Zotac gtx-750ti 2gb vcore short
  • adelfr2009
    HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
    by adelfr2009
    I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
    After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
    09-28-2025, 10:21 PM
  • jm942
    Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
    by jm942
    My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
    I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
    I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
    I did voltage injection on the cpu with 0.7V and i have a current...
    07-11-2024, 05:11 AM
  • T4H
    RTX 2080 ti (Zotac - triple fan) - No video output / Vcore / Vmem missing
    by T4H
    I have an RTX 2080 ti (Zotac - triple fan) with no video output.
    So far I have measured the following:
    • PS_FBVDD_PH3_SW = 40 ohm to ground (Micron ICs) - Memory should be fine right?
    • 12V power rail present
    • 3.3V power rail present
    • 5V power rail present
    • 1.8V power rail present
    • Vcore power rail missing --> PS_NVVDD_VREF is present. (from uP9512P / U812)
    • Vmem power rail missing --> Not there because Vcore power rail is missing.
    Any idea? I have already tried to flash the BIOS chip (backup got created) - sadly no changes.
    Source: https://www.techp...
    08-19-2023, 08:14 AM
  • tony359
    GTX480 short/vCore issue
    by tony359
    I have a weird issue with a GTX480 I am repairing for fun.
    Originally it would crash Windows when drivers were being installed. I checked with MATS and found a faulty RAM IC. I replaced it, MATS is happy but still the installation fails to install the driver - but no more BSOD.
    While testing I found something weird.
    What I think is the VCORE, is completely shorted. I read 0.4 Ohm to ground. I'm aware that low resistance is normal around a GPU but I don't think 0.4 is ok?
    If I check the inductors and all the mosfets,...
    04-24-2023, 03:15 PM
  • Stephen
    MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
    by Stephen
    I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
    02-06-2025, 12:03 PM
