REFLOW NOT WORK- DO ONLY REBALL - GTX780 shifted/bad colors
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3616
    • slovakia
    hello
    have this GTX780 with shifted/bad colors. i try MATS and it show some errors on ic A1. i do proper reflow BUT colors still the same and add some distortion on picture. do MATS and it shows NO ERRORS
    so i do reball and now everything works ok.
    SO DONT DO REFLOW. DO ONLY REBALL!!!
    but still no HDMI and DP, Only both DVI. Have anybody clue what to check?
  • Bozog
    • Jan 2022
    • 125
    Re: REFLOW NOT WORK- DO ONLY REBALL - GTX780 shifted/bad colors
    Originally posted by ktmmotocross
    hello
    Does it have the correct bios?
    • Olvin1
      Acer nitro 5 an517-52 reflow/rebal CPU
      by Olvin1
      I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
      I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
      • A detailed temperature profile for reflowing this specific CPU
      • Step-by-step guidance for a safe and effective reflow process
      • Tips on what to watch out for during the procedure
      If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...
      08-01-2025, 01:59 PM
    • tony359
      Reflow equipment
      by tony359
      Hello all,
      I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
      I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
      Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
      12-25-2021, 01:29 PM
    • silikon77
      Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
      by silikon77
      Hi!
      Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
      Found some advices watching youtube nad came up with this:
      It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
      I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
      See attached picture.
      I tried a few combinations to block individual clock...
      01-02-2025, 02:26 PM
    • Mr_Nada
      Concerns before attempting a Reflow of Laptop's GPU
      by Mr_Nada
      I saw some posts at one point talking about doing a reflow but I couldn't find them again so I thought that I would post this here.
      I plan on reflowing the GPU of this old HP DV2500 laptop but I want to go over what I have and the steps I have to take to guarantee it will come out fine.
      I have a Yihua 8786D 2in1 Rework station, flux (just some paste that I got from an old Radioshack kit), a couple rolls of Kapton tape and a $15 Thermometer +probe (a TM902C from EMR shielding Solutions if its important).
      • The paper that came with the thermometer states that the probe
      10-10-2024, 02:53 AM
    • groomit
      Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
      by groomit
      I just replaced the battery on a Google Pixel 5.
      After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
      Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
      The rubber seal is on again (as mentioned in various suggestions in other forums).
      This smells like a cold or broken solder joint. So I'd like to reflow...
      06-11-2025, 02:21 AM
