Shorted Mosfet due to measurement
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Dear technicians,
    When I measure SMD Mosfets on Laptop mainboards, I face shorted Mosfets sometimes. But I think it might be possible that I made some of them shorted by my measurements. Specifically, I measure resistance between pins of Mosfet while power is being applied to the mosfet and the mainboard. Is that possible this measurement make mosfet shorted?
    For example: I measured 91 ohms between gate and source of a Mosfet while the mainboard was powered on. The next time I powered on that mainboard, I measured 0 ohm between gate and source of the same Mosfet. So, I think I made it shorted.
    note: I measure Mosfets using my multimeter either in Diode mode or in Resistance mode.
    thanks
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Shorted Mosfet due to measurement
    resistance tests should be done with power off .
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      at the time of power off, the mosfet showed high resistance between source and gate. But at the time of power on, the mosfet showed about 91 ohms between source and gate. So I needed resistance at the time of power on to check the mosfet.
      Is this method wrong?
      Is 91 ohms between source and gate a sign of being shorted when powered on? or is it normal?
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        measure volts with power on .
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          It was a P-channel Mosfet PQ25 model: AO4433
          on laptop mainboard: Sony MBX204
          described in Page 54 of the attached schematics.
          When powered on:
          on source: 19.58v
          on gate: 19.31v
          on drain: first 19v then goes to 16v after 1 second.
          between gate and source: 91 Ohms , after a number of shutdowns/restarts went to 0 ohm
          between gate and drain: I forgot to measure
          between source and drain: 0 Ohms
          Resistance when powered off:
          between gate and source: 110 kOhms
          between gate and drain: 55 kOhms
          between source and drain: 50 kOhms
          Diode mode measurement when powered off:
          between gate and source: 2.8 v
          between gate and drain: 2.9 v
          between source and drain: 0L one way and 0.5v the other way
          no other voltage rail exists on the mainboard except the 19v rail.
          what do you think about this strange Mosfet?
          has my measurement made this mosfet shorted between gate and source?
          • diif
            • Feb 2014
            • 6978
            • England
            Yes checking resistance with power on will short components. It's just the same as bridging the component with piece of wire.
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              only real test you can do with a meter is see if shorted... or if turns on and off there is a good chance its good if it does both things .
              saying that i have always found bad ones shorted or blown to pieces ..
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                You can't measure resistance when there's another circuit powering it. This is not to mention that when measuring in-circuit there are parallel paths, and that parallel path will cause your measurements to go wonky. Just think of the second power source when powered up, that's another short that power can go through, *really* throwing off your measurement.
                BTW 19V from gate to source is nearing or exceeds the voltage limit of most MOSFETs. MOSFETs are typically clamped at 15V or so, some much less, to prevent permanent gate damage. Then again I'm not exactly sure how you're measuring voltage there. Perhaps an oscilloscope trace of the pins would tell you more information than a multimeter - if you have one.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Yes, this method wrong. NEVER measure resistance with the power turned ON. (And sorry to say it directly like that. I don't mean to offend you or anyone else.)
                  Measuring resistance with the power turned On can not only damage your board but also can be very dangerous if you are working with line voltages (i.e. relatively high voltages and currents), especially if you are using a cheaper multimeter (they can blow up and easily cause fire).
                  Please be careful.
                  To check MOSFETs correctly, use resistance or diode check ONLY with the power OFF *and* all batteries removed from the device. In addition to that, when checking resistance in devices with high-voltage caps, first always make sure those capacitors are discharged. Again, this is to prevent you from blowing more parts up and for your own safety, too.
                  • caspian
                    • Oct 2015
                    • 1589
                    • Laptop
                    Thanks for the replies. I need help of electronics technicians sometimes. I hope I help you back in some laptop repair.
                    there is about 0.3V between gate and source.
                    there is 19.31v on gate and 19.58v on source. Thus, this p-channel Mosfet should become off and shows infinite resistance from source to drain. But It does not and passes voltage from source to drain. Do you think it is faulty although it shows good Diode mode measurement when powered off?
                    • caspian
                      • Oct 2015
                      • 1589
                      • Laptop
                      When I power a laptop off, I have to start measurement as soon as possible. How long do laptop capacitors hold the power after powering off?
                      note: Laptop mainboards contain mainly SMD ceramic capacitors and also a few SMD tantalum capacitors too.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        You may have other circuits causing a voltage to be sent. At 0.3V it should be subthreshold and should be mostly 'off', maybe some leakage depending on the transistor. The drain should be mostly floating and follow whatever voltage other devices are pulling it.
                        Sine it's an apparently high side p-channel, what is it powering, if it's shorted, it should be constantly powering whatever it's controlling -- is this the case?
                        If it's not shorted out of circuit, the mosfet isn't shorted. You should be able to tell leakage through it out of circuit too, S-D should be virtually infinite resistance when G is connected to S. G should also be infinite resistance to the other pins too when out of circuit - you can't measure this in circuit as the parallel circuit elements tend to dominate the measurement.
                        Why would you need to start measurement soon after poweroff? Heat dependency? Most capacitors discharge fairly quickly, just takes seconds or so as the LEDs turn off fairly quickly ... ???
                        • caspian
                          • Oct 2015
                          • 1589
                          • Laptop
                          During laptop testing, I have to repeat the process of "restarting and measurement" in a fast way, because lots of points may be required to measure on the mainboard. Thus, I can not wait after a restart for more than a few seconds.
                          I finally figured out PQ25 is probably not faulty and some other component of the mainboard pushes the 19v on the drain of PQ25 down to 16v.
                          This was the most strange laptop I ever faced. I want to replace the entire mainboard because it took too long to repair.
                          A very cute discovery on this mainboard: when I connect the battery to the laptop while the AC adapter is connected, I measure a variable voltage on the drain of PQ25 that periodically changes between 12v and 16v similar to a sine wave.
                          • chestercc
                            Alienware M18x Shorted CPU Mosfet
                            by chestercc
                            I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
                            I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
                            Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
                            07-16-2022, 06:05 AM
                          • mat2k
                            iMac 2017 PSU - shorted PFC mosfet
                            by mat2k
                            I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
                            There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
                            03-13-2025, 11:31 AM
                          • daemon123
                            MSI GTX-980ti shorted MOSFET on memory rail
                            by daemon123
                            Hi All,
                            I have this MSI GTX-980ti Gaming Golden Edition. It had shorted mosfet on memory. Replaced the shorted i.e. Q47 PK616BA with 4C09N and the card ran fine for a month. Then suddenly again the same problem. This time when i replace it 4C09N or with replacement PK616BA (Aliexpress) it gets shorted. As soon as turn on the PC the PSU shuts down and the same mosfet Q47 gets short.
                            What should be the next step. Kindly guide.
                            The board view files for this gpu is available and attached. https://www.badcaps.net/forum/showthread.php?p=1237952...
                            05-10-2023, 11:05 AM
                          • tofik
                            MOSFET equivalent K8A60DA
                            by tofik
                            Hello guys,
                            I have a shorted MOSFET K8A60DA with the following characteristics:
                            Type Designator: TK8A60DA
                            Marking Code: K8A60DA
                            Type of Transistor: MOSFET
                            Type of Control Channel: N -Channel
                            Maximum Power Dissipation (Pd): 45 W
                            Maximum Drain-Source Voltage |Vds|: 600 V
                            Maximum Gate-Source Voltage |Vgs|: 30 V
                            Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                            Maximum Drain Current |Id|: 7.5 A
                            Maximum Junction Temperature (Tj): 150 °C
                            Total Gate Charge (Qg): 20 nC
                            Rise Time (tr): 25 nS
                            Drain-Source
                            07-19-2023, 05:18 AM
                          • ktmmotocross
                            MSI Katana 17 MS-15851 no power after shorted forst DC mosfet /BQ24780S/
                            by ktmmotocross
                            Hello.
                            Have this MSI Katana 17 MS-15851 that work only on battery with adapter and have first DC mosfet shorted. After replace not work without battery. On charger DC+ get power only for few seconds and it goes down...
                            01-09-2025, 08:45 AM
