MS-7592 Powers on then off. No post
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I have this MS-7592 motherboard
    It powers on for about 10 seconds then powers off again, it then powers back on and repeats the cycle
    It came with a Core 2 quad -I tried another Core 2 quad, both stop with POST code E1 then it shuts down after a few seconds and restarts.
    If I remove the RAM it beeps as you would expect - then shuts down as described above and restarts.
    I also tried a Pentium D that is compatible with the motherboard. Same thing apart from it sits on code 98 for a few seconds, then goes to F1 and shuts down....
    There are some DIP switches marked OC-SW and it's fairly obvious what that is for - but strangely there is no mention of the switches anywhere in the manual from msi site. Does anyone know the correct default setting?
    PS I did have a CPU cooler on.
    Follow me on YouTube
    Learn Electronics Repair
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Re: MS-7592 Powers on then off. No post
    Check the CPU socket, voltages and make sure the board is straight, in you have an external programer, reflash the bios.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      I already checked the CPU socket pins when I tried some different processors. It looks fine.
      I checked Vram yesterday - it was good 1.84V
      I was just going to check Vcore. But first I flexed the board slightly near the CPU socket with the heat sink unbolted but sitting on the CPU, and hey presto it boots!.... hmmm.
      I then tightened the screws on the heat sink and it still boots everytime. I've tried it numerous times and left it running for some time and it seems to be stable. I have it set to optomised default settings in the BIOS
      Rich
      • Aliencomputres
        • Aug 2019
        • 208
        • România
        check the bios battery or replace it.
        • lowpost99@gmail.com
          Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
          by lowpost99@gmail.com
          I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
          09-03-2024, 02:57 PM
        • platinumsteel
          hp labtop 15-db008 Powers On then Shuts Off
          by platinumsteel
          Hi guys have an issue with a friends labtop that has no signs of liquid damage.They said it just stopped turning on.When i press the power button it turns on normally like 35-500millamp draw and it posts and i have picture. But like after 4 seconds after it posts an image it shuts off completely.If i press power button again same thing happens. Did all basic troubleshooting with the motherboard like fresh thermal paste with it completely out the chasis with battery disconnected. Thermal camera shows these two mosfets heating up more than anything else when i press the power button.I have provided...
          10-28-2023, 10:51 AM
        • survivalbloke
          Dell laptop powers up with kb backlight about 10 seconds, then shuts off
          by survivalbloke
          I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
          Any ideas?
          01-08-2024, 12:12 PM
        • Prosatanosz
          Asus B85M-GAMER no hdmi output and random restarts
          by Prosatanosz
          Hi!
          Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
          10-19-2024, 05:27 AM
        • huzo
          HP Omen shuts down when loading OS
          by huzo
          The model is 15ec-1061nm
          Board number is DAG3EDMB8D0​
          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
          10-29-2024, 12:05 AM
