Endless repeated beep ?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Endless repeated beep ?
    Faulty memory, no memory, beep beep beep.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Originally posted by bianchi77
      Guys what does it mean by endless repeated beep ?
      Reseat the RAM... It's a RAM code, at least with an Award BIOS...
      CPU problem probably would be zero bleeps...
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • bianchi77
        • Jun 2016
        • 1121
        Ok, it means the CPU is doing the job...it's compatible...
        only the spec is saying it's not compatible but in the circuit it's doing the job...
        All right I'll have a look again and post...
        Cheers
        • bianchi77
          • Jun 2016
          • 1121
          Ok...here's what I got....
          when there was no memory.....POST = C1C1 and short beep repeatedly
          and I put memory...the beep is gone but it's still POST = C1C1 and not moving anywhere...
          I try to seat memory on every position and combination...still the same...
          and the memory is fully tested working....
          So return again....does the CPU matter ?
          because I don't see something running on POST diagnostic at all only 0000 then jump to C1C1 and freeze with memory....without memory same thing with short beep repeatedly...
          Any ideas ? or clueless already ?
          • bianchi77
            • Jun 2016
            • 1121
            Currently I'm using Celeron D 346...it's outside from the list...
            Msi MS-7352 CPU Support
            MSI MS-7352 Mainboard Processor Support List.
            * Celeron Dual-Core Processors:
            E1200, E1500
            * Celeron Processors:
            420, 430, 440, 450
            * Pentium Dual-Core Processors:
            E2140, E2160, E2200, E5200, E5300
            * Core 2 Duo Processors:
            E4400, E4500, E4600, E6320, E6420, E6550, E6850, E7300, E7400, E8600
            * Core 2 Quad Processors:
            Q6600, Q6700, Q8200, Q8300, Q8400, Q9400, Q9500, Q9650
            • bianchi77
              • Jun 2016
              • 1121
              The BIOS belongs to HP, so may be there are some revisions, it's not either AMI or AWARD...
              • bianchi77
                • Jun 2016
                • 1121
                it has ability for this celeron, ( celeron 420 ) :
                http://ark.intel.com/products/29734
                what I used (celeron D 346 ):
                http://ark.intel.com/products/27125/...Hz-533-MHz-FSB
                That's the CPU fact I can see...
                • bianchi77
                  • Jun 2016
                  • 1121
                  There's a possibility that BIOS is scanning for CPU id and saying it's not CPU...that's what I can think of from the data I have read..
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Seems just as likely for there to be termination voltage issues... Possibly with it appearing to be a 90 nm! Especially on-die RAM termination and/or FSB termination...
                    Arc A770 16 GB
                    • bianchi77
                      • Jun 2016
                      • 1121
                      okay, if that's what you think, what voltage should I see for RAM ? 1.8V ? which FET ?
                      • bianchi77
                        • Jun 2016
                        • 1121
                        So you think the motherboard can accept this Celeron 346D ?
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          1.8 V is standard for DDR2 SDRAM voltage.
                          And for the FETs I would first check the CPU FETs then the RAM FETs.
                          It looks like it should work with a Celeron D 346, because it's socket 775, but dunno...
                          Arc A770 16 GB
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Ok, let's see the FETs voltage...what's the normal voltage for CPU ? 1.25 -1.38V ?
                            • bianchi77
                              • Jun 2016
                              • 1121
                              I tested on FET, which is the biggest near the CPU = 09N03LA
                              Diode test in circuit drain to source =0.23V either way .... black to red, red to black probe...normally one of them should be OL
                              And it looks burn....there is chance, this one is the faulty FET..since I can't see the label anymore...could be burned ?
                              I'm not sure, because I haven't seen the voltage on it...
                              In progress...
                              • bianchi77
                                • Jun 2016
                                • 1121
                                and the FET is in circuit, so it could be something else unless I desolder and check it..
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  #36
                                  So you checked the memory with memtest86+ ?
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    I've checked the memory, no problem
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      I've measured the voltage for DDR2...all are ok 1.8V...and voltage for CPU 1.35V which is normal...
                                      The only thing I can think of, is testing it with the proper CPU according to the spec...
                                      Clock is ok I reckon...I can see 0000 jump to C1C1 and blinking LED repeatedly, and beep....at least it's responding to clock generator...
                                      • ChaosLegionnaire
                                        HC Overclocker
                                        • Jul 2012
                                        • 3266
                                        • Singapore
                                        #39
                                        u have to use one of the cpus in the supported list. there are some oem boards out there which will only work with cpus in the supported list. the cpu u are trying to use is a prescott based celeron with a 533mhz fsb. i believe the motherboard can only work with cpus with an 800-1333 mhz fsb from the cpu list u posted.
                                        also, it seems the motherboard will only support cpus based on the core architecture. cpus based on the prescott design are unsupported thus the mobo will not post and the mobo will just "play dead" instead. i've seen some mobos play dead if u try an unsupported cpu.
                                        • bianchi77
                                          • Jun 2016
                                          • 1121
                                          @chaoslegionnaire....
                                          Yes, that's what I've been thinking, my mobo doesn't support prescott core,
                                          I need conroe core at least....it has the same LGA775 but different core and the BIOS is already designed to detect CPUID....and if it's not right...no POST...
                                          I'll find conroe CPU and keep posted..
                                          • pkslowk
                                            Debug Card Error Code and Solution
                                            by pkslowk
                                            Sr. Motherboard Debug Error Code Solution
                                            1 Intel 845 E9 Bios Related Problem
                                            2 Intel 845 D4 CPU Socket Related problem
                                            3 Intel 845 37 Bios Related Problem
                                            4 Intel 845 7C Bios Related Problem
                                            5 Intel 945GCPE 34 Bios Related Problem
                                            6 Gigabyte 845 2 Ram Related Problem
                                            7 IBM Server A6 A7 Ram Mismatch Problem
                                            8 Asus 845 29 CPU Related Problem
                                            9 Lenovo I946 97 C-Mos Jumper related
                                            10 Gigabyte 845 A0 CPU Related Problem
                                            11 Asrock G31M-VS D7 Bios Related Problem
                                            12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                                            01-28-2021, 12:51 PM
                                          • Ymotaqi
                                            ROG STRIX Z590-A GAMING WIFI has no POST no BEEP no diag LED
                                            by Ymotaqi
                                            The motherboard does not POST and has the following symptoms:
                                            When the power button is pressed, the fans and RGB turns on.
                                            When the power button is pressed, the motherboard voltages 12, 5, and 3 are connected.
                                            The motherboard does not beep.
                                            None of the diagnostic LEDs light up.
                                            USB voltage is off.
                                            VCORE voltage is off.
                                            The BIOS software was downloaded from Asus site and installed using the Q FLASH button, but it made no difference.
                                            I would appreciate it if anyone could guide me on the cause of the problem.
                                            01-12-2025, 04:15 AM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
                                          • WVUfan
                                            PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                                            by WVUfan
                                            hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                                            08-11-2025, 01:12 PM
                                          • ktmmotocross
                                            Ps5 pro - one beep and not start after hdmi port change and decoder ic reflow
                                            by ktmmotocross
                                            Hello.
                                            Have this ps5 pro EDM033 that came with damaged hdmi connector. i replace it and console works for few days but show hdmi problems when cold start. so cold joint. reflowed connector and decoder ic as i think he have cold joint. but now i have only one beep and no start. can heatdamage of this decoder ic prevent start?
                                            i have ps5 repair guide but not ps5 pro so link me to it if u know it
                                            04-27-2025, 01:10 AM
