SMD inductor code X
  • saronno
    • Jan 2012
    • 57
    SMD inductor code X
    I am trying to repair a nvidia gtx 780 and after checking the main rails
    it came out this X inductor (it's named L17) is open. Obviosly, I checked if there was a short and yes, a shorted capacitor (part of the 12V rail filter powering up the phase responsible for the Vcore of the GPU)
    was responsible for the killing of the X inductor.
    So far, so good. But, what about this X code. What is the meaning?
  • saronno
    • Jan 2012
    • 57
    Re: SMD inductor code X
    It's a fuse (why they write L near it .. I don't know) .... but this code X doesn't help a lot in order to find the correct value and type of the little beast.
    Can anyone guess what kind of fuse and hwo many ampere it's the correct value here? The GPU is a GTX 780
    • diif
      • Feb 2014
      • 6978
      • England
      12a
      • saronno
        • Jan 2012
        • 57
        Yep, thank you .... checking some datasheet on littlefuse, I think it's probably the correct value.
        I said probably because the current limit determined by X depend on the type of fuse.
        But this card had a TDP of 250W ... so 8+12 seems reasonable 20x12=240W ... ok, you have not costant current, it powers a switching power regulator, but since it's polyphase you have current drain from a phase almost all the time.
        • saronno
          • Jan 2012
          • 57
          • R_J
            • 9607
            The fuse marking X will be a 12amp, The L17 designation would be for a coil but I suspect a design change or a different manufacture had them install a fuse for better protection.
            • saronno
              • Jan 2012
              • 57
              In effect usually there is a coil in other card of the same type but different brand.
              12A, so be it.
              Thanks.
              PS: I don't think is necessary to replace the shorted cap I blown (to find the short) ... there are plenty of them in parallel they are there just for filtering.
                LCD LED TV Service Menu Codes
                ALL LCD LED TV SERVICE MENU CODES
                Service Menu Code with Board Name
                China Universal Board / Jumper Board Service Menu Code
                Changhong Ruba Service Menu Code
                Ecostar LED TV Service Menu Code
                Orient LED TV Service Menu Code
                Haier LED TV Service Menu Code
                TCL LED TV Service Menu Code
                Samsung LED TV Service Menu Code
                LG LED TV Service Menu Code
                Videocon LED TV Service Menu Code
                Supra LED TV Service Menu Code
                Toshiba LED TV Service Menu Code
                Symphony LED TV Service Menu Code
                Veste/ LED TV Service Menu Code...
                10-31-2024, 03:58 AM
              • Curtissimo
                HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                by Curtissimo
                Hi everyone.
                I have a HP Elitebook 850 G8.
                Serial: 5CG2324XM0
                ProdID 6L8D5EC#ABA
                It has a Winbond W25Q256JVEN Chip.
                I need to remove BIOS Password.
                I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                Attached my dump.
                I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                What I did:...
                08-26-2025, 04:42 AM
              • Sorrow1
                Intergraph TDZ 2000 mainboard post code 2F/2E
                by Sorrow1
                I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
                It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
                When I recorded video of POST card and played it in slow...
                01-03-2024, 04:13 AM
              • Bartoloni
                Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
                by Bartoloni
                Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
                everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
                there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
                replaced the capacitor (330) and the inductor (R15) without any change
                any idea? very thank you!
                input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
                12-09-2024, 12:42 PM
              • DynaxSC
                MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                by DynaxSC
                Hi Folks
                I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                09-29-2024, 04:27 PM
