Coolmax CX400B GI
  • jedwar10
    • Aug 2009
    • 43
    Coolmax CX400B GI
    Just thought I would post some pics if the caps in a CoolMax 400w PSU. They are GI brand which I have never heard of. This Particular PSU just stopped powering up one day no particular reason. Less than 6 months old.
    Pics aren't that great. They are taken with my LG EnV Touch cell phone.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Coolmax CX400B GI
    Sunpro/leadman. Typical crap.
    • c_hegge
      • Sep 2009
      • 5219
      Looks a bit better made than this sun pro.
      https://www.badcaps.net/forum/showpo...2&postcount=36
      • ss627
        Super Member
        • Mar 2008
        • 52
        Looks the same as my 2 broken coolmax cu-500b. I replaced every single cap and mov and it still blows fuses. I havent bothered to troubleshoot beyond that.
          • 31012
          if it's blowing a fuse then it wasnt the caps, more likely the rectifier or primary transistors.
          • jedwar10
            • Aug 2009
            • 43
            I really just posted this for information. I'm not going to attempt to repair it, since it isn't worth the time invested. I think it was purchased for about $25.00.
            I have to convince the boss that cheap PSU's don't save us money.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              http://www.jonnyguru.com/modules.php...=Story&reid=71
              Here's more proof. The first and second to last units are from the same manufacturer of this coolmax. (leadman/sunpro)
              The first one on the second page is the brand you should use most often.
              • SluggerB
                Help with trying to fix phone that is not charging (Pics inside)
                by SluggerB
                I have two TCL A30 phones.
                Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                New Phone: Works fine, bought as a donor board to try and repair Old Phone
                My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                08-12-2024, 08:11 AM
              • keeney123
                new OS on a Sonim XP5s phone
                by keeney123
                To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                05-13-2022, 07:19 PM
              • mikey5791
                Help with Samsung Galaxy J7 Prime phone
                by mikey5791
                Got this smart phone free from a guy who dropped it hard until the lcd display cracked with no seen display.
                Opened it and found the display ribbon cable partly damaged. I charged the phone full in 2 hours time, the led red light turns to green indicate full charge.
                Then i use a usb cable connect the phone to laptop but it only showed as media player with firmware version. Too bad there is no option to check folder.
                Does anyone know any method to check if the phone is working good? Looking forward for any advice and help possible.
                If tested the...
                09-15-2021, 07:54 PM
              • Dannyx
                Cisco IP phone F-up
                by Dannyx
                Good day folks. I had a little f-up over at my new shop today and it made me pretty angry, but at the same time it determined me to try and figure out what could've happened there. This is only going to be a speculative discussion since I don't know the exact layout of our network, hence I don't know what's going on past our room. So:
                The repair shop where I sit is situated in a remote building down the street from the main building. There's a Cisco IP phone in this room, a 7911, like the rest of the company uses. There's obviously some sort of networking going on between the two...
                11-27-2018, 12:39 PM
                Nokia C2-01 RM-721 RM-722 Phone Schematic
                The Nokia C2-01 RM-721 RM-722 was a mobile phone produced by Nokia. The Nokia C2-01 supported 3G and had a 3.2 megapixel back camera. It had a single SIM card. The handset was introduced to the markets in 2011. It replaced its predecessor, the Nokia 2700 classic and Nokia 2730 classic and has improved specifications....
                11-05-2024, 07:40 AM
