Blown cap on ADSL line in Netgear DG384PN
  • FlibblE
    • Jul 2009
    Please help me to identify what capacitors I need to get to replace the two that have blown in my router after lightning the other night. After the storm the rest of the router seems to be functioning ok, it just can't seem to detect an ADSL signal on the line (orange flashing light). I have tried a friend's router and it does see the signal.
    I have taken the router apart and the two series caps on the adsl line have the casing blown off! I have checked the coil with a meter and it seems like it is unaffected.
    The capacitors are red in colour with lead spacing of about 10mm, and have an AR symbol with 683K and 630V. I guess that this is 68nF rated at 630V, but I'm not sure what a suitable replacement would be - I have been unable to find anything that I think might match on rs or farnell (I'm in the UK).
    Thanks in advance for your time.
    Seimon
  • Wizard
    • Mar 2008
    • 2296
    Re: Blown cap on ADSL line in Netgear DG384PN
    Too risky. The IC are also damaged from the lightning. Invest in another modem.
    Yesterday, I just declared a 50" sony LCD rear proj write off due to lightning fried wires everywhere, scorch marks everywhere including SMPS board.
    Cheers, Wizard
    • FlibblE
      • Jul 2009
      Thanks for your reply Wizard, 50" tv? Ouch - sounds expensive
      There doesn't seem to be any scorches on my router though and everything else seems to power up and work fine, so I thought I could try a couple of new 30p caps before shelling out £80 on a new router; if it doesn't work I haven't lost much right?
      I've taken a pic of the caps in question:
      Thanks again,
      Seimon
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        maube the caps took the hit instead of the ic. that will happen with power supplies a lot.
        sigpic
        (Insert witty quote here)
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          oooh i see teapo
          are there any big eletrolytics on there? if so, might want to fix those too since teapo will fail without visible signs somtimes
          sigpic
          • FlibblE
            • Jul 2009
            There are only a few electrolytics on there, but on close inspection one of them does seem to have a bulging top! Thanks for the heads up on that. I'll try and replace them when I do the others.
            Any ideas what type the blown red ones are though? Film, multilayer ceramic, polystyrene? There's so much choice, and I don't know enough to know what I can successfully replace them with. I figure they are there to block the DC on the line; do I need to stick to 63nF and 630V (which I can't find anywhere) or will a different rating do? Any pointers, please?!
            Cheers,
            Seimon
            • sofTest
              • Aug 2008
              • 361
              I'm not 100 % sure, but I think you are looking for 0.068uF 630V Metallized Polyester Film capacitors. At least, they can be found at DigiKey.
              Be a mensch
              • FlibblE
                • Jul 2009
                Thanks sofTest,
                I've ordered some VISHAY BC COMPONENTS #2222 338 20683 from Farnell. I'll see how I get on with them, then I'll dig around for some replacement electrolytics.
                Thanks everyone for your comments,
                Cheers,
                Seimon
                  master hoarder
                  • May 2008
                  • 12175
                  I doubt those Metallized Polyester Film capacitors are the cause since they rarely die.
                  If there's one bulged electrolytic cap, however, it means that all of them are probably going bad. Just replace all of the electrolytic caps and that should solve your problem. They need to be 105C low-esr rated, however. Just look at the original caps (what brand are they and what series) and post their info here, then we will guide you to a suitable replacement of low-esr caps.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    no, the film caps got all burned up. yes, replace all teapos
                    sigpic
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5038
                      • New Zealand
                      It probably can't detect a signal because of the exploded capacitors, replace them and you might be fine
                      If the thing actually gets line sync back after that you should be good to go, just replace all the teapos too
                      But I assume you can acess the web interface etc and know that the CPU etc is all working fine? Because if that is not the case then it's probably not be worth it
                      If you do resurrect it, go and get a lightning filter too
                      -David VanHorn
                      • severach
                        • Aug 2007
                        • 1055
                        Lightning does not come in and go out on the same line or come in one line and stop. It goes in one line and out the other. Most likely it came in on the power line and went out on the phone line. All parts from here to there are in danger and just one fused transistor and it's toast. If you fix it buy a lottery ticket.
                        Do go get a lightning arrestor. These do arrest lightning unlike the surge suppressors you have now which do not for multiple reasons. You can get the universal kind that adapt to any box or you can get arrestors integrated into a standard size breaker.
                        sig files are for morons
                        • Wizard
                          • Mar 2008
                          • 2296
                          Yes, this Sony 50" is around 4 grand or so when new in 2005. Now I think it paid for. Too bad.
                          I had to give up on other Sony 27" CRT TV. I think micro is semi-damaged even I can bring up menu and play with. But no video or tuner. Tuner is working because it has own seperation circuit built in for video and R and L audio but jungle IC is not outputting them at all even I can bring menu up (micro outputs stuff on RGB wiring to the jungle. In turn jungle IC outputs it to the CRT. Still, I don't get audio and video.
                          video/audio switching circuits works as I can see this switch correctly with scope.
                          I can get micro but jungle IC is NLA. :P This is KV-27S42.
                          Even as a experiment, swapped EEPROM (correct part but incorrect firmware) and still got same problem.
                          Cheers, Wizard
                          Cheers, Wizard
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Cheers, Wizard
                            Cheers, Wizard
                            wrong thread
                            sigpic
                            • ay_erdi
                              Netgear R7500 Router Dead
                              by ay_erdi
                              Hi everybody,
                              My router netgear R7500 is dead.There are four burnt components inside.Can you help me identify?
                              VR8-U17-U78...
                              02-16-2024, 10:58 AM
                            • double_DD
                              Why does my ISP router hate my "homemade" power supply??
                              by double_DD
                              It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                              So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                              For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                              07-12-2025, 03:09 AM
                            • EasyGoing1
                              UPNP, "Standards" and hardware that implements it
                              by EasyGoing1
                              I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                              One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                              So I decided to implement UPNP...
                              07-16-2022, 07:12 PM
                            • cmlewis89
                              LG 47LB5DF blown power supply board
                              by cmlewis89
                              Hi folks,
                              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                              09-03-2024, 07:50 PM
                            • cubytus
                              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                              by cubytus
                              Hi to all,
                              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                              01-10-2024, 01:26 AM
