Ecs g31t-m rev:1.0
  • johnis82
    • Apr 2016
    • 22
    • Greece
    Ecs g31t-m rev:1.0
    Hello guys iam new to this forum! It is nice to know people are not throwing away their staff and trying to repair it as i do!
    My problem is with a mobo ECS G31T-M has got a q6600 cpu on it!
    The problem is when i turn the psu switch on the mobo starts automatically working without pressing the power switch, no display!
    I changed the psu and ram without any difference in operation!
    I have tryed to repair it changing all 1000uf 6.3v caps but nothing, no cap seems to have a problem.
    Iam working with the mobo out of the box!
    Is there anything i can do to save this mobo? (Sorry for my bad english)
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Ecs g31t-m rev:1.0
    Perhaps BIOS setting under section Power Management Setup ?
    Check PWRON After PWR-Fail - may not be set to Power Off
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • johnis82
      • Apr 2016
      • 22
      • Greece
      Thanks for the feedback but the motherboard doesn't post, no display or something! i can't get to bios. Only the cpu fan is spining
      • lbwlow
        • May 2015
        • 125
        • Malaysia
        Yeap, i got to agree with u, C2Q are still very capable for today standard, even core 2s are still very capable (at least for my own usage).
        Do u heard any beep when u turn on your motherboard with no RAM insert ?
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          Which RAM are you using - is it DDR2-667 or DDR2-800 ?
          Are CPU and RAM proven to work in other motherboards ?
          Try clearing CMOS - follow procedure in ECS manual to use CLR_CMOS jumper
          If no success, try removing RAM then powering on, to see if it beeps for memory not detected
          • johnis82
            • Apr 2016
            • 22
            • Greece
            Thanks guys for the responce i have done that! I have both ddr2-800 Good Ram pc2-6400 and ddr-667 Mushkin and kingston.
            The board was working with one Kingstone kvr667d2n5 1gb and one mushkin 667 2gb for some years without problems!
            There isn't any beep on system power on with or without ram on it (speaker connected on the board) and CMOS is cleared!
            The think i don't understand is (like i said before) why the mobo powers up without pressing the power button or shorting the pins! Is like when you plug any PSU on it powers on without any other action. I have many RAM's in my drawer are working properly
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              Power up without pressing button is clue perhaps CMOS is lost, resulting in default setting
              Have you tried a new CMOS battery ?
              Especially seeing it's been "working for some years without problems"
              I was recently about to scrap an IPIBL-LB board (G33 chipset, similar to yours) which seemed to be dead
              Tried a fresh CR2032, and it worked
              • johnis82
                • Apr 2016
                • 22
                • Greece
                The battery is 3,07volt but i changed it with a new one as you point, still nothing! Could that be a bad bios IC? And if so where can i get one?
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  Maybe, or existing one got corrupted
                  ECS manual shows SPI_ROM header, including pinout
                  So you could possibly reflash in situ, by following SPI reflash #1 and SPI reflash #2
                  IC itself probably looks like: C7Q67 BIOS chip
                  • johnis82
                    • Apr 2016
                    • 22
                    • Greece
                    wow didn't know i can reflash the bios! Thanks a lot Can you give me more info to this it is a bit coplex to me!
                    Do i need to remove the bios IC from the board and reprogram it?
                    Can you explain the procedure cause i didn't understand from the site you post!
                    • johnis82
                      • Apr 2016
                      • 22
                      • Greece
                      pfrcom Thank you very much i did perform a successful bios reflash! But the problem still exists do you think is a north bridge fault or can you point something else that can cause this kind of problem?
                        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-06-2024, 05:30 AM
                      • Natob82
                        Micro Momentary Push Switch?
                        by Natob82
                        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                        12-21-2022, 05:22 AM
                      • grimacelord
                        NEC TurboExpress On/Off Power Switch Replacement Help
                        by grimacelord
                        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                        11-09-2023, 09:49 AM
                      • SluggerB
                        Help making a switch work the opposite way with a relay
                        by SluggerB
                        I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                        I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                        It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                        02-07-2025, 07:57 PM
                        Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                        Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                        ( needs more cam circuits for the machine to work correctly again )
                        https://www.ebay.com/itm/275321870186
                        To
                        3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                        ( not 4 positions but the right amount of cams circuits )
                        https://www.ebay.com/itm/274660439950
                        I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                        03-18-2023, 05:12 PM
