again and so on as loss of images per second
    In games it makes him from time to time falls of FPS
    This is not ideal during the game =S
    Is it an unstable capacitor on the +VDCC line of the vcore?
    What advice =D
    Thanks a lot to you
  • Bozog
    • Jan 2022
    • 125
    Re: Frequency drop 1024Mhz to 350 mhz at 70 degrees - Rx 470 4 go
    Seems strange, have you checked the phase for the drmos you replaced is actually working, ie. with a scope or frequency meter?
    Also, why is the core clock not going upto 1260mhz?
    • fab13
      • Dec 2021
      • 109
      • France
      Thanks for the answer really, I'm going to go back and check and re-weld correctly despite several checks or get another one.
      Honestly I don't know it seems bridled. I took the bios on https://www.techpowerup.com/ which is for a Nitro + RX 470 4gb (The only one possible)
      I don't have an oscilloscope yet unfortunately.
      The funny thing is that in games I can very well not have a drop in fps at 3 for example during 10 min and sometimes every 15 seconds it is random.
      According to GPUZ, VDCC does not seem to be equally stable, sometimes dropping to 0.80 and peaking at 0.90 v few seconds
      Any other ideas? =D
      • fab13
        • Dec 2021
        • 109
        • France
        I come back to the news and with good news
        I re-welded the IR3553M phase controller because the hot spot climbs in a few seconds 43 degrees on the thermal camera.
        Now no loss of FPS on Furmark and the core frequency remains in the 1000 to 1050 mhz.
        Why doesn't it go up to its 1260Mhz?
        The voltage remains stable at 1 V on VDDC
        It works on the 2 internal bios of the card with HDMI and display port.
        Thanks to the thermal camera really indispensable tool.
        =D
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          u have thermocam and not have scope to chceck if phase is working?
          • fab13
            • Dec 2021
            • 109
            • France
            hello Only one phase was overheating and since then none. It seems to me that last month I also had a RX470 4gb going to the maximum at 1090 mhz for the Core. So maybe normal
            • abajor
              A2251 L8100 Diode Drop .009V Resistance 2.6Ohm
              by abajor
              Trouble shooting an A2251, it is giving me the behavior that all three USB jacks except the DFU port are reading 5.18V .24A, the DFU port draws no current.
              Tried swapping that CD3217 from a donor, that changed to DFU port same behavior the adjacent USB port is now boot cycling, other side un effected.
              Hindsight probably should have checked the diode drops first.
              I removed L8100 to confirm that the PP1v1_S3 rail was "shorted" It reads about 2.4ohm and .009V on diode drop. The HighSide Low Side FETS before L8100 appear to be fine. Proper diode...
              01-18-2025, 04:38 PM
            • survivalbloke
              Xbox Series X - crashing to dashboard shortly after launching games
              by survivalbloke
              Hey all! I've got a XBOX Series X which came in with the complaint of games crashing to the dashboard after launch. I've tested a few games so far. Red Dead Redemption I observed will load up fine and sit on the menu no problem, but once I actually load into the world, it will not complete the load-in, and crash, stating something about an error must be sent to Rockstar, etc.. Truck simulator seemed to work fine. Minecraft loaded up and zoned into a world, but within a few seconds, it too, crashed to the dashboard. Where are the logs stored? What should I check?​
              09-18-2024, 11:54 AM
            • battery.12v
              Asus G512LI VCCCore raise and drop
              by battery.12v
              Hello guys, Asus G512LI, came with 3.3V drop down immediately .... 5V was stable ... after search and work found that +3VSUS_MUX is the issue (caused by U4701A TUSB1146RNQR) , left off the ic .. 3.3V came up again stable ... after power on laptop turn on for 3 seconds and power off ... VCCcore raise 0.9V for 1.5 seconds and drop down all other voltages do same thing ... Ram voltage , Gpu voltages, concerning VCCGT 0V all the time
              05-03-2024, 03:43 AM
            • tfm
              Drop-in replacement for STR-W6052S?
              by tfm
              The ma​in board of this LG washing and drying machine was damaged due to overvoltage. It is rated for 127V and was powered on 380V.
              Inicial visual inspection revealed that only some components at the input of the SMPS were damaged:
              Ironically, both fuses are intact. Probably the X2 cap and the bridge are also damaged. The whole board is immersed in an epoxy resin. I am removing it so I get access to the components.
              The SMPS is built around an STR-W6052S, which is discontinued and I can't get a replacement....
              02-16-2024, 08:29 AM
            • amigo744
              PS5 CFI-1016A DISK shuts down only when playing ps4 games error ce-108262-9
              by amigo744
              Hello there,
              ps5 cfi-1016a disk console
              Problem: ps5 shuts down when playing ps4 games after cold boot with error code ce-108262-9.
              After the shut down the console boots up normal and then the ps4 game functions without a problem.
              ps5 games run allways without any problems after cold boot.
              Thats absolutely curious....
              I have already rebuild database, clean cache and reinstall latest firmware with usb stick in safe mode.
              That doesen´t help
              Furthermore i have opened console and renew liquid metal on gpu.
              This all doesn´t...
              06-19-2023, 05:02 AM
