replacing capacitors on asus striker extreme motherboard
  • Garurumon
    • Mar 2010
    • 12
    can anyone help me on how to do this?
    i recently purchased this board from ebay a while back and only just found out half the capacitors are blown. where can i get replacement parts?
    -Garurumon
    • 31051
    Re: replacing capacitors on asus striker extreme motherboard
    depends what country your in.
    • Garurumon
      • Mar 2010
      • 12
      United kingdom
        • 31051
        farnell.
        • Garurumon
          • Mar 2010
          • 12
          farnell.
          farnell?
            • 31051
            http://uk.farnell.com/
            • Radio Fox
              • Jan 2010
              • 281
              ...or Radio Spares.
              http://uk.rs-online.com/web/
              ________________________________________________
              Invisible airwaves crackle with life
              Bright antennae bristle with the energy
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                whoa!
                iirc that board is built with solid polys.
                pictures please.
                • c_hegge
                  • Sep 2009
                  • 5219
                  kc8adu is right. The caps on that board don't fail, unless the seller has replaced them with lytics.
                  We need some pics before we can say what will work and whether it actually needs new caps.
                  • Garurumon
                    • Mar 2010
                    • 12
                    i cant really tell if they have blown, but from what i know it doesnt POST and the bios chip has been replaced. i was told the caps could have blown but theres no damage to the board
                    image of motherboard:
                    http://i57.photobucket.com/albums/g2...e/DSCF0037.jpg
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Those look to be 100% solids. All I see are fujitsu and UCC, good brands. I think your problem lies elsewhere.
                      What all are you using with this? Ram, cpu, video card, power supply (make+model please,) etc...
                      • Garurumon
                        • Mar 2010
                        • 12
                        Corsair 1GB DDR2 PC2-8500 ram
                        Intel Core2Duo E4300 1.80GHz
                        Inno3D GeForce 9400GT
                        400w ColorsIT power supply
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          The colorsIT worries me, but that computer isn't too power heavy. How old is the psu?
                          Do you have another computer to check the ram in? If not, try booting up the computer without the ram and see if it beeps.
                          • Garurumon
                            • Mar 2010
                            • 12
                            the ram was taken from my main machine, and ive also had the board hooked up to that hardware too
                            specs:
                            iCute ATX Modular 600w
                            Intel Core 2 Duo 2.40GHz
                            Generic PC2-4200 DDR2 2x1GB Ram (inc the corsair stick)
                            ASUS EN9800GT Hybridpower graphics
                            when doing that the LCD poster didnt say anything apart from CPU INIT
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              A lot of people have had the CPU INIT problem with these boards. Check your pins to make sure they aren't bent and make sure the cpu is seated correctly. Also make sure you have a 8pin cpu connector in the 8 pin cpu connector on the motherboard, not just a 4 pin.
                              This is what one guy said on the asus forums about his:
                              1. Pulled out all my ram, and then just put one stick of ram in the ram slot furtherest away from the CPU. 2. Turned on the PC and went into bios. Set the ram voltage to 2.2v (or set it to whatever your memory should run at). 3. Turned off the PC and put all the memory back in again. 4. I removed my CPU heatsink and CPU. I found a little piece of plastic (I assume from the manufacturing process) stuck in between a few pins on the motherboard. I removed it and re-installed the CPU
                              The connector was not properly in and, in fact, it was being bent upwards by the heatpipe - putting strain on the ATX12V mobo connector.
                              • Garurumon
                                • Mar 2010
                                • 12
                                pins are fine, hooked up my 600w psu and firmly plugged in the 8pin cable.
                                CPU INIT + no beeps
                                • seanc
                                  • Nov 2008
                                  • 1319
                                  Try all the RAM slots.
                                  I have a DFI lanparty NF4 SLI board which is very picky about having single sticks of RAM installed in a specific slot for it to POST.
                                  It used to moan at me when I had it in slot 1 that I should put it in slot 2, then I upgraded the BIOS, it wouldn't do anything, thought I'd bricked it. Posted fine in slot 2.
                                  • Garurumon
                                    • Mar 2010
                                    • 12
                                    did that when i first got it, didnt have any effect
                                    • pfrcom
                                      Oldbie
                                      • Jun 2006
                                      • 1230
                                      Is the replacement BIOS chip proven to work on another Striker Extreme ?
                                      What are the markings on top of the BIOS chip itself ?
                                      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        that board is likely still in warrenty through asus.
                                        just call them up and tell them what you have done and go from there.they were easy to deal with when the northbridge died on one of mine.
