Endless repeated beep ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys what does it mean by endless repeated beep ?
    Is it incompatible CPU ?
    Diagnostic POST showing C1C1....
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Endless repeated beep ?
    Why don't you check the website of the motherboard vendor and the cpu compatibility list ?
    What's the point of owning a card if you don't know what the error codes mean ?
    Have you got a GUARANTEED WORKING stick of memory with no faults in ?
    Have you tried another CPU ?
    • bianchi77
      • Jun 2016
      • 1121
      I don't have another CPU....I reckon the CPU is not compatible...I used Celeron D 346
      I can't find the meaning of ...Beep-beep-beep repeating
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        if its an award bios board, it should mean memory not present or bad. try another memory module. if it still doesnt work, try another dimm slot. it could be one or more bad dimm slots.
        • bianchi77
          • Jun 2016
          • 1121
          I have no idea which BIOS is it....how can I see it ? I can only see the motherboard type....looks like it belongs to HP but the motherboard is MSI
          • bianchi77
            • Jun 2016
            • 1121
            the board code is MS-7352
            • bianchi77
              • Jun 2016
              • 1121
              http://www.findlaptopdriver.com/msi-...ons-20h090712/
              BIOS = unknown
              • bianchi77
                • Jun 2016
                • 1121
                BIOS :
                http://h20564.www2.hp.com/hpsc/swd/p...&swEnvOid=1098
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Is your memory a known 100% working compatible stick ?
                  • bianchi77
                    • Jun 2016
                    • 1121
                    Yes my memory is a good one, tested already...boot until linux and stable...
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Could it be CPU matter ? but it's LGA 775...from I can read and learn...there is some different core for LGA 775, that's I've been thinking...
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Booting Linux is not testing the memory. Test the memory fully and report back.
                        • bianchi77
                          • Jun 2016
                          • 1121
                          If it doesn't work it will not work on another board n boot until OS
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Use memtest86.
                            • bianchi77
                              • Jun 2016
                              • 1121
                              memtest is dos based?
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                yes
                                • ChaosLegionnaire
                                  HC Overclocker
                                  • Jul 2012
                                  • 3264
                                  • Singapore
                                  msi sometimes uses either award or ami for their bios so guessing what bios vendor it is could be tricky. but if its ami bios, a post code stop at C1 means it stopped at setting the processor boot strap information. maybe cpu not recognised or supported by the board? try another known working cpu with a slower fsb?
                                  this is either a ram/cpu not recognised or supported problem.
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    I've tested with Celeron D 346
                                    and from this :
                                    http://www.findlaptopdriver.com/ms-7...-support-list/
                                    I can not find it.....do you think, it's CPU incompatible issue right ?
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      Or faulty memory !
                                      • bianchi77
                                        • Jun 2016
                                        • 1121
                                        I haven't put any memories on it so I reduced the posibility of faulty memory...
                                        trying to debug it one step to another...
                                        There's a possiblity on memory as well...but in this case I didn't put it yet...how can the software at BIOS saying it's a faulty one unless it's doing something quirky..??
                                        • pkslowk
                                          Debug Card Error Code and Solution
                                          by pkslowk
                                          Sr. Motherboard Debug Error Code Solution
                                          1 Intel 845 E9 Bios Related Problem
                                          2 Intel 845 D4 CPU Socket Related problem
                                          3 Intel 845 37 Bios Related Problem
                                          4 Intel 845 7C Bios Related Problem
                                          5 Intel 945GCPE 34 Bios Related Problem
                                          6 Gigabyte 845 2 Ram Related Problem
                                          7 IBM Server A6 A7 Ram Mismatch Problem
                                          8 Asus 845 29 CPU Related Problem
                                          9 Lenovo I946 97 C-Mos Jumper related
                                          10 Gigabyte 845 A0 CPU Related Problem
                                          11 Asrock G31M-VS D7 Bios Related Problem
                                          12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                                          01-28-2021, 12:51 PM
                                        • Ymotaqi
                                          ROG STRIX Z590-A GAMING WIFI has no POST no BEEP no diag LED
                                          by Ymotaqi
                                          The motherboard does not POST and has the following symptoms:
                                          When the power button is pressed, the fans and RGB turns on.
                                          When the power button is pressed, the motherboard voltages 12, 5, and 3 are connected.
                                          The motherboard does not beep.
                                          None of the diagnostic LEDs light up.
                                          USB voltage is off.
                                          VCORE voltage is off.
                                          The BIOS software was downloaded from Asus site and installed using the Q FLASH button, but it made no difference.
                                          I would appreciate it if anyone could guide me on the cause of the problem.
                                          01-12-2025, 04:15 AM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                        • WVUfan
                                          PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                                          by WVUfan
                                          hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                                          08-11-2025, 01:12 PM
                                        • ktmmotocross
                                          Ps5 pro - one beep and not start after hdmi port change and decoder ic reflow
                                          by ktmmotocross
                                          Hello.
                                          Have this ps5 pro EDM033 that came with damaged hdmi connector. i replace it and console works for few days but show hdmi problems when cold start. so cold joint. reflowed connector and decoder ic as i think he have cold joint. but now i have only one beep and no start. can heatdamage of this decoder ic prevent start?
                                          i have ps5 repair guide but not ps5 pro so link me to it if u know it
                                          04-27-2025, 01:10 AM
