R9 285 DUAL-X OC Version not recognized
  • krsta
    • Nov 2020
    • 33
    • Croatia
    I have the Sapphire card mentioned in title.
    DrMos (FDMF6823C) marked on picture died and killed the fuse marked Q with him. Does anyone know the value of the fuse?
    Or does anyone have list of fuse markings and values?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: R9 285 DUAL-X OC Version not recognized
    10A 125v
    • krsta
      • Nov 2020
      • 33
      • Croatia
      Originally posted by diif
      10A 125v
      Thx
      • sikocan
        Lenovo X1 Carbon 9th Gen Black Screen
        by sikocan
        I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
        SN: PF3G1REP
        MODEL: 20KW-00J1AU
        PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
        Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
        06-24-2025, 09:01 PM
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
        by Vesko356
        08-11-2023, 03:27 AM
      • TJ65
        Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
        by TJ65
        i made out of two broken Samsung Galaxy Tabpro S one that works partially.
        The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
        I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
        The problem is, that the micom Version doesn't match with the bios version, see picture.
        How can i update the Micom Version? The Samsung bios update wont work.
        With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
        01-09-2025, 01:35 PM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
