GA-K8NF-9, should I bother re capping?
  • Latoof
    • May 2008
    • 22
    I have just noticed my oldGA-K8NF-9 has bulging caps.. Should I bother re capping it or just bin it? It is still running just fine... so far
    E8400 8G Kingston PC6400 RAM
    GA-EP35-DS3R mobo
    HD4850 512M GA, 2x 1T WD SATA drives
    CoolerMaster case/Seasonic 850w PSU
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: GA-K8NF-9, should I bother re capping?
    I say go for it as long as it has easy to find cap values. I looked up the specs on that motherboard and it still is relevent to todays technology. Just remember, if you're gonna do it, change all of em.
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Or sell it to me - need a S939 board to see if a couple of processors I have are working
      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • Latoof
        • May 2008
        • 22
        Hmm... I have been using it to run BOINC and web access for the kids but with a couple iMacs in the house it's days ARE numbered...
        Tossing up whether or not I should repair and sell or just sell it as is....
        I'll take a closer look at the values and then decide....
        GA-EP35-DS3R mobo
          • 31250
          any 64bit amd is worth fixing.
          • quickname
            Cyberpower 1500AVR UPS repair
            by quickname
            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
            I decided to verify that the batteries were...
            11-12-2023, 09:57 AM
          • hinisa
            Xiaomi router freezes at boot after re-capping
            by hinisa
            I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
            When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
            After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
            Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
            07-08-2023, 05:58 AM
          • dmcabs
            SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
            by dmcabs
            Hey guys,
            I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
            This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
            FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
            I'm a bit rusty but still have ability to dig right down.
            I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
            09-21-2024, 11:09 AM
          • x_orange90_x
            Samsung UN65AU8000FF fried by water
            by x_orange90_x
            I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
            10-16-2025, 08:40 PM
          • howardc64
            LG 65UQ8000AUB no backlight burning smell
            by howardc64
            Only 3 years old. Owner said backlight went out and burning smell. Didn't bother plugging in to check if had power LED. Just opened the TV rear and found shorted bridge rectifier diode on the backlight circuit on the PSU. SF26G (400V 2A super fast recovery rectifier link ) diode replace with SF26 (what I had on hand) Google AI said G = Green Components.
            Burn looked pretty bad on the board but just was blackened carbon coating material. Scraped and cleaned off quite well and clean solder pad for the new diode.
            06-07-2025, 10:38 PM
