MSI 770T-C45 unstable
  • alindumitru46
    • Aug 2015
    • 255
    • Romania
    After long time I come back with the same old problems.
    The mobo has a unstable behavior: with PCI-e videocards cannot boot (1 long 2 short beeps) or boots extremly rare. I put an very old PCI native videocard and now the mobo starts with fewer power-on issues.
    I met some issues with all DDR slots used, however I use 1 o 2 blsck slots of RAM when I tested the mobo.
    Like I said here and to the next post of @momaka: https://www.badcaps.net/forum/showpo...6&postcount=16, I changed the PSU with one very solid (Corsair VX450 powered by Seasonic platform), and I re-verified the entire number of mosfets.
    There are 2 identical NIKOS P75ND2LDG mosfets (Q49 and Q47, in the DDR respectively chipset area) that give continuity, drawed in the photo.
    There is my search for a replacement:http://alltransistors.com/mosfet/crs...TO220AB&page=0
    Do you have additional advices?
    Thanks.
  • alindumitru46
    • Aug 2015
    • 255
    • Romania
    Re: MSI 770T-C45 unstable
    Of course, great haste makes great waste...
    The mosfets are NIKOS P75ND02LDG and the list of replacement is
    http://alltransistors.com/mosfet/crs...007&caps=TO252
    • cpt.charlie
      • Sep 2013
      • 270
      • Spain
      I don't think those fets are shorted, when you have a short, the PSU will shut down immediately.
      Check voltages and contacts at pci-e.
      • alindumitru46
        • Aug 2015
        • 255
        • Romania
        Before opening this discussion I washed carefully with isopropillic alcohol
        all the ports, including PCI-e, by fine spraying followed by fine brushing.
        With voltages... it's a little harder
        • jazzie366
          • May 2016
          • 304
          This depends on how dramatic the short is. You can have a shorted mobo fet, if it's only a 6 ohm short, that'll draw a measly 2A from the PSU, the chip will light up red until the resistance rises and the mobo shuts down from a fault. However this could be a high resistance short, meaning it might only be dissipating 120mA of current, it'll get hot, but that's about it aside from mobo instability.
          Popcorn.
          • alindumitru46
            • Aug 2015
            • 255
            • Romania
            When the mobo boot, I can run a live Linux for hours...
            I do not know anything about mosfets behavior in load, especially if they are out of specification.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              A MOSFET is either good or bad. When bad, the motherboard won't work at all. As such, intermittent issues are never caused by bad FETs.
              You might want to move the video card around in the PCI-E slot. Sometimes a marginal connector will cause the video card to not get detected. Cleaning the slot may not always fix it. I have a finicky 939Dual-SATA2 that sometimes won't detect video cards on PCI-E. Fooled me quite a few times that I had dead GPUs when the motherboard was the issue the whole time.
              The ATI 770 NB/chipset may also have BGA issues. I thought ATI made reliable chipsets, but apparently not.
              • alindumitru46
                • Aug 2015
                • 255
                • Romania
                I cleaned with a brush and isopropillic alcohol the mobo, already ...
                Today I managed to power on the mobo on first attempt, and right now the prime5 runs for more than 1h and 30min and will run until it crashes...
                LE: @momaka, I posted without seeing your message
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4952
                  • New Zealand
                  I had intermittent boot problems on an MSI DKA790GX board, turned out the buck converter controllers for the NB and DRAM power supplies were bad.
                  -David VanHorn
                  • alindumitru46
                    • Aug 2015
                    • 255
                    • Romania
                    Last night I finally decided to give a reboot and the board, of course, does not boot
                    Right now, after 12hours, the board runs fine .
                    @Agent24, can you be more explicit with these the buck converter controllers?
                    Where are they, how can I test / measure / check?
                    Thank you !
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4952
                      • New Zealand
                      https://www.badcaps.net/forum/showthread.php?t=42510
                      They may be different for your board, they may not even be the problem. But if you can get the schematic you might be able to follow a similar troubleshooting approach.
                      -David VanHorn
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        Reading through that thread again, I wouldn't call the issues there intermittent. More like you had a motherboard that did not boot at all and you got it to boot by replacing a bunch of parts.
                        When a motherboard boots and POSTs successfully only sometimes, that's an intermittent issue, as is the case with the O/Ps.
                        • cpt.charlie
                          • Sep 2013
                          • 270
                          • Spain
                          Maybe a bad solder joint or even a BGA problem.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4952
                            • New Zealand
                            I seem to recall that before starting that thread and repair, the board might have worked again once or twice before dying completely. But I guess ultimately you are right. By the time I was seriously working on it, the whole thing was pretty dead.
                            Still, I can imagine it's plausible for a failing voltage rail to cause intermittent POST issues?
                            -David VanHorn
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              I would go for failing northbridge BGA.
                              A working TV? How boring!
                              • alindumitru46
                                • Aug 2015
                                • 255
                                • Romania
                                Trying a heating gun for "basic" reflow can be a solution ?!
                                Or is like a rubbing the wooden leg ?
                                • alindumitru46
                                  • Aug 2015
                                  • 255
                                  • Romania
                                  But why Q49 and Q47 give continuity if there can be a northbridge issue?!
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    Continuity as in a reading of zero, or continuity as in low voltage drop but enough to trigger the beeper? If it's the latter, it's not a short circuit, just the resistance of the circuit fed by those MOSFETs. If you really had a short the board wouldn't power up at all.
                                    You can try using a heat gun and some flux, just be careful not to overheat it, and you should start by heating the underside of the board. A basic temperature probe is a very good idea. Lead-free reflow profiles you can find on the internet. Desktop boards tend to hold up better after reflow than laptop ones as the overall temperatures are lower and there is room for cooling improvements.
                                    Or you can send it this way if you wish a pro to have a go at it. If you just want a reflow it's gonna be cheap, i promise.
                                    • alindumitru46
                                      • Aug 2015
                                      • 255
                                      • Romania
                                      Nice
                                      • BlackScreen_22
                                        Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                        by BlackScreen_22
                                        Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                        Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                        I had no problems connecting mosfets and capacitors,...
                                        08-27-2024, 12:46 PM
                                      • kotel studios
                                        Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                        by kotel studios
                                        Finally got time to fix this board up.
                                        At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                        Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                        04-22-2025, 05:08 AM
                                      • flerre
                                        Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                        by flerre
                                        Hi!
                                        Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                        No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                        So, could I safely assume all of these 3 mosfets are...
                                        03-13-2022, 12:14 PM
                                      • NanoTesting
                                        Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
                                        by NanoTesting
                                        I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
                                        With charger it turns on, fan spins but gives no image.
                                        Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
                                        Reflashed BIOS, same problem.
                                        Replaced both main mosfets.
                                        Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
                                        10-30-2024, 10:48 PM
                                      • c_corr
                                        Asus P4C800-E VRM issues
                                        by c_corr
                                        This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
                                        This board uses mext ICs and Mosfets in VRM:
                                        - ADP3180 PWM controller - in 3 phase mode
                                        - ADP3418 as Modfet drivers
                                        - High side Mosfets STD38NH02L (from ST)
                                        - Low side Mosfets STD90NH02L
                                        Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
                                        I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
                                        02-08-2025, 11:59 PM
