Asrock E350M1
  • sebr
    • Oct 2010
    • 79
    Asrock E350M1
    Hello guys I have a very strange problem with my Asrock E350M1 that serves in my little homeserver. On every reboot the system hangs: after it shut down and next you would expect the BIOS Post showing up nothign happens. The Fans run at full speed, black screen, no beep. After disconnecting the power cord and reconnecting it then it takes further attempts and sometimes I have to go through this process 20 times to get it to boot. Also when I try to enter the BIOS the post screen freezes. But if I not touch it during POST and let the server boot it runs rock stable. What is wrong here?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Asrock E350M1
    Sounds like BIOS corruption almost, tried installing the latest BIOS?
    • sebr
      • Oct 2010
      • 79
      Re: Asrock E350M1
      Well I not see any chance how to do that as I am not able to enter the BIOS / UEFI and start the update
      Removed the Battery already but nothing changed.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Re: Asrock E350M1
        They have BIOS updates for both MS-DOS and Windows.
        I prefer to flash from DOS, it is usually the most reliable way to flash...
        • cpt.charlie
          • Sep 2013
          • 270
          • Spain
          Re: Asrock E350M1
          Have a look at the caps and test it with a different PSU just in case.
          • sebr
            • Oct 2010
            • 79
            Re: Asrock E350M1
            I tried different psu and ram. No luck. Caps look ok . The board is just three years old. Now it not start at all. Maybe try hairdryer ? Like i said once its up then it runs well
            • macabook
              by macabook
              đź§© Initial Issue
              07-24-2025, 02:17 PM
            • gabrieljma1
              Request: Full BIOS dump for ASRock Z790-CX (DDR5)
              by gabrieljma1
              I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
              The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
              I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
              10-08-2025, 03:32 PM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
            • pirati
              by pirati
              Yesterday, 04:20 PM
            • paulwal
              Updating a BIOS on ASROCK
              by paulwal
              Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
              https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
              I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
              CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
              Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
              It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
              10-02-2023, 04:13 PM
