MSI K7T Turbo 3 recap
  • Sudum Gumudu
    • Sep 2005
    • 97
    Hi all.
    I'm going to attempt recapping my two MSI K7t Turbo 3 boards, and has managed to find the following caps from local sources with reasonable shipping costs:
    4700uF Rubycon ZLH
    2700uF Panasonic FC
    1000uF 8x16 Rubycon ZLH
    470uF Rubycon ZLH
    The 3900:s however is a pain. The original caps are 10V, and are not to be found anywhere, but I've found 6,3V 3900 Sanyo MV-WX from a local supplier. Will that do the job, or do I need the higher 10V spec for those.
    If the 6,3V 3900:s are OK, are these an overall acceptable choice? Total cost including shipping $58 for two boards.
    TIA
    Sudum G
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: MSI K7T Turbo 3 recap
    mv-wx should be fine.
    the most they will see is vcore.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      does your supplier have a site we can add to the list of places to buy?
      • Sudum Gumudu
        • Sep 2005
        • 97
        I have ordered the Rubycons from http://www.microkit.se/index.html , but not gotten an order confirmation as of today. The Panasonic FC turned out to be a 12,5mm , and I wanted the 10mm part for a nicer fit. Sanyo MV-WX can be had from www.elfa.se.
        2700;s in 10mm size is a bitch to find. Perhaps I'll put my trust in Topcat, and go for the 3900/3300 and 2700/2200 mod instead. 3300:s and 2200:s Sanyo are readily available from Elfa.
        Sudum G
          by momaka
          03-15-2023, 10:17 PM
        • LealEletronic
          Looking for ASUS TURBO 2080TI Schematic and Boardview.
          by LealEletronic
          Hello guys.
          Im looking for schematic and boardview to ASUS TURBO 2080TI 11GB. Is the same as EVGA board....
          04-22-2025, 05:05 PM
        • Foetuss
          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
          by Foetuss
          Hi all
          Hope this is in the correct place.
          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
          Could use some double checking to see if I'm not doing something stupid .
          Pictures of the boards are attached.
          What I will be replacing with what : (planned)
          Soltek Golden ::
          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
          01-18-2025, 11:44 AM
        • goodpsusearch
          Got 4 LG L222WS 22" for free - psu recap
          by goodpsusearch
          Got 4 CCFL 16/10 monitors for free.
          The resolution is almost Full HD (1680x1050)
          VGA Input only is a bummer though.
          Uses cheap TN panel with terrible viewing angles.
          Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
          All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
          01-15-2022, 05:36 PM
        • varunviolin007
          Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
          by varunviolin007
          Hi guys,
          I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
          I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
          Looking for someone experienced with older PC boards who uses...
          07-29-2025, 11:53 PM
