Transistor identification
  • ageman
    • Oct 2015
    • 45
    • united kingdom
    Hi I am looking for some help trying to identify an NPN transistor. It is marked TCDL 83-92. Please see attached photo. Any help would be appreciated
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Transistor identification
    maybe in house number .can you find a parts list for the unit ?
    • ageman
      • Oct 2015
      • 45
      • united kingdom
      Hi Petehall
      no cannot find any information on the unit
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        what is the unit ? are there anymore transistors same number ? if so you could at least work out the pin out .
        • ageman
          • Oct 2015
          • 45
          • united kingdom
          Hi pete hall. It is a led ballast unit for an emergency light. There is another transistor marked the same the pin out is as follows:1
          pin No
          1 Emitter
          2 Collector
          3 base
            • 31012
            do you have a component tester?
            • ageman
              • Oct 2015
              • 45
              • united kingdom
              Yes I have component tester. Details on the attached photo
              Cheers Adrian
                • 31012
                so does the board contain anymore of those transistors - ones that work?
                • ageman
                  • Oct 2015
                  • 45
                  • united kingdom
                  Hi
                  yes this is the one that is shown on the component tester
                  Regards
                  Adrian
                    • 31012
                    well if you know the spec, what's the problem?
                    or just stick an NPN ZTX seies in there - thoes can handle serious power.
                    • ageman
                      • Oct 2015
                      • 45
                      • united kingdom
                      I was struggling to find something similar to replace it with.
                      Regards
                      Adrian
                        • 31012
                        any idea on the kind of voltage it has to handle?
                        maybe a ztx450 would work - but you need to bend the leads a bit.
