Rare problem on MSI Z77A-G41 board when powering up
  • diegito11
    • Jul 2016
    • 94
    • España
    Good afternoon colleagues, I have a problem with a desktop board MSI Z77A-G41 MS-7758 ver.3.1 that I have changed the super IO because it did not start but now I have another case that I can not find out, it turns out that it turns on and I enter bios but just bridging the green wire with ground, from the switch the fan only makes a couple of turns but it does not stop.
    Turning on with the bridge gives me access to bios but when I turn it off it turns on but it does not give a video signal, if I reset bios on the bridge that has the board, when I turn it on again it gives me a bios signal again.
    I have reprogrammed several bios from the official page but I still have the same symptoms and I don't know what it can be, sometimes it has given me 3 short beeps that I think is a memory failure that I have also changed several even new ones without any problem.
    I have boardview but 2.0 and my board is 3.1.
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Rare problem on MSI board when powering up
    This is a bit of a guess but I think you may have a problem with the PCH as this is mainly responsible for correctly handling the reset signals and starting the ATX PSU. I have a similar fault but on a totally different type of board and chipset.
    In my case changing the SIO made no difference. I can get the board to start by bridging the green wire on the 24 pin ATX connector but it seems to boot up in an indeterminate state (sometimes i get it to beep as there is no RAM inserted)
    I don't know if it will help any but here is what is happening with mine. I now suspect PCH but I don't have any board view or schematics for my board so it is very difficult to diagnose.
    https://www.youtube.com/watch?v=MdDFaUiQI-4
    Follow me on YouTube
    Learn Electronics Repair
    • piernov
      • Jan 2016
      • 4439
      • France
      The SIO is what triggers the PSU PS_ON# signal, after receiving SLP_S3# from the PCH. The SIO also monitors the power button, and sends PWRBTN# to the PCH as a response.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Hi piernov
        As both the OP and myself changed the SIO (OK different chip sets but very similar problem) then I thought the PCH would be the next most likely culprit - though I don't have a schematic/board view for my board so it is a bit of a guess
        • piernov
          • Jan 2016
          • 4439
          • France
          Different boards, different set of symptoms, different problems so (usually) different solution. Troubleshooting process is the same though.
          • diegito11
            • Jul 2016
            • 94
            • España
            I have thought about the PCH because when it turns on well with the bridge that I make, the pch tends to get too hot I think, but I wanted to ask to see if someone had happened something similar to it.
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              Re: Rare problem on MSI Z77A-G41 board when powering up
              Does the PCH get hot when you just have 5V Standby?
              • piernov
                • Jan 2016
                • 4439
                • France
                PCH getting hot when turned on and working is normal.
                • Schorsch87
                  • Feb 2013
                  • 55
                  This behaviour leads to a dead pch. I had the same problem with an x58 board from gigabyte.
                  • diegito11
                    • Jul 2016
                    • 94
                    • España
                    Actually I have no signal from slp s3 # in the super IO so the pch is dead, the same thing happens to me with another Z77 motherboard from asrock, I mean to throw the board away.
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      There are a lot of things going on before SLP_S3# comes up.
                      • diegito11
                        • Jul 2016
                        • 94
                        • España
                        hello piernov, can you guide me where to look? or research,? I am not a professional but I am little by little analyzing it and studying what I can.
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • ShadowAi12
                          ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                          by ShadowAi12
                          I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                          • The board enters a "ready to power on" state after plugging in the PSU.
                          • Pressing the power button increases power draw.
                          • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                          Measurements:
                          (taken after pressing the power button, while the board is attempting to start)
                          • H_SKTOOC#
                          06-11-2025, 01:05 PM
                        • PNI E.
                          Dyson v15 problem with the dust detector board
                          by PNI E.
                          Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
                          10-02-2025, 10:18 AM
                        • slimmy182
                          MacBook M1 Pro 14" 2021 A2442 (820-02098) — U2020 getting hot, board not powering on
                          by slimmy182
                          I have a MacBook Pro M1 14” (board 820-02098) with a broken LCD panel (matrix damaged).
                          The board does not power on — when connected to power it draws about 5.1 V / 0.474 A (~2.45 W) and stays at that level, with no fan spin or display activity.
                          Using a thermal camera, I noticed that U2020 heats up to over 70 °C shortly after connecting power.
                          According to the schematic, U2020 is a SN74AVC2T45RSWR (Texas Instruments) 2-bit bidirectional level shifter.
                          There are no visible signs of liquid damage anywhere on the board.
                          Given the broken LCD,...
                          08-15-2025, 02:57 AM
                        • huj3r
                          Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                          by huj3r
                          Hi there!
                          I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                          Photo of the situation after the black shadow dissipates:
                          After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                          I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                          > This indicates HFR Communication error. [ HFR Communication...
                          08-15-2023, 10:55 AM
