MSI B75MA-E33 (MS-7808) and W25Q128BV BIOS
  • piernov
    • Jan 2016
    • 4439
    • France
    This is the second time I need to flash the BIOS on my board and I also had to do it one time on a friend's (same model, same batch since I ordered 2).
    My friend's board was acting up and most of the time would boot only after a CMOS reset. After flashing the BIOS everything was working again (except that Windows was crashing but it's probably not related).
    In my case, no matter how many CMOS reset I did, it would only boot after several attempts (more than 10 or 20), otherwise it was only showing a black screen and rebooting randomly. After flashing the BIOS, everything was OK.
    A while after, the computer was dropped while it was being moved. It was not working anymore and only boot looping before showing anything on the screen. After plugging in a POST diagnostic card, I pinpointed the problem to the RAM, it was rebooting at POST code 55 (RAM not detected) or shortly after (related to RAM). I obviously tried different sticks and none worked. I reflowed all the RAM slot solder joints, and it booted again.
    Today, after a blackout, the computer did not boot (same symptoms as when I had to flash the BIOS). Last week I had a few cases where it didn't boot the first time, and before the blackout it had been running for 3 days. However it had me really confused because the POST card was showing code 32 most of the times (related to RAM) so I thought I had another RAM issue. And after trying a few different sticks it booted… Well, it was only a coincidence because after shutting it down, it didn't want to boot again. After several attemps, I was finally able to get in the BIOS. I made a dump of the current BIOS, and, strangely enough, it was getting really slow after 32% (coincidence again…). I downloaded the exact same version (1.7) and the MD5 didn't match, but that's not relevant since the downloaded file isn't a full raw dump apparently. I flashed it, and it was back in working order. I tried to dump the BIOS again and this time it went very smoothly.
    I don't know why the BIOS ROM would fail, but it does. I don't know if it's a board issue or a SPI ROM issue, but now whenever I see one of those I'll remember this case and try to flash the BIOS.
    TL;DR: watch out for BIOS corruptions on this board or this chip, it happens.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: MSI B75MA-E33 (MS-7808) and W25Q128BV BIOS
    could be a bad spi flash.
    try a new one
    • kenkaniff
      HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
      by kenkaniff
      Product Name: HP Pro x360 Fortis 11-inch G9
      System BIOS: U94 Ver.01.08.00 10/06/2023
      Serial Number: 5CG31946F5
      SKU Number: 85W05EC#AK8
      Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
      This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
      I needed to remove bios password...
      10-01-2025, 04:32 AM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • q2v5
      Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
      by q2v5
      Lenovo T480s
      Model 20L8-S3TE00
      Board ET481-U10
      Chip MX25L12873F
      Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
      2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
      The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
      08-15-2024, 10:40 PM
    • Max029
      Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
      by Max029
      I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
      I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
      TY,
      08-18-2024, 08:28 PM
    • 0xx
      2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
      by 0xx
      Hi folks,
      My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
      What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
      I assumed that Windows Update was interrupted due to closing...
      09-14-2025, 03:46 PM
