emac board bad caps
  • traderbob
    • May 2009
    • 3
    emac board bad caps
    hi im new to this forum so excuse me if im in the wrong place posting this but i have an emac board with buldging/ leaking caps. they are 1800uf and 6.3v 105c. they are 10x16mm in size. cant find the exact replacements so my question is can i replace these with 2200uf 6.3 capacitors and if so what effect will it have. this is a customers mac and i dont want to screw it up
  • Toasty
    • Jul 2007
    • 4171
    Re: emac board bad caps
    emac or iMac? Which model?
    Need the brand and series of the old caps and how many. You can't replace just one in those banks of caps. Where on the mobo are they located?
    Pics are always helpful.
    Toast
    veritas odium parit
    • traderbob
      • May 2009
      • 3
      its an emac im not sure which model as i dont have the casing to hand the bad caps on board are michicon 1800uf 6.3v 10x16 mm and they are circled in pic (8 of them) the other caps u see arnt buldging and are different rating. the powerboard ones su' scon and 2 of them are 3300uf 10v 13mm x25mm another 3 are 1200uf 10v 10mmx20mm. i have marked out where one of each of the power board capicitors where but i had removed them to measure their size. i hope this is enougth info
      • Toasty
        • Jul 2007
        • 4171
        Completely recap the system. Just because they aren't bulging, does not mean they are good.
        In the first pic, the small metal cans in the lower left may be excluded from recap, at this time.
        All those that are similar to the ones you have circled/marked need to be replaced.
        Please provide brand (Nichicon, Su'scon) and series -a 2 or 3 letter code near temperature rating- of the remaining caps so proper replacement reference can be made.
        So far you have referenced 13 of them. In your pics I see at least 11 more and perhaps some that are hidden from view.
        Toast
        veritas odium parit
        • traderbob
          • May 2009
          • 3
          ryt m8 sorry bout the delay been busy...nichicon ones are 8x h4108 and 5x h0427 the su'scon ones do not have a model number the 1200uf 10v have 0345(V) near the tempeture rating the 3300uf 10v 0405(v) the others are in 1's- 2200uf 16v 0407(V), 1500uf 16v 0408(V),1000uf 16v 0405(V),1200uf 35v 0405(V), 680uf 35v 0405(V), and 1200uf 35v 0405(V).
          • Toasty
            • Jul 2007
            • 4171
            The numbers you gave {i.e.-0408(V)} are the manufacture date codes and the (V) marking usually refers to the tolerance rating, but I do not see a "V" code on the chart I have. There should be a 2 or 3 LETTER code near the temp marking.
            You should be okay replacing the 1800uF caps with the 2200uF ones. The six together are likely in the same "bank". You'll be changing the overall capacitance from 10,800uF to 13,200, a 22% increase.
            I would absolutely replace those Su'scon's. The date code appears to come right in the middle of the problem times for caps.
            You should be able to get exact replacements for all of these caps from Panasonic, Rubycon, NCC/UCC, or Nichicon.
            Where are you located?
            Toast
            veritas odium parit
            • deckart
              • Sep 2009
              • 67
              Hi Toasty!,yeah back in the UK,getting 1800 6.3v is getting nigh on impossibe.Lead times with RS are 4-5 months!.I am replacing these with the 2200 version but wonder if it would be better to replace with 10v 1800 as it has the same capacitance and size of the originals and the voltage increase should not affect stability,but I would bow to your opinion on this!.
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • black6host
                Replacement caps for Samson Resolv studio monitor 65A Amp board.
                by black6host
                Good day!
                I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                I'm going to replace the caps and I'll be the first...
                02-06-2024, 08:22 PM
              • Noodneek
                Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                by Noodneek
                My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                08-30-2024, 12:52 PM
