Gigabyte GA-Z170X-UD3 no post
  • alderick
    • Jun 2015
    • 77
    • france
    Hi guys,
    Recently my main desktop just die in the night (I shutdown before sleep), no idea why, already buy a new MB and CPU so nothing hurry.
    The PC try to start but no post and code 49 on MB debug digit thingy.
    The PCH is hot, CPU cold, 20W on main plug.
    On PCH package there is some cms caps, 1.32ohm is it normal?
    If i bring power on rail one by one, both 5V and 5v stb take power, ~0.6A.
    Any idea or thing to check?
    Thanks a lot.
    Edit: I did backup M_BIOS and after copy B_BIOS into M_BIOS chip, without any change
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Gigabyte GA-Z170X-UD3 no post
    Does the PCH get hot when you have only standby voltage (before starting the ATX PSU)?
    Do you still have 1.3 ohms on the PCH capacitors with the CPU removed?
    If the answer to either of these is yes, then the PCH is fried
    Follow me on YouTube
    Learn Electronics Repair
    • alderick
      • Jun 2015
      • 77
      • france
      Hello, thank you for the answer.
      Without CPU same 1.3 ohms, and with only standby, it takes 3W at main socket, PCH warm but not as much as when I try to start MB.
      PCH fried anyway so.
      Can't change that thing, I should trash it I guess.
      • taxxin
        • Mar 2021
        • 133
        • thailand
        yes you can change it, I failed mine because i lifted the chip along with its trace pad. you can click the link below 990fx failed southbridge in my signature
        Successfully completed Repairs:
        Current repairs:
        • alderick
          • Jun 2015
          • 77
          • france
          I removed the PCH, the short on MB is gone, so it is fried like you said.
          Since I don't have a BGA rework thingy, I'm gonna trash the MB.
          Case closed, thanks for help.
          • DynaxSC
            Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
            by DynaxSC
            I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
            I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
            Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
            Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
            05-04-2025, 12:08 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
            A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
            by momaka
            More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
            And a shot of the label:...
            01-26-2022, 03:26 AM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
