VP6 CPU Speed Problem - CPU is unworkable or has changed?
  • Breezy
    • Dec 2008
    I've had my VP6 for over 7 years now and Its been an outstanding board and the only problem I've had with it is the CPU speed seems to re-set itself ocassionally and I have to go into the bios-> save changes and reboot a few times for it to boot with the correct speed.
    I have 2 x P3 1GHz CPU's running in it and it re-sets itself to 500mhz sometimes and in addition to this the date and time in the bios also gets re-set to 2001 too.
    "CPU is unworkable or has changed"
    I've flashed the board to the latest BIOS which is YT i beleive 24/07/2001?
    I have done a bit of research and think it could be the cmos battery?
    I've anyone has experienced this problem or knows how to fix it that would be much aprpeciated as I woudl love to get my vp6 working 100% so I can use it for a Media centre PC!
    Pav
  • bgavin
    • Jan 2007
    • 1355
    Re: VP6 CPU Speed Problem - CPU is unworkable or has changed?
    Power supply and/or board caps.
    • Breezy
      • Dec 2008
      I was getting the same issue when I purchased a new power supply a couple of years ago?
      Do you have any more info on the board caps? i'm not getting any stability issues at all when its running its just ocassionally re-setting the cpu speed info and date/time.
      I guess changing the battery wont do any harm
      Pav
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        replace cmos battery and recap it.
        it will then continue to serve you well.
        any vp6 that still posts is worth fixing.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Yup. Recap. FWIW, I still have a VP6 in operation as a backup server.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            and use this bios.
            then thank topcat.
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
            • HTR-Informatique
              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
              by HTR-Informatique
              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
              I also changed the screen because the PC fell and the screen was broken.
              I changed the battery with a new and original battery.
              I also had corrosion/oxidation on the...
              02-09-2025, 06:51 AM
            • perzyk23
              Lenovo T580 - LCD Panel problem - error 0288
              by perzyk23
              Good morning,
              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
              10-25-2024, 12:42 AM
