gigbyte h61m s2pv 2.2
  • harounHD
    • Feb 2017
    • 46
    • Algérie
    hello guys i have a gigbyte h61m s2pv 2.2
    restarting by itself without showing any picture
    i reflashed the bios chip
    i checked on voltage near ram
    there is a mosfet who has 12 v on gate
    but this 12 v is coming and going fast
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    Re: gigbyte h61m s2pv 2.2
    Probably shorted MOSFET in the CPU phase.
    Place black on gate and test res on both pins for each MOSFET. Ruled out a dud FET on a H55M-S2V.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
      master hoarder
      • May 2008
      • 12175
      Shorted MOSFET typically trips the PSU into lockout. So I don't think that would be the problem here.
      Would try all the usual easy stuff first: minimal hardware, known good PSU + RAM + CPU, test all memory slots individually one at a time, CMOS reset + new battery, flex board near CPU socket, and so on. If none of these help, then start measuring voltages to possibly get a clue what might be going on. Sometimes, voltages at certain rails simply won't show up due to other hardware not working (i.e. if for example the CPU doesn't detect properly or the RAM, the mobo may signal the system to halt / not ready state, which could turn off some of the voltage rails... and hence why you might not see a rail come up.) So just keep that in mind before concluding that since a voltage is not present on certain rail that a MOSFET is bad. In many cases, it won't be.
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        Not always. My H55M-S2V would simply power on for 2 seconds then stop and repeat the cycle.
        Later found out two of the VRM fets were kill (there was visible soot on both of them, and also both drain and source beeped when using continuity mode)
        Replaced them and life is sweet now.
        Main rig:
        Gigabyte B75M-D3H
        16GB DDR3-1600
        Delux MG760 case
        • ayooon_2010
          • Sep 2015
          • 33
          • cairo
          shoerted mosfet mother turn on few second and stop
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            What happens if you remove the BIOS chip and try to boot the board? Does it power up and stay up (fan keeps spinning)?
            Follow me on YouTube
            Learn Electronics Repair
            • shaon_kof
              • Feb 2014
              • 41
              • Bangladesh
              It seems your Vcore IC is not getting VRMPWRGD singal. You may remove DQ19 transistor near the vcore ic ISL95836. Hope it will fix the problem.
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
              • irfan karatela
                MOSFET no voltage at gate Quanta G7HA DAG7HAMB8EO
                by irfan karatela
                I'm working on a HP Pavilion Laptop Model 15-eh1508sa that is missing 19v. I've looked at the schematics and want to know what conditions the ISL9238C checks before it enables the gate for MOSFETs PQ8200 and PQ8201,
                I havent found any shorts on the board.
                I get 19v at +PRWSRC but around 1.7v at the Drain of PQ8201(+vin)
                On Page 82 of the attachment. Link to schematic - https://www.badcaps.net/forum/troubl...ilion-laptop-p...
                01-20-2025, 07:15 PM
              • redbaron1007
                Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                by redbaron1007
                I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                09-09-2025, 11:10 AM
              • tofik
                MOSFET equivalent K8A60DA
                by tofik
                Hello guys,
                I have a shorted MOSFET K8A60DA with the following characteristics:
                Type Designator: TK8A60DA
                Marking Code: K8A60DA
                Type of Transistor: MOSFET
                Type of Control Channel: N -Channel
                Maximum Power Dissipation (Pd): 45 W
                Maximum Drain-Source Voltage |Vds|: 600 V
                Maximum Gate-Source Voltage |Vgs|: 30 V
                Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                Maximum Drain Current |Id|: 7.5 A
                Maximum Junction Temperature (Tj): 150 °C
                Total Gate Charge (Qg): 20 nC
                Rise Time (tr): 25 nS
                Drain-Source
                07-19-2023, 05:18 AM
              • MicroSMD Lab
                by MicroSMD Lab
                I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                01-10-2024, 06:36 AM
