Epox 8k9a2+ bad caps
  • Phaz
    • Aug 2005
    all affected caps are the 6.3 2200 microfarad other caps arent affected
    Machine stability is not affected, mbm5 reports my 3.3v rail @ 1.7v
    all suspect caps bulged, some discharge on the top of them
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Epox 8k9a2+ bad caps
    It's probably still unstable. If you run any heavy tasks, then it probably would crash. Also, I had the 3.3V rail be read as 3.1V and 2.8V while using my PC one day and amazingly, was still stable when running a 4-hour loop of 3D Mark 2001 SE! That was just because of the ATX power connector being loose!
    FYI, if you ever come across a PC with the 3.3V (or another rail) reading being majorly low, such as 2.8V, then check the ATX power connector and just push it down and make sure it's clipped. Mine for some reason didn't clip after putting in another processor last August. I was surprised that the ATX power connectors didn't get charred!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Rainbow
      • Aug 2005
      • 1371
      I've got this board for repair. There are GSC (1000uF, 2200uF) and TEAPO (3300uF) caps bulging. There are also GSC 1500uF that look OK but I'll replace them anyway.
      • japlytic
        • Oct 2005
        • 2086
        I'd get those GSC capacitors out first (According to www.gsc-cap.com, their business has been established in Mainland China since 2003... maybe this explains something?).
        Avoid the Nichicon extra low-ESR units... as many of us know, they have been bulging in Optiplex GX270s.
        • Rainbow
          • Aug 2005
          • 1371
          Replaced the 6 3300uF Teapos (connected in parallel) with 4 Kome 4700uF/16V+1 Kome 1000uF/16V, 1000uF GSCs with Kome 1000uF/16V, 2200uF GSCs with Kome 2200uF/16V and finally the still-good-looking 1500uF GSCs with Kome 2200uF/16V too.
          The board had some problems with powering up but then finally powered up and worked. But after a while, it suddenly turned off - but strangely without smell So powered it up again - and it turned off in a couple off seconds again. Next power up attempts were unsuccessful.
          So I traced where the PS_ON# signal from the ATX connector goes - and found a small 8-pin chip - Attansic ATTP1 which had some white substance between its pins. Cleaned it using a toothbrush&alcohol - and the board then powered up and worked fine
          The ATTP1 is over-temperature protection controller and that white substance was probably conductive enough for it to activate.
          • japlytic
            • Oct 2005
            • 2086
            I have never heard about KOME capacitors before... see www.pro-an.com.hk and you will find they have been established in 1992.
            • PeteS in CA
              • Aug 2005
              • 3580
              • USA, Unsure of Planet
              Contamination and small IC pin spacing sucks. Welcome to the wonders of SMT. Don't have shaky hands when probing a SMT IC pin with a DMM probe or scope probe .
              PeteS in CA
              • Rainbow
                • Aug 2005
                • 1371
                That white substance was probably something from a water-cooling system that the owner uses with that board. The ATTP1 chip connects directly to a thermistor or diode so it's very sensitive to resistance changes.
                • Rainbow
                  • Aug 2005
                  • 1371
                  I've measured the capacitance of the bad caps from this board (using a multimeter that can do up to 20uF):
                  GSC 2200uF/10V:
                  12.11uF
                  16.09uF
                  19.40uF
                  >20uF
                  GSC 1000uF/6.3V:
                  16.10uF (bottom of came out)
                  9.33uF
                  5.64uF
                  0.21uF
                  13.90uF
                  0.00uF (748pF )
                  >20uF
                  6.99uF
                  GSC 1500uF/16V - all >20uF (none of them bulged)
                  TEAPO 3300uF/6.3V - all >20uF (including the single bulged one)
                  Summary: GSC is REAL crap. No wonder that the board failed with values like these.
                  • sulbert
                    • Dec 2004
                    • 59
                    Need to recap one of these boards too. The board lying on my desk has Sanyo MV-WX caps instead of 3300uF Teapos so I have a bit less work
                    But I have trouble finding replacement for the 2200uF/10V GSC caps located between the FETs - 10mm is the largest diameter that will fit there but I have only found 12.5mm 10V caps so far (and I think I can't replace them with the 6.3V ones since they seem to be connected to the 5V rail).
                    • Rainbow
                      • Aug 2005
                      • 1371
                      I used 2200uF/16V that have the same diameter as the original GSC and are even lower.
                      • AK0R
                        • Mar 2005
                        • 204
                        Computek (which usually supplies Rubycon MBZ) and Digi-Key (Panasonic FC) both have parts available in 2200uF, 10v, 10mm size. It would be marginal, but acceptable, to use a 6.3v cap on the 5v line.
                        • AK0R
                          • Mar 2005
                          • 204
                          Sulbert,
                          How many do you need? Panasonic lists 0 for their inventory. I need to order some of these for a power supply I'm refurbishing, and will be placing an order with Computek for those and some other caps.
                          • sulbert
                            • Dec 2004
                            • 59
                            Thank you but I already bought 12.5mm Sanyos from a local electronics store (the owner of the board wanted it back ASAP). Looks ugly IMHO but it works.
