ASUS P5GC-MX - No memory, no boot
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 662
    • samsara
    Re: ASUS P5GC-MX - No memory, no boot
    While looking on the backside of the board for a "shortpin" POJP1 (what's a shortpin?), which doesn't appear to exist after lining up the board with the image on Openboardview, to test it's continuity,
    i noticed burned (and possibly shorted) traces
    i haven't cleaned them up yet, just in case there is some way to test if they are creating a fault condition
    On the front side of the board, in the same vicinity, there is the upper and lower mosfets (directly above "0310" on the barcode sticker in the attached photo) who's gates are connected to the POU1 chip.
    These mosfets are responsible for supplying +1.8V_DUAL
    Any thoughts/suggestions as what could be happening here, and what to do?
    • socketa
      Asbelowsoabove
      • Jun 2014
      • 662
      • samsara
      Cleaned up the burned trace
      It's the 3.3V rail - which measures 108 ohms to ground, with the CPU and CMOS battery removed
      There was no short to the adjacent traces - the blackness was the burned lacquer (since the copper is now exposed)
      So the initial fault still remains.
      When i turn on the power, there is 3.3V on the 3.3V rail
      so i noticed this circuitry that changes the 3.3V to 2.5V DAC (whatever that is) and tested there.
      There is 3.3V there but on the other side of the component there is not 2.5V but rather some cycling from what appears to be 100mV to 400mV
      Those two resistors add up to the reading that my meter gives of 180 ohms so they look to be good
      So maybe that "switching diode", D1191, is faulty?
      Or am i barking up the wrong tree?
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        So you get less than 2 Ohms continuity between the 3.3V rail on the ATX power connector and this trace?
        Reason I ask is because I was looking at my P5GC-MX, and my traces are a little different in that area. The one trace that seems like yours appears to be for the 12V rail and goes to the CPU fan.
        Of course, your board is the P5GC-MX/1333, so there can be some differences.
        That said, I checked resistance between the 3.3V rail and ground on my P5GC-MX, and I get about 196 Ohms - this is with RAM, CPU, and CMOS battery, though (but PSU disconnected, of course.)
        Wait, you first said you get 108 Ohms to ground above. I'm guessing that was a typo, and you meant to say 180 Ohms? If so, that also appears to line up better with the resistance on the 3.3V rail on my board (~196 Ohms.)
        Anyways, this missing 2.5V_DAC voltage may or may not be normal. Although.... see below.
        By the looks of the schematic you posted, if there is 3.3V coming to anode of diode D1191, then on the cathode side of D1191 where 2.5V_DAC is, you should get 2.5V. If D1191 was bad (shorted), you should have only seen 82.5 Ohms to ground. Moreover, if D1191 is shorted, 2.5V_DAC should be at 3.3V.
        But I guess this diode could also be leaky and/or just partially-shorted to some random resistance (which I recently found is actually possible while troubleshooting an ATX PSU and finding a leaky/partially-shorted 1N4148 diode.)
        So maybe remove it and check it. That could be the reason why that trace burned up on the 3.3V rail.
        Also, I re-read some of the posts back on page 1 again. In particular, I was interested why there is no 1.8V for the RAM VDDQ rail. As you found correctly, POU1 (an APW7120 PWM controller) is what drives those MOSFETs for the RAM VDDQ. Going by your voltages in post #14, I think pin 7 (OCSET) on the APW7120 controller being at 2.55V may be another flag here.
        In particular, going by the APW7120 datasheet:
        "The OCSET is a dual-function input pin for over-current protection and shutdown control. Connect a resistor (ROCSET) from this pin to the Drain of the low-side MOSFET. This resistor, an internal 40µA current source (IOCSET), and the MOSFET’s on-resistance (RDSON) set the converter over-current trip level (IPEAK) according to the following formula:
        Pulling and holding this pin below 0.15V with an open drain device, with very low parasitic capacitor, shuts down the IC with floating output and also resets the over-current counter. Releasing OCSET pin initiates a
        new soft-start and the converter works again."
        So if pin 7 (OCSET) is held below 0.15V, the IC should be in shut-down state. Your voltage is at 2.55V, so it seems like this is a pass. However, I noticed something on page 4 of the datasheet that I'm not 100% sure about: the parameter for Over-Current Reference. The datasheet says 0.4V is typical (and allowed to vary between 0.37V and 0.43V with temperature changes.) This brings the question: if the voltage drops below 0.4V (but is more than 0.15V), is that how the over-current protection is triggered? ... or is it the other way around? Looking at the application circuit on page 6 of the datasheet, it seems that R5 should be the resistor corresponding to the R_OCSET resistor they talk about in the formula on page 5. And if that's the case, the only logical way I can see how the OCSET circuit works is that an over-current event will cause a larger voltage drop through the lower MOSFET's R_DSON, thus pulling the voltage on one side of R_OCSET lower... and when it goes too low (below 0.4V??), that's when over-current protection should trigger.
        But if that's the case above, then the 2.55V on the OCSET pin you measured should allow the APW7120 to start switching and the 1.8V RAM VDDQ should be present. Or am I misunderstanding something here?
        If I am correct, then that brings the question whether the APW7120 is faulty or not. With that said, perhaps investigate the 2.5V_DAC circuit and see if D1191 is faulty first, as I think that may be easier than trying to source/replace the APW7120. My guess is that you would just have to take out D1191 out of the circuit and check it in both directions to see if it's faulty or not. (And maybe even build a test circuit and see if it functions correctly as a diode by trying to pass 5V through it in both directions to make sure it's not "leaky" in the reverse direction.)
        • socketa
          Asbelowsoabove
          • Jun 2014
          • 662
          • samsara
          Thanks for the reply,
          Yes - 0.1 ohms to be be precise
          Ohms?
          No, there is actually 108 ohms to ground - still an error by me though, as i added up the two resistor values (which are actually not even installed!) which came close to 180 and i dyslexically equated that with 108.
          So, even with those two resistors missing, there is 108 ohms from the 3.3V rail to ground, (or equivalently across the diode, since it's in parallel with the 3.3V rail)
          So i've now removed the switching diode and it appears to test good?
          On diode mode:
          +ve of diode to +ve meter, -ve of diode to -ve of meter = 0.580V for either -ve legs of diode
          Reversing the meter leads gives no reading
          +ve of diode to +ve meter, both -ve legs of diode to -ve of meter = 0.555V
          Now, with meter on voltage selection, connecting 5V to +ve leg of diode, then both -ve legs to meter, and other meter lead to earth, gives 4.85V
          And swapping the wires going to PSU around, gives 0V
          i added a photo of the two omitted resistors (circled in red), the switching diode (orange), and the two capacitors (yellow)
          i'll contemplate the rest of what you said about the PWM Driver
          Maybe something will click, but i doubt it, especially if you are not even sure what's happening there.
          • socketa
            Asbelowsoabove
            • Jun 2014
            • 662
            • samsara
            Finally got a replacement for the switching diode, D1191, and now have the 2.5V on the +2.5V_DAC rail (see schematic on post #22)
            So it really seems like the original switching diode was faulty
            But i still only have "0000" displayed on a PCI post card, and no VCore for the CPU
            And the only voltage that i'm getting on the RAM slots is 3.3V
            Is it necessary to have all of the RAM voltages present before the board starts to POST?
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 662
              • samsara
              #26
              Fixed!
              Finally replaced the APW7120 PWM buck controller, and it now boots.
              Thankyou to those that chipped in.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                #27
                Cool!
                Good to see another motherboard saved from the dump, even if it took 3 years to get there (but hey, you did it on your own, so applause there. )
                I'm surprised to see the PWM controller dead. Those things usually don't die unless a MOSFET does. Very strange. Maybe the previous owner(s) ran it with a really poor quality PSU?
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • trbovan
                  Asus GL731GT Boot loop
                  by trbovan
                  Laptop is a GL731GT with the I7-9750h and GTX1650.
                  Full model number is gl731gt-rb71-cb
                  Serial: (placeholder for when I get home)
                  Board model: G531GT REV. 1.5
                  Issue: Laptop was password protected with admin password. I extracted the Bios with the CH341A and ASprogrammer. I Initially saved the backup. I then scoured the internet for a rom to flash to the chip. I found a file and flashed it. I then read it back to verify and mistakenly over wrote my backup of the original Bios.
                  I assembled and tested anyway. The bios worked, I was able...
                  10-04-2023, 07:27 AM
                • jrodefeld
                  Asus laptop won't boot (no power) - possible bad caps?
                  by jrodefeld
                  I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                  The model:
                  Asus Zenbook Pro Duo UX582L
                  I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                  However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                  09-02-2024, 04:55 PM
                • acata
                  Asus X450LC REV 2.2 can't boot to anything
                  by acata
                  I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                  Power on normally. Boot to bios ok.
                  But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                  10-10-2023, 05:15 AM
                • lukkihapsi
                  Asus Vivobook X515JA Weird Boot Issue
                  by lukkihapsi
                  Asus Vivobook X515JA Laptop
                  Issue :
                  Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                  Tried :
                  Cleaned inside for dust, applied fresh thermal paste. No Change!
                  Removed keyboard, Trackpad, fingerprint sensor. No Change!
                  Removed Internal SSD. No Change!
                  Updated BIOS to latest version. No Change!
                  Removed battery and pressing power button for 1 minute. No Change!
                  Weird Part :
                  Upon turning laptop ON, screen lights up - stays black,
                  I...
                  07-07-2025, 12:07 PM
