A7S333 1 long beep 3 short beep and shut down ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    I got Asus motherboard with :
    Is it a GPU problem ?
    CPU fan is spinning...
  • R_J
    • 9555
    Re: A7S333 1 long beep 3 short beep and shut down ?
    According to the manual, One Long beep followed by three short beeps means Video card not found or video card memory bad,
    Try another agp video card or try a pci video card, try removing the memory and see what happens, I have seen memory and agp conflicts before, also try reseting the bios if you have'nt already
    • bianchi77
      • Jun 2016
      • 1121
      I removed everything still beep awhile and then completely shut off...is one of the FET faulty ? if I remove the CPU...it's running ok...the fan spinning and it's still on
      • bianchi77
        • Jun 2016
        • 1121
        any ideas with it ?
        • R_J
          • 9555
          Are you removing 'G'pu or 'C'pu, post 1 said Gpu post 3 said CPU, If you removed the CPU and it works, I would check the fets around the CPU socket or your CPU could be bad
          • bianchi77
            • Jun 2016
            • 1121
            I removed all...CPU and GPU...fan is running without stopping...
            but if I put CPU...it's running awhile then stop ...no GPU
            • bianchi77
              • Jun 2016
              • 1121
              I check Q3 and Q4 = 0V on the drain, it could be a death FET and caps...
              3 caps are short...I will see if I remove them...what's the response on my DMM ??
              I keeo posted...
              • bianchi77
                • Jun 2016
                • 1121
                nothing wrong with those FET or caps, I reckon the CPU is not right...
                without CPU, fan can run ok, but after I put CPU...fan on for about 5 seconds voltage at 03 and Q4 is 1.7V which is CPU core and off....
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  I suspect the AGP slot... AGP systems seem finicky. It's not seeing a valid video card...
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • bianchi77
                    • Jun 2016
                    • 1121
                    without AGP or anything, only CPU, power ON....few seconds fan rotating....and OFF
                    ok I will see with different VGA...
                    I keep posted..
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Not working with different VGA....I can hear a beep...but power off ..
                      without VGA and memory....beep as well and power off..
                      CPU is not good...
                      • bianchi77
                        • Jun 2016
                        • 1121
                        I tried with different CPU, good one, but the symptom is the same....beep...fan spin and off...if I release the CPU....it's stable...any clues ?
                        I'll measure the voltage now...
                        • bianchi77
                          • Jun 2016
                          • 1121
                          I've found 1 diode 1N5817, forward voltage only 0.1V...
                          it could be the culprit ??
                          • bianchi77
                            • Jun 2016
                            • 1121
                            I want to replace it with 1N4007...
                            • bianchi77
                              • Jun 2016
                              • 1121
                              the caps with red line on top are failed on continuity test...
                              they're all beep very loud...
                              could it be the problem ?
                              but I can't see any bulge on top...
                              Have a look on the photos
                              • bianchi77
                                • Jun 2016
                                • 1121
                                it's 3300uF/6.3V
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  could it be because of low rpm CPU fan ? and there is no chassis fan and power fan..
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    Voltage measurement, PWM and zener photos...
                                    Could it the problem with PWM and zener ?
                                    Any clues ?
                                    Zener = LM431ACT
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      Originally posted by bianchi77
                                      it's 3300uF/6.3V
                                      Are they KZGs? All 3300uF KZGs were visibly bad (bulged) on my Asus A7N8X-X! And that's when just sitting in the room of my former place!
                                      Arc A770 16 GB
                                      • bianchi77
                                        • Jun 2016
                                        • 1121
                                        Nope they are 5 dark purple Rubycon 3300 uF/6.3V capacitors...is it possible that my PWM is faulty ?
