Dead Motherboard after storm
  • Bishop
    • Apr 2009
    • 99
    I got a bad motherboard from a HP700 with 67 Caps on board and every one looks perfect, no leaks no swelling and all good name brand.
    I can't replace them all but I can replace the most important caps if I can find out which way the power might flow.
    Any one out there with knowledge of power flow in motherbaords?
    Thaanks
    • 31040
    Re: Dead Motherboard after storm
    thunder-storm followed by a board that wont boot, first suspect is the ethernet controller.
    check it for burn marks and see if it's getting hot.
    • Bishop
      • Apr 2009
      • 99
      Board is dead, the only thing I get is the cpu cooling fan kicks, or moves just a little ans stops when the power cord to the power supply is plugged in from the wall. I can't find any cap that appears to have failed.
      I have a power supply tester and I know the power supply voltage is correct at all points.
      No burn spots anywhere, board looks perfect.
      I was thinking about replacing a few key caps if I can identify the most guilty caps that would stall the motherboard.
        • 31040
        it's not caps.
        99% chance the ethernet controller is short-circuit.
        the static in the air during a storm goes into the network cable that acts as an antenna.
        this is made worse by the transformer on the board or in the ethernet socket - then it hits the controller with several thousand volts!
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          I have to go with ethernet controller here....
          Follow the white rabbit.
          • Bishop
            • Apr 2009
            • 99
            Has anyone opened a short in the ethernet board wiring?
            The board is dead so it would not hurt anything to desolder a point somewhere and use a usb ethernet connection.
            Has any tried? I can easily pull a bad cap I should be able to open a link if I can id the junction on the motherboard
              • 31040
              you generally have to lift the ethernet chip wih hot air and tweezers.
              • Bishop
                • Apr 2009
                • 99
                I had to try.
                I removed the metal cover over the ethernet port on the motherboard and I was able to remove the ethernet chip by severing clean the connections of the chip to the motherboard.
                I put everything back together and plugged in the power..........nothing,
                I believe I did not damage the motherboard or the area around the ethernet plug, it was worth a try. I have a usb network port adapter and was ready to install it, but no change, still dead motherboard.
                I'm open to try something else, got any ideas?
                  • 31040
                  got a foto? i have never seen a motherboard wih a shielded ethernet PHI chip.
                  • Bishop
                    • Apr 2009
                    • 99
                    I took a pic before I put the system back together.
                    Don't tell me I pull the wrong part.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      From what I can see, it's the rtl813* But I can't see much, so I'm probably wrong about something. It looks like the board you pulled was part of the Ethernet, so no loss. A more complete job if anything...
                        • 31040
                        RTL8100 network controller
                          • 31040
                          what board is it btw.
                          • Bishop
                            • Apr 2009
                            • 99
                            It's a D33007 motherboard
                            It there a simpler way to desolder just a link to the ethernet chip?
                            Remove a solder joint somewhere with out removing the entire chip?
                            I'm now on a mission to see how far I can go before placing the motherboard in the can.
                            Sometimes circuitboard developers leave a place to open a circuit.
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              Remove a solder joint somewhere without removing the entire chip?
                              Opening a jumper won't do. Even if you kill power to the RTL8* chip the southbridge will still "see" it. It will still try and POST it and fail. The chip needs to be completely eliminated. Now, i don't recommend this method, but, you can remove it without a hot air station. Separate the pins from the chip using a pair of needle nose pliers, but don't damage the board in the process. Once you have the pin separated grab the soldering iron and drag solder the pins off the board, then grab the desoldering wick and clean up the mess you made. Again, this is very risky. Don't do this to a customer's gear and don't do this to something you absolutely need to get working, It may screw it worse.
                                • 31040
                                if it does not have a pad under it, you could WITH CARE, cut all the pins by pressing a blade down on them where they enter the package.
                                then lift the chip away leaving the pins.
                                just make sure none of the pins are touching each other before you test it after.
                                • lbwlow
                                  • May 2015
                                  • 125
                                  • Malaysia
                                  Usually once a LAN chip was shorted it become extremely hot to touch. The proper way to remove it is by desoldering it with hot air station / heatgun. Last time i ghetto remove it by using a lighter, yeap... i know that is a very very bad and wrong way to remove it. But well... i need to get the board working in no time. After i remove it and it still works.
                                  • Bishop
                                    • Apr 2009
                                    • 99
                                    I was able to get the chip off the motherboard and it looks pretty clean.
                                    I tried to put a microscope at 10 power to the board but I could not get a real good focus because I couldn't get close enough.
                                    Take a look.
                                    • Bishop
                                      • Apr 2009
                                      • 99
                                      Here's the chip off the board
                                      • Bishop
                                        • Apr 2009
                                        • 99
                                        Try again
                                          ASUS ROG FLOW-X13-GV301RE-007W Hybrid (2-in-1) Flow X13 Specification for Upgrade or Repair
                                          This specification for the ASUS ROG FLOW-X13-GV301RE-007W Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FLOW-X13-GV301RE-007W boardview and FLOW-X13-GV301RE-007W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
                                        • tk3000
                                          Dead Laptop Motherboard, then refurbished one installed...
                                          by tk3000
                                          My venerable and old laptop (Toshiba Satellite P75-A7200 equipped with an i7-4700MQ, circa 2014) and previously a powerful machine during its heyday is no more. Have been using it for many years, but about 3 months ago it went kaputt for no apparent reason (left it on overnight [normally it goes to standby mode after some idle time], and in the morning it was cold dead with no boot, no post, no leds; nothing at all).
                                          Since the 1990s I have been building custom desktop computers, etc; but it has been few years since my last built one and for the last 15 years I have built very few...
                                          08-20-2022, 08:45 AM
                                        • DrvLikHell
                                          Dell Latitude E6540 - 2nd dead motherboard
                                          by DrvLikHell
                                          Greetings and sanitations! Several years ago I received some really awesome help on this forum for fixing my monitor (which is still working) so I figure maybe someone can help with this laptop issue.
                                          I have a Dell E6540, motherboard 9411P, DP/N:VWNW8. A year ago it died a strange death where at first it wouldn't turn on all the time, but would turn on when it felt like it, then it got worse where it wouldn't turn on at all and I would just get a flashing light. So I replaced the motherboard with a matching part number board. (I still have the old motherboard) Now a year later this...
                                          01-30-2021, 02:36 PM
                                        • bobbintb
                                          TCL Roku 55S403TCAA dead after storm
                                          by bobbintb
                                          I have a TCL Roku 55S403TCAA. It quit working after a storm. Other electronics quit working as well so I am pretty sure the storm had something to do with it. Anyway, I took a look at it, no obvious damage, blown components, scorch marks, etc. I am looking at the power board first, 40-L141H4-PWG1CG. I've repaired bad caps and blown components but nothing more extensive beyond that. I am trying to troubleshoot it, but I can't even find the fuse on this board. There are markings on the PCB saying "replace fuse as marking" however. I attached a photo of the board. I am also testing the...
                                          11-19-2023, 05:02 PM
                                        • Archimedes
                                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                          by Archimedes
                                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                          Fans are spinning. Blindly could install windows11 and got the device manager...
                                          07-30-2024, 05:14 PM
