Gx620 No Post
  • smarterzippo
    • Feb 2009
    • 7
    Gx620 No Post
    hi to all
    this is my 1st time here, hope someone can help.
    I've a dell gx620 sff which was all good until i pulled the VGA cable from the monitor, the instant i did this the cpu started fast clicking sounds and the the fan went crazy,
    Now after a hard shutdown i have the same noises and nothing else the mobo will not do a post and i have a solid amber light on the power button!
    I've tryed a know good psu, and tryed my cpu in an other machine so its def the mobo.
    firstly can pulling the monitor lead do this? and how?
    and
    secondly can i repair the mobo?
    any help very much appreciated.
    Jon
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Gx620 No Post
    You mean you unplugged the monitor cable from the computer while it was running? It shouldn't do anything to the computer in that case, unless you shorted some pins when you pulled out the cable.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: Gx620 No Post
      Monitors Are Not Hot Swap.
      Mann-Made Global Warming.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: Gx620 No Post
        Onboard video comes from the main chipset.
        If you do not have an add-in video card you may have killed the motherboard's main chipset by way of a voltage spike.
        - Dr Seuss
        • smarterzippo
          • Feb 2009
          • 7
          Re: Gx620 No Post
          yess i pulled the cable while she was running,
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: Gx620 No Post
            Oops!
            The outlook isn't good.
            Couple things to try to see if there is any life there:
            Reset the CMOS. Should be a jumper somewhere to do that.
            [Have it unplugged from AC when you do this.]
            You might try an add-in video card to see if you get any display at all.
            Inspect board for any small parts that look fried, cracked, burned.
            - Dr Seuss
            • smarterzippo
              • Feb 2009
              • 7
              Re: Gx620 No Post
              Originally posted by PCBONEZ
              Oops!
              yea i have tried resetting the cmos using the jumper. and cant see any obvious components which are fried, its not looking good. !
              • midibob
                • Nov 2008
                • 285
                Re: Gx620 No Post
                Hi Jon,
                With all the 620's I've repaired so far that is the original fault, fan goes full blast with the orange led. Now it could just be coincidence that it failed when you unplugged the monitor although I must admit it does seem unlikely.
                Anyway,
                Usually I have found on these boards that one or both of the 820uF caps has vented (the ones under the hard disk) but not always. On all the boards there were quite a few of the 220uF caps that had gone high ESR around that area and some even o/cct! Once replaced the boards work OK again so might be worth investigating. I change these as a matter of course along with the 820's.
                Checkout the GX620 thread a bit further down.
                Good luck
                Bob
                • smarterzippo
                  • Feb 2009
                  • 7
                  Re: Gx620 No Post
                  Originally posted by midibob
                  Hi Jon,
                  Anyway,
                  Good luck
                  Bob
                  hey midibob
                  cheers for the info i was looking at the thread you mention is this the same for the sff 620's as i can't seam to locate the 820's
                  • midibob
                    • Nov 2008
                    • 285
                    Re: Gx620 No Post
                    I hope we're talking about the same board? I did attach a picture in the other thread so let me know if it's not the one you're talking about. Better still post one of yours.
                    Cheers
                    Bob
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Re: Gx620 No Post
                      then my video card must have exploded like, 70 times by now, because I just unhook my computer from my monitor to plug in my 360, and I've had no troubles.
                      • smarterzippo
                        • Feb 2009
                        • 7
                        Re: Gx620 No Post
                        Cheers
                        Bob
                        here is the pic of my gx620 sff mobo
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          Re: Gx620 No Post
                          BTX layout, like most new dells.
                          Is it me or are those rubycons and OScons?
                          • smarterzippo
                            • Feb 2009
                            • 7
                            Re: Gx620 No Post
                            yes to oscons
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Re: Gx620 No Post
                              You've been lucky.
                              One of these times it will blow something out.
                              You'll be a happy camper that day.
                              - Dr Seuss
                              • Wizard
                                • Mar 2008
                                • 2296
                                Re: Gx620 No Post
                                I plug hot on the VGA port. DVI as well but I usually do not, since the DVI and HDMI utilize the HDCP and best kept connected till powered off.
                                Cheers, Wizard
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Re: Gx620 No Post
                                  VGA uses DCC for configuration and it's not Hot-swappable.
                                  Go ahead and burn out your gear.
                                  I really don't care.
                                  - Dr Seuss
                                  • smarterzippo
                                    • Feb 2009
                                    • 7
                                    Re: Gx620 No Post
                                    Right so we've come to the conclusion that pulling the vga can kill the mobo- we'll most of us....--!
                                    wot has actually fried and is it due for the trash can??
                                    cheers jon
                                    • midibob
                                      • Nov 2008
                                      • 285
                                      Re: Gx620 No Post
                                      A different board indeed. You'll have to excuse me as I just thought the boards I knew were SFF, at my age even the bigger ones look pretty small to me
                                      As I haven't worked on these then I'll stand by the more knowledgeable comments of the other contributors.
                                      As these boards are probably not so old then there may not be a caps problem but if it were me I'd still be looking at those smaller caps clustered around the middle especially if they're only 85c ones as in the larger boards.
                                      Might be worth checking with an ESR meter (out of circuit) as you've got nothing to lose.
                                      Good luck
                                      Bob
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Re: Gx620 No Post
                                        GX620 comes in SFF and USFF.
                                        USFF = Ultra Small Form Factor.
                                        If it's like earlier series then:
                                        USFF has an external power brick
                                        SFF has an internal power supply
                                        - Dr Seuss
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • wattage
                                          by wattage
                                          Hello Badcaps Community,
                                          07-13-2025, 04:41 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          Things I tried
                                          06-22-2024, 04:44 PM
                                          Wise Wing F199 19'' LCD monitor - recapped
                                          by momaka
                                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                          When I saw the Craigslist post, I wasn't...
                                          08-24-2020, 10:58 AM
