I swiped this board from a failed machine at work and kept it around until i start doing more cap replacement. I've had some success but i'm a newbie at it so -
My board had a few (out of 5) bulging KZG next to the cpu. I'm new to this, so i ordered the closest matching caps i could find at the time. They were identical in size and from what i read on the spec sheets of both caps, they were identical (unless i misread or missed a detail like ripple or something). I replaced all 5 caps with nichicon 3300uf 6.3v. I still was not getting any post or activity video-wise (if i recall correctly, the board was powering on which it was not before) so i did the baking 'trick' (yeah baked the motherboard as a last resort) and now the video is working again. My issue is that it will show the emachine screen, and then shows some vague info and cuts off completely each time. Basically a few seconds after emachine screen posting, it cuts off. My question is did I choose the wrong caps? Nichicon 3300uf 6.3v 105c H0906 is all the info i see on the ones i used (can't remember where i ordered them from). Should i have stuck with replacing with equal KZG caps?
