Polymer's on mainboards, new trend?
  • MD Willington
    • Sep 2004
    • 702
    Aparently EVGA, the company that makes video cards, is making NF3 & 4 mainboards...
    http://www.evga.com/articles/public.asp?AID=239
    They have chosen polymer caps over "plain-ol-jelly-bean" electrolytics...
    This is what they say about them.
    Capacitors are one of the most important items on your motherboard - and it has a lot of them. They are used to filter the power supply lines (the +12, -12, +5, -5, +5VSB, and +3.3 lines) to keep noise down and they are also used by the motherboard's switching regulators that provide the power given to the CPU.
    Since the capacitors are in one way or another responsible for powering every single item on, or attached, to your motherboard, it makes sense to use the best ones possible.
    The EVGA 115-K8-NF31-AX uses Polymer Based capacitors rather than the cheaper and more popular Electrolytic Based capacitors. This means that on our capacitors, the Mean-Time-Between-Failures is greater than 10 years - while Electrolytic capacitors tend to begin failing after only about 2 years. Ours are also rated at 105 degrees C rather than the standard 85 degrees. This means that they make less heat and can withstand more, keeping even the hottest of motherboards stable.
    I know Panasonic, Rubycon & Nichicon make polymer caps...Your thoughts on EVGA's shift to polymer??
    MD
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    I've NEVER seen a motherboard using 85* caps, EVER. That's BS right there. I've also never seen a motherboard have capacitor failures in 2 years when using proven lytics, such as Rubycon. The recent Nichicon HM series failures are the exception to this, however, most high-end capacitors live well beyond the motherboard's useful lifetime.
    All the same, I'd like to get my hands on one of these and put a scope on it, and see how clean the various rails are using the polymer caps.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      high end boards use these caps and have been for a long while.
      thats those purple or blue sanyo os cons.
      i save them whenever i scrap a board that has them.
      • MD Willington
        • Sep 2004
        • 702
        I though I read a bit of bovine effluent when I was reading that and got a bit of a chuckle...85*C...LOL.
        I agree with good caps lasting longer than 2 years...
        I just received a Sante-Fe KM mainboard (socket 462)...All Chemi-con LXV's in the power section, those are Sanyo's IIRC, it's quite old since it only has a KT133 chipset (2x100 FSB)...
        Anything to make a buck I guess...
        Hopefully more companies will take this route...the Abit deal may be scaring them a little...
        MD
        • RJARRRPCGP
          • Jul 2004
          • 6304
          I have those for caps on my eVGA GeForce 4 Ti4200 64 MB!!!! Cool!!!!
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            who is doing the oem for evga?
            looks like a nice board. hope they stick to 100% polymers, it is a good marketing point. pity about the marketing material though, should have passed it by the technical dept.
            it is a curious looking board though. smaller than the others of the same chipset, looking a bit crowded but still functional.
            compare it to the gigabyte board. look at the damn smt components on that, packed.
            http://www.pcstats.com/articleview.cfm?articleID=1612
            have the polymer caps eliminated a lot of the smt components for the evga board?
