p4sd - case d5w
  • MXM
    • 430
    • Unknown
    p4sd - case d5w
    hey, this p4sd mobo from another hp d530 sff is giving me the 3 red flash, which according to its manual is the Processor not seated/installed error, of course the proc is seated and installed, and works (tested on other pc) so i was wondering if anyone could point me to which direction should i look for... given this specific error.
    Due to the rush i didnot checked the status i recieved the mobo
    i have also replaced the caps i found blown (not all the caps on the board, just those that looked bad)... if you think i should replace any other specific cap due to this failure, please advise, im up to hear any opinion. I also applied a little heat to the board and i dont know if that may have damaged it, what do you think?...
    I suspect of tracks on the board, or some sort of passive element shortcircuited, maybe an IC.... and nothing seems wrong, like burnt and that, with the board...
    so, whats on your mind? any tip or idea is highly appreciated.
    thanks.
    peace.
    We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
  • seanc
    • Nov 2008
    • 1319
    Re: p4sd - case d5w
    Take pictures of both sides of the board, highlight the capacitor you replaced.
    • MXM
      • 430
      • Unknown
      Re: p4sd - case d5w
      thank you i promise pic for next week, i do not have a cam on me right now and im takin off from today til next wed so not even if i wanted i could post during those days, but i will ASAP.
      Thanks for your reply.
      • MXM
        • 430
        • Unknown
        Re: p4sd - case d5w
        SORRY for the late delay, i really am thru a bunch of stuff around...
        In this i changed the one to the left of the AGP port, the one that reads "16 V"...
        I didnt change any of em here cause accordig to me they look ok...
        I changed these two, 1800uf 6.3v...
        General overview...
        ANY Tip or info is highly appreciated.
        Peace.
        And sorry again for the delay.
        • seanc
          • Nov 2008
          • 1319
          Re: p4sd - case d5w
          You put that white cap in, what is it?
          Are those two blue LTEC 1800uf? Why? Can't you put some Panasonic low ESR caps in?
          • MXM
            • 430
            • Unknown
            Re: p4sd - case d5w
            Thank you again, i am no expert when it comes to caps.
            the white one is a..mm dude the only logo it has is like a rounded-corners triangule with letters "C G E" in it... there was originally a 560uf/4v but since i couldnt find that one i picked the closest i found... 680uf/16v
            yeah the blues are Ltec but they are 1500uf my bad, 6.3v and the reason is because thats what i got and i havent found others, i am very limited when it comes to finding new parts, specially good ones, my bad again :s
            Thanks in advance.
            • seanc
              • Nov 2008
              • 1319
              Re: p4sd - case d5w
              A 680uf 16v replacement is easily available from Panasonic, same for 1500uf, you can use a higher voltage.
              FM, FC, or FK <- best, starting from left to right.
              Edit: Whoa hang on, 560uf, 4v? Sounds like it was a polymer. Replace it with another polymer of the same value, or a Panasonic FM, most likely needs a very low ESR.
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Re: p4sd - case d5w
                yep.. it is in fact a polymer.. got the same board right in front of me (P4SD Rev. 1.07)
                on mine, its a nippon chemicon PS 560uF 4V
                theres another polymer cap on that board.. a Sanyo OSCON SP 6.3V 680uF between the RAM slots and the SATA ports.
                oh and instead of the yellow fujitsu FPCAPs, mine has Sanyo OSCON [no series marking!?] 2.5V 820uF between the Panny FL's in the CPU VRM
                edit: kinda funny.. seems like they put whatever caps were available on those boards. looking at the overview pic, every single cap except the Panasonic FL's in the CPU VRM are different than on mine.
                - VRM in has Nichicon HD instead of Teapo
                - VRM out has sanyo oscon instead of fujitsu fpcap
                - the various 6.3V 1000uF caps on mine are Teapo, on yours they're rubycon
                - the 2 LTecs near the RAM slots are Rubycon MCZ on mine
                - the cap right next to the "P4SD" text is a rubycon MBZ or MCZ on yours (looks like it), and a rubycon ZL on mine..
                strange.. especially since a lot of them differ in both quality and ESR despite being in the same places..
                • MXM
                  • 430
                  • Unknown
                  Re: p4sd - case d5w
                  i dont know if theres any difference between these two, but my boards are P4SD Rev 1.09
                  Thanks.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    Re: p4sd - case d5w
                    sorry for the horrible quality..that's best i could do with my cellphone at 12:45am :P
                    http://bambooz.pytalhost.net/badcaps/P4SD/DSC08263.JPG
                    http://bambooz.pytalhost.net/badcaps/P4SD/DSC08265.JPG
                    edit: oops i forgot. chipset heatsink got replaced by me cause the original one was all bent up and had broken off fins, and a standard s478 retention module added cause i'm using it in a standard µATX tower..
                    • MXM
                      • 430
                      • Unknown
                      Re: p4sd - case d5w
                      yeah i know, i have also realized how different they are, since i got plenty of em, oddly enough this is one of the very very few that has got Rubycon on it, and is that the reason why i chose to try to fix it, since one of the things ive learned from this site is "rubycon are the best"
                      can u explain me how different is the so called polymer caps from the rest of the caps on the board, like does it really make a difference? cause i have never bought caps asking for a polymer but mainly for just caps... u know :S and thats what i get and what im doing is a little list of all the caps and ask for better quality from somewhere faraway else.
                      and those pics look good for a cellphone cam
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • howardc64
                        by howardc64
                        Today, 05:17 PM
                      • Hakuu
                        by Hakuu
                        Hi There,
                        More Details
                        TV Model - LG OLED77G1PUA
                        07-12-2023, 02:37 PM
                      • jb_Bak
                        by jb_Bak
                        CN6401
                        Pin 01 NC
                        Pin 02 NC
                        Pin 03 "BL_ON": 0V
                        Pin 04 "N/C"
                        Pin 05 "STBY 3.3V": 3.5V
                        Pin 06 "GND": N/C
                        Pin 07 "AC_OFF"...
                        09-27-2021, 04:52 PM
