A7S333 1 long beep 3 short beep and shut down ?
  • bianchi77
    • Jun 2016
    • 1121
    Re: A7S333 1 long beep 3 short beep and shut down ?
    On POST code diagnostic I got C1 and motherboard is off after that....
    What does it say to me ? any experiences ?
    • bianchi77
      • Jun 2016
      • 1121
      can it be the audio modem chip is short and making all the system shutdown...?
      It's the closest to LM78L05
      https://cdn.badcaps-static.com/pdfs/...c2f51bc7b4.pdf
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #43
        C1
        Detect memory
        -Auto-detection of DRAM size, type and ECC
        • bianchi77
          • Jun 2016
          • 1121
          but it shut off after showing C1.....how do you reckon ? is it something wrong with my VRM
          ? I've replaced all the FET and Caps...but no avail...could be my buck controller and driver ?
          NCP5322 ?
          • bianchi77
            • Jun 2016
            • 1121
            LM78L05ACM is connected directly to 74HC4053...which a logic HCMOS chip...
            I have no idea what's it doing yet ??
            • bianchi77
              • Jun 2016
              • 1121
              74HC4053, could it be died already ? and making the system shut off ??
              • bianchi77
                • Jun 2016
                • 1121
                • bianchi77
                  • Jun 2016
                  • 1121
                  exact chip :
                  • bianchi77
                    • Jun 2016
                    • 1121
                    Is it possible that I get a corrupted BIOS ?
                    • bianchi77
                      • Jun 2016
                      • 1121
                      can I upload this one
                      http://dlcdnet.asus.com/pub/ASUS/mb/...316.1472338911
                      straight away with chip flash programmer ? thanks
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #51
                        1 long and 3 short beeps is no VGA detected.
                        https://www.asus.com/support/faq/1029959
                        Are you testing with a known quality working PSU ?
                        • bianchi77
                          • Jun 2016
                          • 1121
                          Yes I'm using a working PSU...I've tested this PSU with other mobo...works ok...
                          I will try changing buck controller and see...
                          either death buck or corrupted BIOS or both...
                          • bianchi77
                            • Jun 2016
                            • 1121
                            I got progress....I've replaced all the FET and now it bot until displaying C1C1 on POST diagnostic...beep...and shut down...
                            I think it's NCP5322 buck controller not right....
                            Do you reckon ?
                            • bianchi77
                              • Jun 2016
                              • 1121
                              from physical appearance, looks like NCP5322 buck controller is burned, please have a look at the photo...
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #55
                                Are you serious ? You can't see anything in that photo.
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  Can't you see the chip next to CPU on the right ?....ok, I'll try taking picture again...
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    Another photo...hope it's better now...
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      I can't read the label on NCP5322, because of burn I suppose...must take a good closer look with magnifying glass to see its label....
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #59
                                        Buck controller seems fine to me.
                                        Why do you always think it's the buck controller that's the problem?
                                        Honestly, from all of the motherboards I got in for repair, I've never had to replace a buck controller. Maybe a few FETs and the occasional FET driver. The buck controller is protected pretty well.
                                        • bianchi77
                                          • Jun 2016
                                          • 1121
                                          I have replaced all the FETs and it's still happened....turn on trying to POST and shut off after few seconds ?? do you know what else then ?
