SuperMicro Board Issue
  • facecard
    • Jul 2020
    • 7
    Please move post if necessary.
    I have a old PC with a Supermicro P6dgu board. Back in the day it was used as a Netware 4.11 server. It does get power but I don't get any video. I do understand it is old and outdated.
    I did try swapping PSU, graphic cards, etc.. but nothing seems to work for very long. If the video comes up it will go through the POST screen then stop because I don't have any HDs connected to it. There is no consistency. I can't seem to narrow it down to anything specific.
    For all I know it could be the power supply, board, AGP slot, graphics card....it could be any number of them.
    Any suggestions would be appreciated.
    • 20643
    Re: SuperMicro Board Issue
    Post some pictures of the board, especially around the capacitors
    • facecard
      • Jul 2020
      • 7
      Attached is pictures of the board.
      Again, getting video on the screen is hit or miss. Getting either PS/2 or USB ports to work completely is hit or miss.
      Another words getting video up is inconsistent and connecting either mouse and/or keyboard regardless of the port is inconsistent.
      Maybe someone can spot something on the board that is related to everything that is going on whether it is a bad CAP or something with the slots or circuitry.
      If anyone wants to see a close up of something on the board or a different angle then please let me know.
      • brethin
        • Dec 2008
        • 1907
        Hard to help with so little information. No details on CPU GPU or Memory Chips used etc. It's like saying my car won't run and I changed the battery and put new gas in it.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Replace those six caps marked 'nrsy', they should be 1000uF 10v. They are junk. Yes, we do need to know a little more.... CPU(s)? RAM? GPU? Firmware revision?
          I actually still have one of these boards in my retro fleet.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • facecard
            • Jul 2020
            • 7
            @Topcat- Can you tell where on the board where are these CAPS that you are referring to? Are these CAPS bad? What would be the benefit to upgrade or replace them with 1000uf 10v?
            To answer the general questions.
            -PSU is a Powerman FSP 300 (I replaced the original PSU which was the same type)
            -Two PII CPUs (Original ones)
            -One PC100 512 memory (Original one)
            -AGP graphic card
            -Adaptec 1130 scsi card (Original one)
            Back in the late 90s early 2000s, someone had put together (bought all of the parts) for this computer. This computer was used (with all of the original parts stated above) as a Netware 4.11 server. Nothing has been replaced on the board. At the time, my employer was using this computer as a server then decided to decommission it and get rid of it. This computer is 15+ years old.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              They don't need to be 'upgraded', they'll be bad...even without showing it. SM was horrible for using these back in the day. There are 6 of them on your board, the culprits are marked with a red dot...see below:
              The remaining lytics on that board are Santo WG or SE series, and won't be problematic.
              Pull that and throw it in the trash before it fries the board. Those PSU's are horrendous junk!
              Those are neat little controllers utilizing the 'raidport' slot, proprietary to these boards.....just make sure you have the latest firmwares on both the motherboard AND the controller....it'll spare you inventing some new swear words.
              Team : 49813
              Join in!!
              Team Stats
              • facecard
                • Jul 2020
                • 7
                How might I go about replacing the bad CAPS? I don't have the knowledge or resources ie... soldering gun or new CAPS.... to perform the replacement.
                Since you are not a fan of Powerman PSUs then which PSU would you recommend that works with this type of board?
                I am guessing those CAPS are the culprit of my issues with no video and inconsistency?
                • facecard
                  • Jul 2020
                  • 7
                  Without video and use of a keyboard and floppy drive, I can't perform a BIOS or other necessary upgrades.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16956
                    You'll need to find someone who can then. I can do it if you want to send it, I'd recap the entire board....otherwise you'll have to find someone local. You're just pissing in the wind until this is done.
                    Disregard about that, I had powmax in my brain for some reason.... Powerman PSU's aren't the greatest, but they're ok. You'll want to check its caps as well. Just to eliminate the PSU as an issue, try another that's known to be good.
                    Yup. Classic symptom.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • facecard
                      • Jul 2020
                      • 7
                      So, you have your own business of providing this type of service? What will this cost me to send the board and you perform the labor plus parts? Once you recap everything do you completely test the board to make sure it works?
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        https://www.badcaps.net/index.php?pageid=repair_costs
                        Team : 49813
                        Join in!!
                        Team Stats
                          master hoarder
                          • May 2008
                          • 12170
                          • Bulgaria
                          Yeah, I was just about to post, what you got against FSP PSUs?
                          Then it crossed my mind perhaps you were thinking of Powmax, which is indeed only trash-worthy
                          Yep, Powerman / FSP / Sparkle aren't the greatest, but they are usually decent. The older units do indeed use crap caps and often have the tan/brown conductive glue. But once recapped and glue removed, they are pretty reliable PSUs.
                          BTW, the only thing I could find for Powerman FSP 300 was this:
                          https://www.badcaps.net/forum/showth...werman+FSP+300
                          I see crap cap brands in that one, so I concur with TC: check the PSU first and even test the PC with another one, just to confirm problems are not coming from there.
                          And regardless of that, it would still be a good idea to get rid of the NRSY caps and replace them. They are classic crap from the bad caps era. Unlike fine whiskey, these caps won't get better with the years.
                          • Soulzink
                            Samsug washing machine. Power supply DC41-00189a board issue
                            by Soulzink
                            I am trying to fix a samsung washinmachine power supply main board.
                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                            The power supply board reference is the following: DC41-00189a
                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                            04-19-2025, 06:26 AM
                          • Asraf Atb
                            by Asraf Atb
                            01-27-2025, 05:02 PM
                          • notallbad
                            TCL 55RP620K power board issue
                            by notallbad
                            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                            0% p_dim at 1.65v and a_dim at 1v
                            50% p_dim at 3.3v and a_dim at 1.65v
                            100% p_dim at 3.3v and a_dim at 2.88v
                            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                            Leds are 2 rows of 15 6v leds.
                            On inspection of the power board found diode MBR3200 shorted so replaced with...
                            07-12-2025, 05:45 AM
                          • eclectric
                            Sony Bravia KDL-70W850B T-CON board / software update issue
                            by eclectric
                            Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                            In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                            Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                            I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                            05-23-2022, 01:25 AM
