Epox EP-8RDA+ mobo
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Epox EP-8RDA+ mobo
    Hi
    This is an nVidia nForce 2 chipset.
    Recapped this mobo and it was working...
    Recently powered up again and having problems with memory.
    I established there was a problem loading Linux Live CDs, Hirens
    Test CD and such like.
    Have tried three different known good DIMMs.
    MemTest86+ v2.11, it is reporting errors irrespective of test selected.
    Suspect this may be a VDIMM block issue, then again.. perhaps not
    However, in the BIOS all the voltages report ok
    The mobo POSTS ok but cannot load anything into memory given
    the issue above
    Is this symptomatic of a VDIMM block failure?
    I haven't had a chance to pull the mobo (yet)
    Would like to sound out the views/opinins of members.
  • lucky13
    • Aug 2007
    • 412
    Re: Epox EP-8RDA+ mobo
    Did you recap around the dimm sockets? If not, can you see the brand of the cap?
    Do you have any pictures to show us?
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • hs5424
      Dynacord powermate 1600 block diagram.
      by hs5424
      Hi All,
      I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
      The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
      07-31-2025, 01:35 PM
    • Cerberuska
      Mobo MSI B550-A PRO password popup
      by Cerberuska
      Hello guys,
      I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
      BIOS I updated to last one.
      any suggestions?
      And same thing for two different 5600G, and yes, MoBo supposed to support it.
      Thank you...
      11-10-2024, 01:23 PM
    • mrsith
      Dell G3 17 3779 - no display after mobo replacement
      by mrsith
      Hi guys,
      I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
      Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
      04-30-2023, 05:11 AM
    • Ibod
      Corsair cx600 psu & ASRock B450Pro4 mobo wont start
      by Ibod
      HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
      With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
      Not sure where to go from here ?
      Is the PSU at fault or is the mobo causing the problem
      Look forward to any help :-)
      If I plug the 24...
      02-08-2023, 11:00 AM
