Bad Caps Or Stability Problem
  • krazykev64
    • Feb 2009
    • 49
    Re: Bad Caps Or Stability Problem
    $30000 LOL: have a look at the enclosed pic and go to http://www.maplin.co.uk/module.aspx?moduleno=98829
    • gdement
      • Jan 2007
      • 690
      Do you have good voltages in the BIOS health monitor?
      Those testers sometimes show a bad PSU, but they're too simple to prove if one is good. It could be operating out of spec without failing the tester. The health monitor doesn't prove it either, but it's something else to check.
      I can understand not wanting to buy stuff randomly, but if you have other good PSUs around it would be worth trying a swap.
      Load is apparently a factor since it's passing memtest but failing under a GUI.
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        The problem with those little guys is that they are not the most accurate, and they don't tell you how bad or good your power supply is, just if its bad or good.
        • krazykev64
          • Feb 2009
          • 49
          GOOD OR BAD? i have finally removed the cover from the 350Watt PSU (Tsunami KYP-350ATXN P4) to check the caps. there is one cap that i cannot be too sure about. it has a very slight bulge and had a small amount of brown crap on the top. it is possible that the crap on the top could have been dust as it virtually fell off. the make of the offending cap is JEE. There are other makes that i can see in the unit which are UNITE and HE?? There is also some that have no names but are black and marked LOW ESR IM0410. I have enclosed a picture of the offending cap which is the largest one in the picture
          • Harvey
            • Apr 2007
            • 264
            BAD. Showing classic symptoms of a faulty capacitor. Chance are if one has failed all the caps will want changing... or, as is probably easier and cheaper - get a new PSU.
            • linuxguru
              • Apr 2005
              • 1564
              #26
              JEE/Rulycon, Unite and Low.ESR are all bad caps that must be replaced regardless of whether they're bulging or leaking.
              • krazykev64
                • Feb 2009
                • 49
                #27
                no wonder the tsunami cases are only around £25 inc PSU. LMFAO
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  They don't even tell you bad or good.
                  They CAN'T tell you it's good in real conditions.
                  - They don't put enough load on it to know what voltages will be in a system.
                  They also can't tell you if it's bad in some cases.
                  - DC voltages could be dead-on but ripple 10x what it's allowed to be and those things wouldn't know.
                  They only tell you DC voltage is good -> with no load.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Yup, Time to break out the soldering iron or seek a new PSU.
                    - Dr Seuss
                    • bulkchart32
                      i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
                      by bulkchart32
                      i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
                      06-16-2025, 03:09 AM
                    • kahlil88
                      AOpen MX36LE-UN which replacement caps?
                      by kahlil88
                      Just got a computer with this board and ALL of the Lelon RXA caps have failed. Having trouble finding datasheets to match against potential replacements. The caps in question are 7x 1500uf 6.3V 10x20 and 11x 1000uf 6.3V 8x12. Open to replacing with polymers as long as it works.
                      10-23-2025, 03:14 PM
                    • dclass-pro
                      Hp DAOP5FMB6A0 blink caps/lock problem
                      by dclass-pro
                      Hi guys, I have an HP model 15s-eq1040nl main DAOP5FMB6A0 REV:A with a caps/lock 5 long 3 short led flashing problem, I tried to remove the battery and program a new bios and when I restarted it immediately worked correctly, the pc turned on and loaded the operating system.
                      As soon as I turned off the pc and connected the battery, the problem reappeared... caps/lock 5 long 3 short led flashing again!
                      the battery was dead, i charged it and it works fine, but the pc won't turn on again.
                      What do you recommend me? Do I have to redo the bios or is there anything else to check?...
                      05-08-2023, 12:46 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
