Any hope for a dead RTX4000 GPU?
  • jayjr1105
    • 281
    This was a garbage freebie from work. A small component (maybe a VRM?) just went up in smoke (see pics). I contacted PNY and pushed pretty hard but they denied my RMA claim saying it could had been a surge from the PSU that made that component fry. I thought about getting an attorney involved for some type of small claims deal but I'm not sure it's worth it. It's well known in the community that PNY pulls this crap for RMA's. The client machine is operating just fine with the same power supply with the new card but they simply won't budge.
    Anyways, going forward with it. Is there any hope for repair? Or just sell for parts? Might fetch a couple hundred as it's a $1000 card new.
    https://www.badcaps.net/forum/attach...1&d=1640296661
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • DrasticRepairs
    • May 2021
    • 23
    Re: Any hope for a dead RTX4000 GPU?
    That's a current ballancing MOSFET. It's not even really needed, but should be replaced anyway.
    The reason it burnt up, though, is because one of the Vcore or VMEM MOSFETs shorted. If it's VMEM, say goodbye. If it's vcore, it's most likely repairable.
    So you'll have 2 MOSFETs, and possibly a gate driver to replace.
    And uhh... that's not an RTX 4000. Those haven't come out yet. More likely an RTX 2060 or 1060.
    • jayjr1105
      • 281
      Quadro RTX 4000
      Ryzen 3600x
      FX-8802 Iron
      • DrasticRepairs
        • May 2021
        • 23
        Originally posted by jayjr1105
        Quadro RTX 4000
        Oh. That makes sense. Looks the same as a 2060, mostly. Still the same diagnosis. If you have the tools I can help you diagnose and repair it. You'll need a multimeter, a hot air station and a soldering iron, preferably, with a bevel tip.
        • jayjr1105
          • 281
          Yep, I have all those things.
          Ryzen 3600x
          FX-8802 Iron
            • 20795
            Do you have a microscope, can you get any better pictures of the burnt part, can you see any part numbers on it at all.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              Please attach images to the thread and not use 3rd party image hosting. I fixed the initial post.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • jayjr1105
                • 281
                I do, just a USB one but I'll try later.
                Sure thing
                Ryzen 3600x
                FX-8802 Iron
                • jayjr1105
                  • 281
                  Here's some images. I cleaned it up with some 99% ipa
                  Ryzen 3600x
                  FX-8802 Iron
                  • DrasticRepairs
                    • May 2021
                    • 23
                    Okay, cool.
                    First, you want to pull that burnt chip off. You can test the card without it. Next, you want to measure resistance on the 12V inputs. So the 6/8 pin connectors and the 3 far left pins on the pcie fingers.
                    That will tell us which rail the shorted MOSFET is on and verify that one really is shorted.
                    A picture of the whole front of the PCB would be helpful.
                    Once you have confirmed that there really is a short, you can look for the VCORE and VMEM, power stages, DRMOS, or MOSFETs, depending on what they used. The part number of those will be necessary to find the high gate and measure the resistance on that for each phase.
                    • jayjr1105
                      • 281
                      Well it got a little more interesting. It's burned on the opposite side in the same location...
                      Ryzen 3600x
                      FX-8802 Iron
                      • jayjr1105
                        • 281
                        So a small update. I did take some time to heat up and remove the upper and bottom components that were cooked. They sort of crumbled off but they are off and the area is cleaned up. The layers seem to be badly burned underneath both components and unfortunately there is still a short to ground somewhere. Whether it's the cooked layers or a surface mount component somewhere I have no idea. I may be at the end of the road with my skillset.
                        Ryzen 3600x
                        FX-8802 Iron
                        • Bozog
                          • Jan 2022
                          • 125
                          I think there is still hope that the GPU survived this, but clearly the PCB is badly damaged and almost certainly the source of the short. It might be a challenging repair
                          • double_DD
                            How can I be sure that my EC chip is dead?
                            by double_DD
                            As the title suggests, how can I be sure that my EC chip is really dead?
                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                            03-12-2025, 07:47 AM
                          • flibidy
                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                            by flibidy
                            I have here a Magnum IA.100 which belongs to my parents.
                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                            What Ive done........
                            01-01-2025, 01:26 PM
                          • disorder
                            ps5 edm-033 dead after hdmi/usb ports destroyed
                            by disorder
                            hello guys,
                            i need help to repair a edm-033 ps2
                            history : as always hdmi port and usb ports destroyed after unplugged
                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                            so i changed it
                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                            i don't see any projection of liquid metal on pcb.
                            01-14-2025, 12:48 PM
                          • Beton
                            Finding a dead short component
                            by Beton
                            Hi guys!
                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                            I have a bench PSU and if I try to inject voltage the voltage...
                            12-10-2021, 01:05 PM
                          • FiguringITout
                            MSI Raider GE75 - Not posting, probable dead CPU
                            by FiguringITout
                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                            07-25-2024, 07:27 AM
