Netgear R6300v2
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Netgear R6300v2
    Originally posted by Gorrillasnot
    I'm not sure exaxtly where to test voltages at, but at the 330uF 16v cap, near the power plug, I get 12v when plugged in and power button off. It drops to 11.7v when power button is on while bricked and 11.6v when powered on and not bricked.
    These voltages seem about right?
    Well, nothing you can tell without a scope anyways.
    Unfortunately, it appears there are a lot of buck-type regulators (anywhere where you see a coil) instead of linear ones. Linear regs are usually easy to test, as you have an input and an output to test voltages. For the buck-type regulators, you really need a scope to see the ripple/noise they are putting out, because if there's anything to go "partially" bad with those, it would be excessive noise/ripple on the output.
    An easier route might be to install parallel ceramic capacitors with all of the buck-regulators' output ceramic capacitors (all of the groups of ceramic capacitors in the upper-left corner of this picture.)
    • Longbow
      • Jun 2011
      • 623
      Re: Netgear R6300v2
      The link to the NVRAM chip tells you which pins do what. These things don't have a unique reset pin, but are reset via serial data commands. Don't worry with the chip, unless you have found that heating/cooling the chip itself reproduces the problem. The thing to check if possible is the main micro. If that thing is a BGA then forget it unless you have a schematic. Locate the various regulators on the board and check the voltages. A failing filter on these regulated lines can cause erratic power up behavior, you can be sure. But that doesn't mean it HAS to be a filter capacitor. Go ahead. Check them with your ESR meter.
      I'm guessing the wall wort provides 12v d.c. or more, so there are probably 12v, 5v and 3.3 volt regulators on board. Some selective freezing might help you zero in on the problem. On something like this you need a healthy dose of luck. Beyond finding a bad filter cap or loose connection, they are way too complex to get into the component level. Then there is the whole issue of re-flowing the board.
      Is it plugged in?
      • Gorrillasnot
        • Dec 2013
        • 316
        Re: Netgear R6300v2
        Thanks for the info guys.
        Unfortunately I don't have a scope or ESR meter, or the skills to use them for that matter.
        It would be nice if they would make routers like TVs with voltage testing points labeled on the board.
        I replaced the 1 capacitor down by the power connector (is this the main filter cap?) and it didn't change anything.
        I've tried heating the chips and board with a paint stripper gun on low settings which also didn't help..actually made the router completely dead (no lights at all) until it cooled off a bit and have also tried putting it in the freezer over night (I know not a good idea..condensation) which made no difference.
        I couldn't find the package type of the CPU (Broadcom BCM4708A0) but I would bet it is BGA..I did try heating the crap out of the heatsink on top of the CPU, with my paint stripper gun, and letting it cool back to room temperature in hopes of "reflowing" it but it didn't help.
        I know it would take special tools and skill to reball it (not worth it).
        I'll probably poke around at the various regulators I can spot and hopefully stumble onto the problem..in the meantime I have it placed in a semi permanent location running flawlessly (as long as i dont power cycle/powerloss) as a client bridge.
        thanks again guys
        • ay_erdi
          Netgear R7500 Router Dead
          by ay_erdi
          Hi everybody,
          My router netgear R7500 is dead.There are four burnt components inside.Can you help me identify?
          VR8-U17-U78...
          02-16-2024, 10:58 AM
        • double_DD
          Why does my ISP router hate my "homemade" power supply??
          by double_DD
          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
          07-12-2025, 03:09 AM
        • EasyGoing1
          UPNP, "Standards" and hardware that implements it
          by EasyGoing1
          I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
          One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
          So I decided to implement UPNP...
          07-16-2022, 07:12 PM
        • gripa
          looking for netgear WN2500RP schematic
          by gripa
          I am looking for a schematic of the netgear WN2500RP repeater.
          best regards
          12-17-2024, 12:39 PM
        • shadow666
          Router Xiaomi M4A Gigabit
          by shadow666
          hello
          i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
          Mi Router 4A Gigabit Edition
          ROM CHIP is 16 MB
          i attached picture of motherboard​...
          11-30-2024, 03:49 PM
