I have a Dimension 8400 U7077 board that gives me the solid amber power light, no status lights, and the jet engine fan. My research points me toward bad nichion capacitors, but there is a trillion 470uf nichions on this board and I'm not willing to replace all those. There are some larger nichions, but none on the board are bulging or leaking. Which should I replace? The cap list from the previous 8400 thread does not match any Dimension 8400 board part numbers.
Dimension 8400 (yes I searched)
Tags: None
Re: Dimension 8400 (yes I searched)
Thanks to C-Net's archive, I found this article that more specifically identifies the capacitors as the black and gold-colored low-ESR (equivalent series resistance) aluminum electrolytic cylinders about an inch in length and marked HN(M) and HM(M) on the side with a letter "X" stamped on the top"
http://news.cnet.com/PCs-plagued-by-...3-5942647.html -
Replace ALL Nichicon HM or HN caps with a date codes before 2005. Handle HN/HM caps after 2005 on a case by case basis...some might be bad but are much less likely to be bad. After 2007, I have seen none out of spec.
Date codes are in the form XYYZZ where X is a letter, YY is the 2 digit year and ZZ is the week.
For example, H0945 is on one of the caps in my stash indicating that the cap was made in week 45 of 2009.Comment
You are getting good advice and correct info here.
If you aren't willing to replace them then it's time to scrap the board and build a new system.
.Mann-Made Global Warming.
- Dr Seuss
On the 8400, replace all HM, HN, KZG, KZJ. Other series can generally stay. That board will likely have some 85 degree caps, which can dry out in rare cases. I haven't seen it, but I've heard it happens. It's impossible to say what's where as the manufacturers will use different brand capacitors depending on their stock levels at the time.Last edited by yyonline; 07-24-2011, 10:40 PM.Comment
Yes. Agree.
Those 85C caps.
Intel -sometimes- uses 85C for the small caps since at least socket 370 [PIII].
I know they did it on some socket 775 boards too, and I think they still do it.
It's an issue one needs to at least check for but not supper common.
If the board was in a hot case or has a lot of hours on it then definitely check them.
I posted photos of 85C 4mm & 5mm Nichicons bloated on one each Intel P3 and Intel P4 boards a while ago.
- Dr Seuss
I have a dell 8400 with bad 2200uf 6.3v HN, I found a replacement for this one. Can I replace [100uf 25v HN] with [Rubycon ZLG 100uf 25v 6mm] and I can't find the recommended replacement for [470uf 10v VR]. Forum says replace with [Rubycon MCZ 470uF 16v 8mm] but can't find it.Comment
I think you need to read the 100uF again.
HN series doesn't go up to 25v and would be over-kill for that application.
The small uF caps are for EMI vice Ripple from the PSU.
That said a ZLG will work there even though it's probably a little bit of over-kill too.
A 16v cap would also be fine there BTW. - 16v is a common value in that app.
MCZ is a ridiculous amount of over-kill for a VR which isn't even a low ESR series.
A 470uf 10v VR is rated for 350 mA of Ripple Current.
Any 470uF 6.3v/10v/16v that is rated for that much or more Ripple Current will work.
[10v mobo caps are on 5v or less so a 6.3v cap is fine.]
Please enter your location in your profile. - It saves having to ask.
Where are you buying from?
.Last edited by PCBONEZ; 08-31-2011, 11:00 AM.Mann-Made Global Warming.
- Dr Seuss
Yes, the 100uF 25V is VR(M)
Thank You for your fast reply PCBONEZComment
Nichicon VZ is a direct replacement for VR but they are rated for 105C to VR's 85C.
Chemicon LXZ and Panasonic FC are better rated and usually easy to find.
There are actually a lot of options in that range.
- Dr Seuss
Once again thanks for your free information. I'm getting ready to order them from Badcap.comComment
The VR 100uF is 5mm and BNC only has 6mm
The VR 470uF is 6.3mm and BCN only has 8mm
Will larger diameter caps fit?
If not you need to look at digikey.com or mouser.com - if you are in the USA.
- Dr Seuss
There is only 1 470uF 10v VR that I will have to leave the leads long and put shrink tube on and lay it down.Comment
Give that and what is here these would be what I'd use.
https://www.badcaps.net/store/produc...roducts_id=153
https://www.badcaps.net/store/produc...roducts_id=119
You said you have the others figured out already.
Is that correct or need help with those?
- Dr Seuss
Yes the others are no problem. This is for 2200uf 6.3v HN ---
https://www.badcaps.net/store/produc...products_id=32
I'm all set thanks to PCBONEZ.Comment
I have another dell 8400 with 1 bad cap. The cap has no name, but has gold and black markings, here is whats on it.
4n R(3)
05 degrees C (m) 105 degrees C
820uf - 4v - KZV
the size is about 15mm x 8mm
Can anyone suggest a replacment
ThanksComment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
