GA-H77-DS3H RAM problem
  • playman
    • Jan 2011
    • 252
    This started when I woke up and was going to use the PC, but it was turned off.
    I turned it on and it would not post, just restart loop.
    After trial and errors I found out that it would boot with 2gb RAM stick and only 1x 2gb.
    There was 16gb RAM in it when it broke down.
    I've tried all the slots with different rams 8gb 4gb 2gb 2x8gb 2x4gb and 2x2gb, just endless restart loop.
    Tried installing new win10 on to it and I can't finish the installation as it restarts as it seems it gets at certain degrees.
    Any one knows what's going on? no visible damage on the motherboard.
    I know it's not the newest motherboard but I have 16gb RAM and i7 3770k so I would hate to throw it away.
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: GA-H77-DS3H RAM problem
    this is tricky cuz the cpu, board, ram or maybe all three could be faulty. is that 2gb stick which works the only mem stick that works? what happens if u try another 1x2gb stick or 1x4gb stick or 1x8gb stick?
    • playman
      • Jan 2011
      • 252
      All 2gb I had worked, 1x4gb and 1x8gb do not work.
      I switched the 3770k for 3570k almost the same problem, 2gb work with the 3570k.
      if I try any other higher RAM's it starts up, fans blow for 15-20sec with no other action then restarts, gives me one beep and shows BIOS for 2 secs then restarts again.
      • playman
        • Jan 2011
        • 252
        Any one?
        • RJARRRPCGP
          • Jul 2004
          • 6304
          I suspect a bad cap somewhere. That symptom is just like the normal thing I get with my Gigabyte GA-F2A88X-D3HP motherboard, when the PSU was unplugged and discharged, then plugged back in the wall.
          It always bleeps once then recycles once when I turn it on for the first time after I plugged the PSU back in.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • playman
            • Jan 2011
            • 252
            That board has all solid caps so no easy way spotting the bad ones, could you point out what caps to test?
            Is there any reason to test the SMD ceramic ones?
            I've uploaded two pics of the board, and also giving a link to high res pictures.
            https://drive.google.com/drive/folde...3M?usp=sharing
            • RJARRRPCGP
              • Jul 2004
              • 6304
              I don't know which one I suspect needs to be charged to avoid the "double-boot" thing that Gigabyte motherboards are known for. (at least the later AMD platforms)
              Every time it gets unplugged (or a blackout) for any reason, it will double-boot on the first switch-on.
              Arc A770 16 GB
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Unlikely.
                They are all solid polymers. Not that solid caps can't fail. But I really doubt it that there would be any.
                To playman: did you try reseting CMOS settings (i.e. pull CMOS battery and disconnect PSU and/or set jumpers to "clear CMOS" position, if there is one?) If not, do that first. Then try the larger memory sticks. It could be that the board is failing to detect their timings properly.
                If the above procedure doesn't work, try booting with the 2GB module and set all RAM timings and clocks manually. You should look up the model number on each of your RAM sticks and see what timings and clocks it is meant to do, then configure that with the 2 GB module that allows the PC to POST. Once you do that, see if the higher capacity modules will work both with and without the 2 GB module.
                If that fails, use the 2 GB module only and run MEMTEST on the board. If it detects errors, there may be something wrong either with the VRM that supplies power to the RAM or perhaps the CPU socket pins and/or BGA.
                Let us know what you find when you do the above procedures.
                • boulakhsoum85
                  • Apr 2019
                  • maroc
                  Originally posted by momaka
                  Unlikely.
                  • playman
                    • Jan 2011
                    • 252
                    Unlikely.
                    I got the board up and running, I tried all those things with no luck.
                    It was not until I flashed the BIOS I was able to use 16gb RAM again, somehow it managed to get itself corrupted.
                    But the restart did not stop, it was somehow connected to the onboard graphics, as I put in a graphics card it stopped restarting and everything is back to normal
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Well, good to hear you got it running again!
                      So looks like there were multiple issues, then (i.e. BIOS and onboard GPU.) That said, I suppose this goes to show how sometimes you just have to try all kinds of different things when troubleshooting a board in order to get to the bottom of the issue(s).
                      I too, have seen boards where the BIOS went corrupt by itself and needed reflashing. It's just strange that only the RAM detection got messed up. (Perhaps whatever RAM timings/tables there were in the BIOS was the only thing that got corrupt?) As for the bad onboard GPU... since for this motherboard / CPU type, any onboard GPU is on the CPU. Thus, I wonder if the CPU is starting to go bad (unlikely) or if it's just a socket issue (bad pins or perhaps CPU socket BGA going bad.)
                      • theone111
                        by theone111
                        3. Problem: TV shuts down
                        07-22-2024, 10:36 AM
                      • Zeonalbasta
                        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                        by Zeonalbasta
                        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                        09-13-2024, 01:17 PM
                      • shakib200
                        Hp 840 G3 Restarts Problem
                        by shakib200
                        HP 840 G3 On and Off problem. All voltages on coil present but only 130 mA load. AMD Graphic chip is slightly warm. Is it graphic chip faulty? In this model loads for display will be 300mA to 400mA. Suddenly it takes 100 mA or 130 mA loads. Tried new bios and same condition. When load becomes 130 mA graphic chip becomes hot. Is it possible to convert it to non-graphic?
                        10-29-2023, 04:03 AM
                      • Gibon378
                        Problem with stopping audio and video for no reason
                        by Gibon378
                        PC Specs:
                        • CPU: Ryzen 5 1600
                        • GPU: GTX 1080 Palit JetStream
                        • MOBO: ASRock ab350 PRO4
                        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                        • PSU: XFX 650W (don't remember what model)
                        • OS SSD: ADATA SP920
                        • OS: Windows 10 21H2
                        Problem description:
                        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                        11-19-2022, 09:41 AM
                      • perzyk23
                        Lenovo T580 - LCD Panel problem - error 0288
                        by perzyk23
                        Good morning,
                        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                        10-25-2024, 12:42 AM
