Identifying bad capacitors ?
  • bianchi77
    • Jun 2016
    • 1121
    Everyone,
    How can I identify a bad capacitor if they're looking good ?
    Only unsoldered and test with ESR meter ??
    Cheers
  • Joe Black
    eager to learn
    • Sep 2015
    • 173
    • southeastern europe
    Re: Identifying bad capacitors ?
    Yes, that is the only safe method. Caps can have OK capacity but develop high ESR nonetheless, so w/out ESR meter it's hard to tell for sure.
    That being sad, i have to say that I have yet to see good looking but failed cap.
    I am just a hobbyst and don't have much xp, but all the good looking caps I ever tested were fine.
    stay classy
    • varkatope
      Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
      by varkatope
      Hey there, retro fans.
      I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
      12-15-2024, 09:48 AM
    • chth96
      by chth96
      03-09-2024, 10:03 PM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
    • JimBanville
      ESR meter (MK-168) not showing ESR readout on certain capacitors?
      by JimBanville
      I'm doing a recap job. I measured three Rubycon 50v 33uf electrolytic capacitors and they all showed about 31uf of capacity on the MK-168 transistor tester (ESR meter) but no ESR reading at all. I then measured some brand new caps with ratings around these rubycons and the meter correctly gave both a capacitance AND an ESR readout. Any ideas?
      04-14-2021, 06:39 AM
      12-31-2023, 06:04 AM
