How to find the faulty mosfet?
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    Hi everyone.
    I friend asked me to try to fix his gigabyte ga-x99-ud4 motherboard which is not booting. After some probing, it turned out that the CPU power supply is shorted.. but not only vCore, but cpu +12V also ( the "atx +12v x4" connector ).
    Basically almost everything around and under the cpu socket is shorted to ground.
    +12V on the ATX 24pin connector seems to be fine. Indeed nothing on the 24pin connector seems to be shorted.
    For the vCore rail there are 6x IR3550 mosfets and it looks like everything on them is connected in parallel ( except for the PWM pin which goes to the control IC and each mosfet has its own control line ). Unfortunately I couldn't find boardview or schematics for that or similar MB, so can not really trace the other mosfet pins, but the PWM on all 6 mosfets, shows the same resistance readings to ground.
    So, I guess at least one of those mosfets has gone ( as far as I know, that's the only place where +12, vcore and ground meet ), but can not find which one(s). Visually all of them are fine.
    I tried injecting power on the connector, but my bench power supply cannot go higher than 5A@0.5V (2.5W), which doesn't make any difference to the temperature of the mosfets .
    Desoldering the mosfets right now is not an option, because my hobby hot air/soldering station just cannot apply enough heat .
    So any other ideas about how to find the culprit?
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: How to find the faulty mosfet?
    there is a new tool to find it . its on the forums . basically its a very accurate volt meter .
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Here is the tool petehall refers to: https://www.badcaps.net/forum/showthread.php?t=93031
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        @madan1
        Try using an ESR meter to find the shorted FET(s). Remove the CPU first.
        Referring to the attached pic... You probably have an input inductor Lin from ATX_12V to the Drains of the high side FETs
        Consider that Q3 is short and Q1 is good.
        If you use a multimeter on ohms range and measure from the junction of Q3/Q4 to 12V you would see short as Lin is a very low DC resistance
        If you use a multimeter on ohms range and measure from the junction of Q1/Q2 to 12V you would also see short as the path from 12V via Lin - Q3 (short) - L3 - L2 to Q1/Q2 junction is also a very low DC resistance.
        And your mulitimter can't tell you which high side FETs are short.
        Now make the same measurement using an ESR meter. Lin has some impedance and the ESR meter uses 100KHz test signal so you will now see some resistance from 12V to junction Q3/Q4.
        If you now measure from 12V to junction Q1/Q2 you are again measuring the path 12V - Lin - Q3 (short) - L3 -L2 but you will see higher resistance as the ESR meter sees the impedance of all three coils in series (Lin+L3+L2). So you will see the lowest resistance on the shorted FET(s)
        You can apply the same technique from Junction Q1/Q2. Q3/Q4 etc to find any shorted low side FET(s)
        Give that a go and let me know the results
        Follow me on YouTube
        Learn Electronics Repair
        • piernov
          • Jan 2016
          • 4435
          • France
          Remove them one by one, will be done much faster.
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            In the OP he says desoldering the mosfets right now is not an option as is hot air station is not up to the job.
            Quite what he intends to do if he finds a faulty mosfet by other methods, I am not quite sure.
            • madan1
              • Nov 2016
              • 682
              • Bulgaria
              Thanks for the replies.
              No luck for now.
              Well the first thing I got in mind was to remove them one by one until the short is gone, but my soldering station can not handle that amount of thermal mass.
              I tried the ESR* test, but the tester just does not read any esr or capacitance between +12/ground ( two separate tests with probe on the +12 and then on gnd ) and the out, in and gnd terminals on the FETs.
              If used in its default mode, only resistance is detected and again - the values are similar on all fets.
              Then I used frequency generator - 100khz on +12/gnd and expected to see difference on the scope** when probed on the IN,OUT and GND fet terminals ( 200khz-1000khz switching frequency according to the fet datasheet, so I hoped that the filtering would be tuned to something like x00khz ), but again - identical readings on all.
              Now I'm totally out of ideas... probably will pass it to someone with an adequate hot air station to get those little **** out of the board.
              *indeed my ESR tester is one of those https://www.banggood.com/Original-Hi...-p-986954.html
              **diy DSO138
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                @madan1
                Hmm I am a little surprised about the results of the ESR test. I'll deliberately put a short on a motherboard vcore high side mosfet tomorrow (solder a bit of wire D to S) and then try this again myself to see if i can detect which phase has the short
                I'll put the video on my youtube chanel
                My ESR Meter is a different model but I also have one of these on order which looks similar to the one you have but much cheaper
                https://www.aliexpress.com/item/4000...247a4c4dRyTRFv
                I intend to do a video on this $6 tester when it arrives
                  • 30985
                  check resistance between ground and the gate pin on each fet
                  • madan1
                    • Nov 2016
                    • 682
                    • Bulgaria
                    Thanks for the idea.
                    I tested pin5 against gnd and 12v and this time I found an odd one.
                    Pic1 is what I got on 5 of the fets, and pic2 is the reading from FET3.
                    When I got the motherboard I tested all FET pins with multimeter, but I guess it is not good enough for that particular job.
                    By the way, I also tried injecting a more powerful pulse signal on the rail ( and load connected in series with the MB ) and hoped to be able to detect its path with an improvised small antenna connected to a scope... the damn thing rang around the whole board .. I guess the whole ground plate became antenna
                    Then I wanted to try to detect the magnetic field around the conducting path, but don't have small enough ferrous particles on hand.. and am too lazy at the moment to grind some...
                    p.s. Do you think a mainboard would run without one of those vcore FETs? From what I've read, they are there to dephase the ripple and not that much for the power need. Is there feedback from them or some kind of ripple monitoring by the controller? Just curious...
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      @Madan1
                      OK I checked out the method of using an ESR meter to find the high side MosFET short again and I don't understand why it didn't work for you as I have had plenty success with this method but I would be very interested to hear why
                      I made a short(ish) video describing this fault finding technique - if you get time to watch it I would be interested in your feedback
                      https://youtu.be/i8TudEfD2Ao
                      Rich
                      • CapLeaker
                        Leaking Member
                        • 8127
                        not sure if EDS is still making the LeakSeeker 89.
                        • dicky96
                          Sun Seeker
                          • Mar 2017
                          • 1825
                          • Spain
                          That's not a good idea, though I have seen it done on GPUs. Anyway, depending on the VRM controller, it may just shut Vcore down after a second or two if one phase isn't working, or is not working correctly.
                          • dicky96
                            Sun Seeker
                            • Mar 2017
                            • 1825
                            • Spain
                            So I decided to see if the ESR meter technique would also work on a GPU where there is a very low resistance (less than one ohm) from Vcore to Ground
                            Here is the result
                            https://www.youtube.com/watch?v=5cG2aJwNoAw
                            • madan1
                              • Nov 2016
                              • 682
                              • Bulgaria
                              Originally posted by dicky96
                              @Madan1
                              Rich
                              Just finished the video.. could it be that in my case all 3 - Vcore, ground and +15 are shorted ( hi and low phase I guess )?
                              Also, my ESR meter seems to be not working when there is no capacitance ( I'm attaching an image from testing a cap on a board ).
                              100+ us bucks on the fleabay... I guess if someone runs a pc/laptop repair shop is a good investment, but for the hobbyist, who rarely play with such hardware is lil'bit on the expensive side.
                              • kotel studios
                                Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                by kotel studios
                                Finally got time to fix this board up.
                                At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                04-22-2025, 05:08 AM
                              • c_corr
                                Asus P4C800-E VRM issues
                                by c_corr
                                This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
                                This board uses mext ICs and Mosfets in VRM:
                                - ADP3180 PWM controller - in 3 phase mode
                                - ADP3418 as Modfet drivers
                                - High side Mosfets STD38NH02L (from ST)
                                - Low side Mosfets STD90NH02L
                                Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
                                I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
                                02-08-2025, 11:59 PM
                              • Nooy
                                VGA MOSfet permanently shorted and loss of MOSfet pad
                                by Nooy
                                Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                02-14-2024, 02:26 AM
                              • Blastsail
                                Help find compatible MOSFET from Asus FA506 DABXBMBAD0
                                by Blastsail
                                I have a coffee damaged asus laptop with shorted mosfet for vram. Trying to find replacement but I am struggling to. Markings are M3966M and I have attached image of mosfet. Schematics are available which say chip is a QM3966M6 but i am unable to find this chip no matter what combination of letters i put in. I can see there exists an m3966m3 chip but this appears to be the wrong size and markings are different.
                                I have attached schematic as well to help, mosfet is on page 44 of pdf. I do not know where to start to find a compatible mosfet so any help will be greatly appreciated....
                                05-07-2022, 07:35 AM
                              • Jane
                                How do you test MOSFET in laptops ?
                                by Jane
                                I tried to use this method:
                                Testing an N-channel MOSFET:
                                Step 1: Discharge the Gate (turn off the MOSFET)
                                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                Step 2: Charge the Gate (turn on the MOSFET)
                                Now, place the red probe on the Gate (G) and the black probe on the
                                09-27-2024, 03:31 AM
