hi i'm a newbie here...
  • eazer22
    • Apr 2010
    hello there...first of all, i would like to ask if i am welcome in this forum? i have a problem to consult...about my motherboard, it is msi k9vgm-v am2 socket. i bought it, during it was test it is working. now, when i bought a casing for it and try to open it the fan of the proceesor will just run a bit and will stop then it will not continue. there's no burn damage to the motherboard....i tested my power supply and it is working well. so, masters, what seems to be the problem of it. i am looking forward for any help..thank you very much.
    • 31246
    Re: hi i'm a newbie here...
    try another psu.
    • eazer22
      • Apr 2010
      i already try another psu sir..but still no luck...same scenario..
      • mattch
        • Mar 2010
        • 121
        so lemme get this straight
        you opened the case and your problems start? CLOSE THE CASE duh! jk
        Seriously just becasue your power supply makes another system turn on doesnt mean it will make that one turn on. So try another power supply, and if in fact you did, my apologies, its just in past 7 years troubleshooting a problem the end user is never honest. "I didnt do anything!"
        Anywho if it really happenend when you openended case, then you probably grabbed the case by side or top while moving it and flexed the whole case, and the motherboard not screwed down tight enough moved just enough to cause something to cause it not to post
        Me? i would try resetting the CMOS, most times it not the problem, but when it is, dont it feel good to think thats all you had to do?
        • Scenic
          o.O
          • Sep 2007
          • 2642
          wait a second..
          from what i understood, you bought that board and tested it and it worked.
          but it doesn't work when you put it into your new case...right?
          sounds like a standoff too much.. (i've had that before.. shorted the board from the back, and when you tried to turn it on the fans just twitched and the PSU wen't into SCP (short circuit protection) took forever to find that out )
          some info's would be a great start... make/model of your PSU for example..
          resetting the CMOS as mattch said.. well.. give it a try.
          if that doesn't do anything remove the board from the case and benchtest it with only the psu/cpu/ram and (if it doesn't have onboard video) a graphics card..
          if it works fine then, look if there's a standoff too much in the case or something else that shorts out...
          • sofTest
            • Aug 2008
            • 361
            Or none stand offs...
            Be a mensch
              I bought three of these Sparkle Power FSP460-60GLC - Computer Power Supply 460Watts recap need
              I have bought computer switching power supplies from Electronic Goldmine before and every one of them the capacitors were bloated and or leaking out of the capacitors so I am sure that these are going to be the same way five or six years ago I had bought some 300 and 350 watt computer switching power supply from Electronic Goldmine these are all from FSP brand
              Here is the listing for this switching power supply they only had three of them in stock and I bought all three of them
              https://theelectronicgoldmine.com/products/g28149
              I have one old computer that...
              07-18-2024, 06:55 PM
              Another project idea for a battery bought from Battery Hookup with a good BMS board
              https://batteryhookup.com/products/n...-2900mah-cells
              One note these battery packs are below 10 volts and the BMS protection board has locked them off from having any voltage on the BMS output wires I have tested three of them so far and voltage is around 8 volts it not an issue because it testing about 9.2 amp hours
              The price of this offer has gone up sense I bought these two boxes
              I bought two boxes of these batteries but there is a catch to the these battery packs
              The BMS protection board does work but it...
              07-31-2022, 04:07 AM
            • xnRS
              Did I just bought a fakecap ?
              by xnRS
              Today I bought... I mean friend of mine bought capacitors that I ordered, as the shop where i bought it is too far away from me, as he isn't understands anything in electronics, he just bought it as I ordered. At first shop on their page showed 1800uf 6.3V Sanyo caps, with generic picture and code SY-1800(which isn't correct). After little bit of search I found out that it was WG 8X20 capacitors(p.s found that out before buy). Ok, ordered, next day friend gives me package with those caps and some other caps that I ordered. But... This were NOT the Sanyo WG, these were Panasonic(Matsushita) FL...
              06-01-2021, 07:48 AM
              I just bought a SkyRc MC3000 battery testing machine very interesting device temp
              I just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
              The charger has four individual temperature sensors for each battery cell
              The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
              Or test...
              09-14-2022, 07:12 PM
            • studdy05
              Bricked HP Probook 450 G7 Bios questions
              by studdy05
              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
              Ive got...
              07-08-2025, 09:24 PM
