MSI B75MA-E33 (MS-7808) and W25Q128BV BIOS
  • piernov
    • Jan 2016
    • 4435
    • France
    This is the second time I need to flash the BIOS on my board and I also had to do it one time on a friend's (same model, same batch since I ordered 2).
    My friend's board was acting up and most of the time would boot only after a CMOS reset. After flashing the BIOS everything was working again (except that Windows was crashing but it's probably not related).
    In my case, no matter how many CMOS reset I did, it would only boot after several attempts (more than 10 or 20), otherwise it was only showing a black screen and rebooting randomly. After flashing the BIOS, everything was OK.
    A while after, the computer was dropped while it was being moved. It was not working anymore and only boot looping before showing anything on the screen. After plugging in a POST diagnostic card, I pinpointed the problem to the RAM, it was rebooting at POST code 55 (RAM not detected) or shortly after (related to RAM). I obviously tried different sticks and none worked. I reflowed all the RAM slot solder joints, and it booted again.
    Today, after a blackout, the computer did not boot (same symptoms as when I had to flash the BIOS). Last week I had a few cases where it didn't boot the first time, and before the blackout it had been running for 3 days. However it had me really confused because the POST card was showing code 32 most of the times (related to RAM) so I thought I had another RAM issue. And after trying a few different sticks it booted… Well, it was only a coincidence because after shutting it down, it didn't want to boot again. After several attemps, I was finally able to get in the BIOS. I made a dump of the current BIOS, and, strangely enough, it was getting really slow after 32% (coincidence again…). I downloaded the exact same version (1.7) and the MD5 didn't match, but that's not relevant since the downloaded file isn't a full raw dump apparently. I flashed it, and it was back in working order. I tried to dump the BIOS again and this time it went very smoothly.
    I don't know why the BIOS ROM would fail, but it does. I don't know if it's a board issue or a SPI ROM issue, but now whenever I see one of those I'll remember this case and try to flash the BIOS.
    TL;DR: watch out for BIOS corruptions on this board or this chip, it happens.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: MSI B75MA-E33 (MS-7808) and W25Q128BV BIOS
    could be a bad spi flash.
    try a new one
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • q2v5
      Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
      by q2v5
      Lenovo T480s
      Model 20L8-S3TE00
      Board ET481-U10
      Chip MX25L12873F
      Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
      2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
      The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
      08-15-2024, 10:40 PM
    • Neddsme
      Bios partially corrupted somehow and now warm boot doesn't work which is critical
      by Neddsme
      Hie.
      I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
      Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
      I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
      I managed to run Windows troubleshooting and...
      02-04-2022, 05:57 AM
    • Max029
      Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
      by Max029
      I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
      I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
      TY,
      08-18-2024, 08:28 PM
    • Vesko356
      by Vesko356
      08-11-2023, 03:27 AM
